Helllllllllllp!
Results 1 to 10 of 10
This is a discussion on Helllllllllllp! within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I just bought my second Subaru (02 WRX) with 84k and had to get it emmisions inspected for DMV, and ...
    Registered User willXedge's Avatar
    Dec 2008
    Virginia
    Helllllllllllp!
    I just bought my second Subaru (02 WRX) with 84k and had to get it emmisions inspected for DMV, and it failed.
    3 cylinders are misfiring and I believe it's the camshaft sensor. How do I know for sure without paying $80 for a diagnostics test?
    Dec 2007
    go to autozone and ask them to do a diognostic test, they'll scan it for free. do u have a check engine light?
    Dec 2008
    Virginia
    Yeah I do.
    I've also noticed it seems to be running a bit rich.
    I'm not sure if this has anything to do with the problem, but I have a fuel ratio gauge and all it does is freak out 24/7.
    And thanks for that tip!
    I didn't know Autozone did that.
    Registered User Truckster27's Avatar
    Mar 2006
    Everywhere
    Like what was said, have autozone do a diag. test and tell you what error codes you have in the ECU. Also, if its a narrow-band AFR gauge (meaning its tied electrically to your stock O2 Sensor instead of wired directly to an independent O2 sensor in your exhaust). Then it's a light show. Normal (narrow-band) AFR's work on 0-1 volts. The changes make it jump all over. A wide-band AFR works on 0-5 volts, and will give you a much steadier, more accurate #. Why put in the crappier one? Because it costs $60, while the real deal is $200...a good check is when you are criusing at a steady speed (no boost, in vaccum) what does it read? If its in the neighborhood of 14-14.9, you're at stoich, that's okay.
    Tell us what error codes you come up with..
    Movn' on up to an '06 WRX
    Vf-39 all the way!
    Love to build 'em, just to ship 'em out and start all over!
    I got friends in cyberspace, so I must be cool, right?
    Facebook / Myspace
    Dec 2008
    Virginia
    I just went by Autozone, and the code i got was E0340.
    Mar 2006
    Everywhere
    Well, first off, I hope that he meant to use a "P" designation instead of an "E". Might just be the scanner he used...in any rate, here's a comprehensive list that i have of the SUBARU WRX codes. Notice the one in RED. Looks like you might have properly assessed your issue:
    COMPREHENSIVE WRX CODE LIST:
    P0011 A Camshaft Position System Performance (Bank 1)
    P0021 A Camshaft Position System Performance (Bank 2)
    P0026 OSV Solenoid Valve L Malfunction
    P0028 OSV Solenoid Valve L Malfunction
    P0030 O2 Sensor Heater Circuit Range/Performance Bank 1 Sensor 1
    P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
    P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
    P0034 Turbo Charger Bypass Valve Control Circuit Low
    P0035 Turbo Charger Bypass Valve Control Circuit High
    P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
    P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
    P0043 HO2S Heater Control Circuit Low Bank 1 Sensor 3
    P0044 H02S Heater Control Circuit High Bank 1 Sensor 3
    P0050 O2 Sensor Heater Circuit Range/Performance Bank 2 Sensor 1
    P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
    P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
    P0057 HO2S Heater Control Circuit Low Bank 2 Sensor 2
    P0058 HO2S Heater Control Circuit High Bank 2 Sensor 2
    P0063 HO2S Heater Control Circuit Low Bank 2 Sensor 3
    P0064 HO2S Heater Control Circuit High Bank 2 Sensor 3
    P0065 Air Assisted Injector Control Range/Performance
    P0066 Air Assisted Injector Control Circuit or Circuit Low
    P0067 Air Assisted Injector Control Circuit High
    P0068 Manifold Pressure Sensor Range/Performance
    P0076 OSV Solenoid Valve L Circuit Malfunction Low
    P0077 OSV Solenoid Valve L Circuit Malfunction High
    P0082 OSV Solenoid Valve L Circuit Malfunction Low
    P0083 OSV Solenoid Valve L Circuit Malfunction High
    P0101 Mass air flow sensor circuit range/performance problem (high input)
    P0101 Mass or Volume Air Flow Circuit Range Performance
    P0102 Mass air flow sensor circuit low input
    P0103 Mass air flow sensor circuit high input
    P0106 Manifold Pressure Sensor Circuit Range/Performance Problem (Low)
    P0106 Pressure sensor circuit range/performance problem (low input)
    P0107 Manifold Pressure Sensor Circuit Malfunction (Low Input)
    P0107 Pressure sensor circuit low input
    P0108 Manifold Pressure Sensor Circuit Malfunction (High Input)
    P0108 Pressure sensor circuit high input
    P0111 Intake Air Temperature Sensor Range/Performance Problem
    P0112 Intake Air Temperature Sensor Circuit Malfunction (Low Input)
    P0113 Intake Air Temperature Sensor Circuit Malfunction (High Input)
    P0117 Engine coolant temperature sensor circuit low input
    P0118 Engine coolant temperature sensor circuit high input
    P0121 Throttle position sensor circuit range/performance problem (high input)
