cooked my clutch....
Results 1 to 15 of 15
This is a discussion on cooked my clutch.... within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; i am new to stick, and last night i absolutely fried my clutch I started from a stop and killed ...
    Registered User khawajakustoms's Avatar
    Jun 2009
    San Jose
    I started from a stop and killed it. I quickly(read: in a slight panic) started it back up and gave it more gas, but the car still bogged and almost died. Pissed, i revved to about 3k and slipped the clutch till I finally got the car into gear (about 7 seconds of clutch slippage) before i was even out of the small intersection i could smell it. i'd tried to start from 3rd gear instead of 1st. I let both the clutch and I chill out for about 10 minutes then drove the last mile to the restaurant.
    after an hour in the restaurant, I started the car back up and immediately could smell my clutch again. shouldnt the car have smelled fine? theres no way the clutch was still hot is there? is there anything that I should to to try to offset the damage that i did?
    and no, I will not be trying that stunt again
    You have two options.
    1. If any of the following is true:
    (a) The clutch slips (revs climb but the car does not accelerate
    (b) The throw-out bearing is noisy (there is a rattle or whirrrrr that goes away when the clutch pedal is pushed)
    (c) The car does not shift
    then replace the clutch
    2. If none of the above are true, drive the car.
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Clutch smell has always intrigued me. Think about it....the clutch is bolted to the flywheel and has an aluminum bell housing almost completely sealed around it, yet when you burn the clutch, the smell is instant a very potent. Where do the fumes escape from?
    Aside from my rant, I burnt the clutch a couple times in my Rex when it was new, acting like an asshat. Almost 50k miles no issues.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    That isn't me laughing at you i promise. I just remember when i did that same thing to my old boss's truck. Well i think the advice you've been given so far is good. And worst case scenario is you have to replace your clutch and join the club. I'd guess that well over half the people on here have replaced the clutch in their subbie. Well good luck with the car and dont get too down on yourself. Hopefully your clutch is still fine.
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
    Dec 2003
    Dallas, TX / Sterling, VA
    This.
    Quote Originally Posted by 06wrx4me View Post
    It's not a closed system like you said. Some gearboxes have removable inspection covers that come off with a couple screws and allow flywheel viewing. I once owned a Mitsu with the AWD that I bought without the inspection cover; drove it for years with the flywheel exposed.
    Jun 2009
    San Jose
    I havent noticed any of these yet, but i'll pay attention just in case. Thanks!
    uhoh... now im going to have to find an answer to this one.. you've intrigued me!
    Quote Originally Posted by GarrettKoonsman View Post
    my dad got a solid laugh out of it too. he had a couple stories for me about his first driving experiences
    now that i know what issues to watch out for, my only question is: why was i still able to smell my clutch an hour later?
    Jun 2009
    San Jose
    oooOoOOoOoOh! cool
    Registered User AsILayDying's Avatar
    Dec 2008
    Central Florida
    Quote Originally Posted by khawajakustoms View Post
    Well regardless of "clutch smell" it seems you have an issue that needs attention. Be alert of the situation and have it checked sooner then later.
    I recently picked up my WRX and have been finding out that the car was owned by a young kid with upgrades and he beat the crap out of the car. I am actually having the clutch replaced today cause I had the issue of clutch slipping "Part A: of option 1 above." But I am upgrading to a Stage 2 Clutch cause I am already Stage II and plan to go just a little bit further and dont want to have to do the clutch again because of HP/TQ limits. But good luck with the car, and if I was you I would seriously have someone take a peek at whats going on with the car.
    BlobEye Syndicate #-666
    Stage II 04' WRX Black (Performance Race Solutions Tuned 310whp)
    "its never enough"
    May 2009
    pffffffffffft your good - clutch probably stank because you opened it again......I could be wrong, but I have never heard of a new clutch going to poop on a 7sec burn..........I think even the most experienced driver on this forum smells clutch from time to time. Having said that - you will probably burn your clutch out faster than most with this car
    Registered User elscoobano20's Avatar
    Oct 2008
    SoCal
    Similar story, I learned stick on my dad's 2000 Boxster S and I DESTROYED his clutch. He literally said it was super soft after I was done with his car haha. Had to get the clutch replaced a few months later... if not weeks...
    Anyways I'm still new to driving stick and it just takes patience. One of the things I always screw up on is taking the clutch out all the way when I just begin to feel the car engage. I always try to remind myself to leave the clutch in as long as I can.
    Good luck!
    Stink-Eye Mob #4
    DGM: Dank Guy Machine
    Mine's named Sasha, whats yours :'D
    Registered User wrx0131's Avatar
    Jul 2007
    Yonkers, NY
    Quote Originally Posted by decrypted View Post
    When i first got my exedy stage 1 clutch last yr i burned it for like 4 seconds at like 3500 rpms. It was on a super steep hill and i just couldn't get out of it. Since then, I hold out my clutch to where it grabs while having the brake held down, whenever im on a super steep hill.
    My clutch was never the same as it first was. Now it grabs super high, but still holds strong. I dont know if because i bought the clutch on ebay (it said exedy on the box) it burns alot easier than any clutch i have ever driven. EVERYONE that has driven my car has burned my clutch. I could smell it. It takes no more than 2000 rpms to start smelling it. I dont know...
    I have an ACT Street disc sitting at home waiting to be put it..
    Bugeye Mafia #213
    Kevin
    2002 Midnight Black Pearl WRX (Traded In!)
    2012 Ice Silver Metallic STi Sedan
    Registered User viperuws's Avatar
    Dec 2005
    Algonquin, Illinois
    I have burned my clutch a few times. It happens. At around 10k miles my clutch seemed to lose some of its bite. I am not complaining too much because now it's a lot easier to drive smoothly and still grips when I want it to(no slippage).
    Remember...A clutch is cheap to replace...a transmission is not.
    Then again, replacing your seats cause they smell like burnt clutch might rack that cost up some.
    CGM 2006 Subaru Impreza WRX - Sold
    WRB 2007 Subaru Impreza WRX STI
    Hawk-Eye alliance #100.1
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    OK, I've done exactly a similiar thing. Yes, you smoked your clutch. What you did was take the resins on your clutch, melted them and deposited them on your flywheel.
    When your clutch cools, being organic, stuff gathers on the flywheel and you start to brush the residue off your flywheel.
    Your clutch will heal itself after a few miles and still grab like new.
    Now, do this too many times or mod your car to exceed the hp of the clutch, and you will be looking at replacing it after 10k miles.
    However, my parting advice is take it easy on your tranny, let the clutch rebed itself, and you will be fine.
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    If the clutch was a 100% closed system.. then where would all the dust go? they can't be.
    OP... you'll be fine. Just drive the car normally. You probably glazed the clutch face. When the clutch isn't fully engaged and there is a large amount of slippage... the clutch face glazes over. If you have an organic clutch, then the clutch face will need to be broken in again... with normal driving. It'll be back to normal in a week or so of normal driving.
    If the clutch face is not organic, or an organic blend... 9 times out of 10.. it's not recoverable. Luckily you're on a stock clutch, and you'll be able to recover the face of the clutch.
    You just need to drive gently and shift gears often so you can wear off the glazing. No hard launches.. and try to avoid hill starts if possible.. for safety's sake, and the clutch's sake.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
