03 won't take gas
Results 1 to 14 of 14
This is a discussion on 03 won't take gas within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I posted a few months back about my 03 WRX not taking gas normally. It acts likes it full when ...
    Oct 2008
    03 won't take gas
    I posted a few months back about my 03 WRX not taking gas normally. It acts likes it full when I know it's not and the pump keeps shutting off if I do more than just trickle gas in it. The replies I got were very helpful and I think I have the problem narrowed down to a plugged filler neck. Does anyone know if I have to remove the gas tank to replace the filler neck? Any help would be much appreciated.
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Yes you do, because you can't do it from the top and I would take it apart regardless.... Might have more crap in there than you think.
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Registered User CJ05's Avatar
    Apr 2008
    North Juarez Mexico (aka El Paso TX)
    i'm having the same issue with my 02. Does anyone know how much it will cost to have this problem taken care of at the dealership or a mechanic? I don't have the space nor the time to look into the issue myself.
    Bugeye Mafia #231 - 2002 WRB - sold Dec 31, 2009
    -Stink-Eye Mob-#173 - 2008 SWP - Returned to TD04 Stage 2 in Jan 2012
    Frmr Blobeye Syndicate #173 - 2005 CGM -sold Sept 15, 2008. I miss my STi
    Proud owner of 99 RS coupe with EJ205 engine and tranny swap.
    May 2007
    Delaware
    My 04 hasnt been taking as much gas as it normally does during these cold months, Its like less ~1 to 2 gallons or so. any ideas?
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    broken gas pump
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Registered User 2:43AM's Avatar
    Sep 2008
    NWI
    Quote Originally Posted by JHAM View Post
    ... I think I have the problem narrowed down to a plugged filler neck. Does anyone know if I have to remove the gas tank to replace the filler neck?
    Come on. What the hell could it be plugged with?!? You try a different pump...different gas station? Pull the nozzle out just a tad and then try it.
    Jul 2008
    San Antonio
    Quote Originally Posted by 2:43AM View Post
    Have you no enemies ?
    N-swinger
    2000 Escort
    Sep 2008
    NWI
    Quote Originally Posted by pzr2874 View Post
    Have you no enemies?
    Not yet. Believe me, my comments aren't nearly as bad as some.
    I would like to know how this one turns out, but the OP probably will never reply back. If his filler neck is clogged, he's pumping some sh*tty gas, filled with water, rust, etc. But the big stuff should have been filtered by the pump beforehand. If anything, his vent tube may be clogged with ice. That's why I said pull the nozzle out a bit and try again. That will open up the neck to relieve some pressure. EPA doesn't like that but oh well.
    Apr 2008
    ^^^ i have the same issues^^^ and i can safely say it's not the pump. Unless i have the rotten luck of pickin every s****y pump from Klamath Falls OR to El Paso TX. (Fred Meyer, Chevron, Shell, and Valero) I've used the same pumps here in E.P. to fill my 08 with no issues. Temperature can't be an issue. It does it at 15 as well as 65. Slightly pulling the nozzle out does remedy the issue either. It's something i can live with but a real PITA, especially if you go places where they pump the gas for you i.e.... Oregon.
    Jul 2008
    San Antonio
    Call the dealer to see if they had/have a TSB or recall on yur model....
    N-swinger
    2000 Escort
    Registered User roadtrip1098's Avatar
    Jul 2008
    Winslow, Maine
    I had the exact same problem with my 08, it was a faulty air vent valve in the filler neck. It took the shop about 15 minutes to fix. 2:43 AM is most likely correct.
    http://www.cardomain.com/ride/3801103
    2008 WRX 4 door, Access Port, Short Shifter, Megan Racing adjustable coilovers, Strut Bar, Perrin DP, Magnaflow CBE, CAI, AVO 380 Turbo, AVO TMIC, Stage 3 Rallitek Tune More to come....
    Oct 2008
    I still haven't got it fixed. My mechanic verified the filler neck is clear. I spoke with a mechanic at the Subaru dealership; he said there is some kind of emission solenoid between the filler neck and tank. He seems to think that the solenoid being stuck is the problem. I hate to take it to a dealership mechanic cause I know they are going to bend me over with the labor $$$. I don't think I have much of a choice though. Why in the hell would any vehicle manufacturer put something on a car that would prevent it from taking gas?
    Sep 2008
    NWI
    It's all emissions-related bullsh*t. Thank big Gov and the EPA, though they mean well.
    It's not that the device preventing you from filling the tank, but fuel vapors are either siphoned out while you pump to either a) the pump itself (if equipment with vapor-return hose) or b) into a charcoal container near the gas tank (if equipped, but I think all cars are). Air flow out of the tank while you fill the tank rapidly is not escaping fast enough, thus shutting off the pump. That's my guess anyway. A clogged filler neck most likely would have caused an overflow, spilling gas onto your shoes!
    Registered User habitatxskate's Avatar
    Jun 2008
    it happens to me sometimes, if you flip the nozzle it works usually.. idk its just a pain but whenever it does do it, it drive me a little