    P0122 Throttle position sensor circuit low input
    P0123 Throttle position sensor circuit high input
    P0125 Insufficient coolant temperature for closed loop fuel control
    P0128 Coolant Thermostat
    P0129 Atmospheric Pressure Sensor Range/Performance
    P0130 O2 Sensor Circuit (Bank 1 Sensor 1)
    P0130 O2 Sensor Circuit (Lean) (Bank 1 Sensor 2)
    P0130 O2 Sensor Circuit Bank 1 Sensor 1
    P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134 O2 Sensor Circuit Open Bank 1 Sensor 1
    P0135 O2 Sensor Heater Circuit (Bank 1 Sensor 1)
    P0136 O2 Sensor Circuit (Bank 1 Sensor 2)
    P0137 O2 Sensor Circuit Low Voltage Bank 1 Sensor 2
    P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit (Bank 1 Sensor 2)
    P0142 O2 Sensor Circuit Bank 1 Sensor 3
    P0143 O2 Sensor Circuit Low Voltage Bank 1 Sensor 3
    P0144 O2 Sensor Circuit High Voltage Bank 1 Sensor 3
    P0145 O2 Sensor Circuit Slow Response Bank 1 Sensor 3
    P0150 O2 Sensor Circuit Bank 2 Sensor 1
    P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154 O2 Sensor Circuit Open Bank 2 Sensor 1
    P0156 O2 Sensor Circuit Bank 2 Sensor 2
    P0157 O2 Sensor Circuit Low Voltage Bank 2 Sensor 2
    P0158 O2 Sensor Circuit High Voltage Bank 2 Sensor 2
    P0159 O2 Sensor Circuit Slow Response Bank 2 Sensor 2
    P0162 O2 Sensor Circuit Bank 2 Sensor 3
    P0165 O2 Sensor Circuit Slow Response Bank 2 Sensor 3
    P0170 Fuel Trim (Bank 1)
    P0171 System Too Lean (Bank 1)
    P0172 System Too Rich (Bank 1)
    P0174 System Too Lean (Bank 2)
    P0175 System Too Rich (Bank 2)
    P0181 Fuel Temperature Sensor A Performance Problem
    P0182 Fuel Temperature Sensor A Circuit Low Input
    P0183 Fuel Temperature Sensor A Circuit High Input
    P0196 Oil Temperature Sensor Circuit Range/Performance Problem
    P0197 Oil Temperature Sensor Circuit Malfunction Low
    P0198 Oil Temperature Sensor Circuit Malfunction High
    P0222 Throttle Position Sensor B Low Input
    P0223 Throttle Position Sensor B High Input
    P0230 Fuel Pump Controller
    P0244 Turbocharger Wastegate Solenoid A Range/Performance (High Input)
    P0245 Turbocharger Wastegate Solenoid A Low
    P0246 Turbocharger Wastegate Solenoid A High
    P0249 Turbocharger Wastegate Solenoid B Low
    P0250 Turbocharger Wastegate Solenoid B High
    P0261 Fuel Injector Circuit Low - #1
    P0264 Fuel Injector Circuit Low - #2
    P0267 Fuel Injector Circuit Low - #3
    P0270 Fuel Injector Circuit Low - #4
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0325 Knock Sensor 1 Circuit Malfunction
    P0327 Knock Sensor 1 Circuit Malfunction (Low Input)
    P0328 Knock Sensor 1 Circuit Malfunction (High Input)
    P0330 Knock Sensor 2 Circuit Malfunction
    P0332 Knock Sensor 2 Circuit Malfunction (Low Input)
    P0333 Knock Sensor 2 Circuit Malfunction (High Input)
    P0335 Crankshaft position sensor circuit malfunction
    P0336 Crankshaft position sensor circuit range/performance problem
    P0340 Camshaft position sensor circuit malfunction
    P0341 Camshaft position sensor circuit range/performance problem
    P0345 Camshaft Position Sensor A Circuit Bank 2
    P0350 Ignition coil primary/secondary circuit
    P0365 Camshaft Position Sensor B Circuit (Bank 1)
    P0390 Camshaft Position Sensor B Circuit (Bank 2)
    P0400 EGR System
    P0420 Catalyst System Efficiency Below Threshold
    P0442 EVAP Control System Leak Detected (Small Leak)
    P0444 Canister Purge Control Solenoid Valve Circuit Low
    P0445 Canister Purge Control Solenoid Valve Circuit High
    P0447 EVAP Control System Vent Control Circuit Open
    P0448 EVAP Control System Vent Control Circuit Short
    P0451 Fuel Tank Pressure Sensor Performance Problem
    P0452 Fuel Tank Pressure Sensor Circuit Low Input
    P0453 Fuel Tank Pressure Sensor Circuit High Input
    P0456 EVAP Control System Leak Detected (Very Small Leak)
    P0457 EVAP Control System Leak Detected (Fuel Cap Loose/Off)
    P0458 Canister Purge Control Solenoid Valve Circuit Low
    P0459 Canister Purge Control Solenoid Valve Circuit High
    P0461 Fuel level sensor circuit range/performance problem
    P0462 Fuel level sensor circuit low input
    P0463 Fuel level sensor circuit high input
    P0464 Fuel level sensor intermittent input
    P0480 Cooling Fan Relay 1 Circuit Low
    P0483 Cooling Fan Rationality Check Malfunction
    P0500 Vehicle speed sensor malfunction
    P0501 Vehicle Speed Sensor Malfunction at Low Speed
    P0502 Vehicle Speed Sensor Low Speed
    P0503 Vehicle Speed Sensor High Speed
    P0506 Idle Control System RPM Lower than Expected
    P0507 Idle Control System RPM Higher than Expected
    P0508 Idle Control System Circuit Low
    P0509 Idle Control System Circuit High
    P0512 Starter switch circuit high input
    P0513 Incorrect Immobilizer Key
    P0519 Idle Control System Malfunction (Fail-Safe)
    P0545 Exhaust Gas Temperature Sensor Circuit Malfunction (Low Input)
    P0546 Exhaust Gas Temperature Sensor Circuit Malfunction (High Input)
    Vf-39 all the way!
