Turbo Timer? - Page 2
Results 16 to 30 of 37
This is a discussion on Turbo Timer? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Ok, so then I have alot to learn about turbos, since this is my first car with one. So how ...
    Registered User TurboKimchi's Avatar
    May 2009
    Colorado
    Ok, so then I have alot to learn about turbos, since this is my first car with one. So how about a bov? Are they ok to get? Ive heard from many wrx owners that its not a good thing to get for this car. LOL but man do I love the sound of it!!!
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    "2002MY WRX TURBO COOL DOWN PROCEDURE
    FHI's position regarding this is that it is not necessary to perform a "cool down/idling" procedure, as was recommended with past turbo models. Our current 2.0L turbo engine has a far greater cooling capacity and, coupled with technology advances, makes this practice no longer necessary. This explains why information about cool down is not included in the 2002MY Impreza Owner's Manual.
    The heat contained in the turbo charger will begin to vaporize the coolant at the turbo charger after the engine is stopped. This hot vapor will then enter the coolant reservoir tank which is the highest point of the coolant system. At the same time the vapor exits the turbo charger, coolant supplied from the right bank cylinder head flows into the turbo. This action cools the turbo charger down. This process will continue until the vaporizing action in the turbo charger has stopped or cooled down."
    YOU DON'T NEED A COOL DOWN PERIOD OR TURBO TIMER!!
    A Turbo Timer is designed to keep the OIL from cooking inside of an oil cooled turbo. We don't have an oil cooled turbo. It's oil lubricated, and water cooled. If you're having second thoughts.. re-read my above post.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    May 2007
    orlando flawduh
    Quote Originally Posted by TurboKimchi View Post
    time out! stop & start from ground zero before you touch your car at all.
    read these:
    Unabomber's Manifesto - NASIOC
    Engine Performance FAQ [[[READ ME]]]
    Yes, you need an EM for engine mods
    http://www.clubwrx.net/forums/engine...ov-thread.html
    and after you're done & know your car like the back of your hand- THEN you can start modding.
    subarus are picky picky picky.
    desiree
  6. #19
    Nov 2006
    Denver Metro Area
    TurboKimchi... Just noticed you're local...
    Give me a PM on here, or IM on AIM, and I'd be glad to meet up for a burger, and show you around your car, and help you out a bit.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  7. #20
    Moderator Donkey's Avatar
    Da boonies,Va
    Not to mention our cars also have a factory oil cooler as well which aids in reduced engine and turbo wear and tear.
    2002 FORESTER S
    1998 FORESTER S
  8. #21
    Jun 2009
    So our turbos are water cooled? even in the 09 WRX?
  9. #22
    The turbos are all water cooled. It is becoming more and more difficult to find turbos that are not water cooled.
  10. #23
    Registered User Impreza2.0's Avatar
    Nov 2008
    Maine
    I considered a timer for it's other available options, like air/fuel ratio, digital tachometer, top speed recording, shift light, etc.... things that are available on a couple of models, and they are $100 or less. Some are offerred with harness on eBay at that price.
    I finally decided against it, because the A/F ratio is narrowband, tachs notoriously innacurate, shift light a total bork, therefore not useful...
    If Subaru had built a car in the last 6 years that died after 50k miles of driving, no one would like Imprezas, no one would buy them, and they would get laughed at all the time.
    Leave it stock, and change the oil, etc., and it can last a million miles if driven gently enough. It is unlikely, but it is not impossible. There are totally stock Imprezas in Maine (where I am), which have over a half million miles, I have seen this myself, and it is why I have mine.
    Mine won't make it that far without a lot of love, I have already done the damage we do.
  11. #24
    Registered User 03subiedude's Avatar
    Jul 2009
    somewhere in the nowhere of somethings mind eye of a nothing
    yes u dont need a turbo timer, did i get one yes. y? cause wen im the highway or a long drive i dont want to sit there 'just in case' i rather get out wit no worries. so plz no s**t for it.
    i got an apex'i for 80 bucks and it came with the harness...
