p304
Results 1 to 6 of 6
This is a discussion on p304 within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; im new to owning a subaru but my light came on and i checked it and this was the number, ...
    Jun 2009
    dover, afb
    p304
    im new to owning a subaru but my light came on and i checked it and this was the number, and i need to pass emmissions test how much will it cost to repair and what are the effects it will put on my engine until i get it fixed?
    That's a misfire on no. 4 cyl and there could be a number of causes. Either take the car to a shop or check the ignition system, assuming the car is stock. If the car is modified, list those parts and maybe someone with a similar setup can add some info.
    Jun 2009
    dover, afb
    say i clear the ecu and dont fix it what are the long term effects?
    Since we don't know what's causing the code we can't say.
    Jun 2009
    dover, afb
    welll i reset the ecu and ran it until it rest it self and the code did not come back does that mean it could have been an error? or did i make things worse.
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    It could have been an error but it is highly unlikely. The vehicle needs to cycle (key turn to hot or start) several times with the same code before the light will return. Im guessing it will return, it may just take a few days. As far as long term damage, since the number 4 cylinder is the weakest and misfiring is very bad in a forced induction car you could have a number 4 cylinder detonation. Which in turn would only be fixed with installing a new shortblock. So it comes back to this... Couple hundred now for maintainence or couple thousand later for lack there of? Id personally choose the couple hundred. Good luck man!
    Lead Wrench @ WTF Tuning, LLC