    "if you want peace, prepare for war", latin proverb and common sense
    "Why do penguins take smoke breaks?"
  12. #25
    Dec 2003
    Dallas, TX / Sterling, VA
    Quote Originally Posted by 03subiedude View Post
    You wasted your money if that's why you got one. You don't need to sit on the car for it to cool down after a steady highway drive on the behalf on the turbo. Why? Your turbo isn't scolding hot. The only time you would legitimately have to is if you just did 5 laps at Infineon or Buttonwillow.
    Quote Originally Posted by Nyccandyman View Post
    No turbocharged, non-exotic car has come stock with an oil-only cooled turbo since the mid 90s.
  13. #26
    Nov 2006
    Denver Metro Area
    Even aftermarket ones.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  14. #27
    Nov 2008
    Maine
    If a cool turbo is something you are really concerned with, there are nice heat shields out there, you can upgrade the oil/coolant lines to stainless braided ones, the coolant tank can be replaced with billet, and if you have time and the desire, you can pull the turbo out and polish it. The polishing won't make a major difference, but having it completely clean will help if it is presently dirty at all. It is remarkable that a clean engine does run several degrees cooler than a dirty one.
    For the same money as a good turbo timer costs, you can do all of the above and probably have a few dollars left over. Heat shield -$50, braided lines -$40, cleaning -$0-20.
    Cusco is about to send out it's turbo heat shields to several vendors who are backordered, it is a good time to get your orders in.
    It is not seen as often, does not add lights and beeps to the interior, but years from now a shield will possibly prevent a labor charge and parts replacement. A turbo timer will only add to the likelyhood of having to go back and do some sort of re-do...
    Cobb has a nicely made heat shield also... as does SPT, and Nasioc has a nice DIY for around $20-30. Along with this, if you have a short ram intake, you can build or buy a heat shield for it which can divert some heat from that area also, while keeping the intake charge air slightly cooler (not so important, but looks pretty nice).
    Good luck on this, our (OEM) turbos are quite good for their longevity and cool operation. I doubt there is any real cause for concern.
    Our primary heat issue is heat-soaked intercoolers. There are many fixes for it, and it is wise to do at least one. The heat-soaked intercooler can cause Cyl 3 plug fouling, and a few other issues. A search will quickly show you the other problems that this creates. Sprayers, aftermarket TMICs, inlet and coupling upgrades, FMIC kits, etc., are all methods tried and true for helping with this.
    Ultimately, the turbo timer is a gadget, like a dashboard-mounted clock. It redundantly performs a task which is already being adequately handled by other accessories (any aftermarket radio with a digital display will have a clock).
    Not sure if this is similar to the "Big BOV Thread", where all BOV questions are repeated over time... I do not want to offend anyone, and I do hope that my information is accurate.
  15. #28
    Nov 2006
    Denver Metro Area
    SPT heat shield isn't a turbo heat shield. It's an intercooler heatshield that works in conjunction with a stock size turbo heat shield. (Works fine with my cobb). It's mostly bling, and may actually hurt the performance of the IC because it catches the heat and conducts it through to the intercooler end tanks. That's never been proven one way or another to my knowledge.
    All that you mentioned are upgrades that IMO aren't worth their weight in gold. There is no need to upgrade coolant lines on a stock turbo, the stock turbo heatshield is better than any aftermarket... it just doesn't fit most aftermarket downpipes... and how're you going to "Clean" the turbo?
    The Cylinder issue you're referring to isn't from a heat-soaked intercooler. The back right cyl is the closest to the turbo... with a large turbo that is not blanketed, or even a small one without the heatshield... the cylinder's EGTs can get to temperatures that are high enough to melt some plugs, and cause other issues.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  16. #29
    Apr 2009
    Wisconsin
    nice
  17. #30
    Dec 2003
    The Cobb piece is the same thing. It's an engine dress up item, not a functional shield.