    Facebook / Myspace
    Mar 2006
    Everywhere
    P0558 Alternator Circuit Low
    P0559 Alternator Circuit High
    P0562 System Voltage Low
    P0563 System Voltage High
    P0565 Cruise Control Set Signal
    P0579 Cruise Control Switch Circuit Range Performance Problem High Input
    P0600 Improper CAN Communication
    P0601 Internal control module memory check sum error
    P0604 Internal control module random access memory error
    P0605 Internal Control Module Read Only Memory Error
    P0607 Throttle Control System Circuit Range/Performance
    P0638 Throttle Control Circuit Range/Performance Problem
    P0641 Throttle Position Sensor A Power Supply Circuit
    P0661 Intake Manifold Tuning Valve Circuit Low
    P0662 Intake Manifold Tuning Valve Circuit High
    P0691 Cooling Fan Relay 1 Circuit Low
    P0692 Cooling Fan Relay 1 Circuit High
    P0700 Request AT MIL On
    P0703 Brake Switch Circuit Malfunction for AT
    P0703 Brake Switch Circuit Range Performance Problem High Input
    P0705 AT Range Switch Circuit Malfunction
    P0710 ATF Temp. Sensor Circuit Malfunction
    P0712 ATF Temp Sensor Circuit Low
    P0713 ATF Temp Sensor Circuit High
    P0715 Torque Converter Turbine Speed Signal Circuit Malfunction
    P0716 Torque Converter Turbine Speed Signal Circuit Malfunction
    P0719 Brake Switch Circuit Low
    P0720 AT Vehicle Speed Sensor Circuit High
    P0720 AT Vehicle Speed Sensor Circuit Malfunction
    P0722 AT Vehicle Speed Sensor Circuit Low
    P0724 Brake Switch Circuit High
    P0725 Engine Speed Input Circuit Malfunction
    P0726 Engine Speed Input Circuit Malfunction
    P0731 Gear 1 Incorrect Ratio
    P0732 Gear 2 Incorrect Ratio
    P0733 Gear 3 Incorrect Ratio
    P0734 Gear 4 Incorrect Ratio
    P0735 Gear 5 Incorrect Ratio
    P0736 Reverse Incorrect Ratio
    P0741 Torque Converter Clutch Circuit Malfunction
    P0743 Torque Converter Clutch Circuit Electrical (Duty Sol. B)
    P0748 Pressure Control Solenoid Electrical (Duty Sol. A)
    P0751 Shift Solenoid A Malfunction
    P0753 Shift Solenoid A Electrical
    P0756 Shift Solenoid B Malfunction
    P0758 Shift Solenoid B Electrical
    P0761 Shift Solenoid C Malfunction
    P0763 Shift Solenoid C Electrical
    P0766 Shift Solenoid D Malfunction
    P0768 Shift Solenoid D Electrical
    P0771 AT Low Clutch Timing Solenoid Valve Circuit Malfunction
    P0771 Shift Solenoid E Malfunction
    P0773 Shift Solenoid E Electrical
    P0778 AT 2–4 Brake Pressure Solenoid Valve Circuit Malfunction
    P0785 AT 2–4 Brake Timing Solenoid Valve Circuit Malfunction
    P0801 Reverse Inhibit Control Circuit
    P0817 PN Signal Output Circuit
    P0851 Neutral Switch Input Circuit Low
    P0852 Neutral Switch Input Circuit High
    P0864 TCM Communication Circuit Range/Performance
    P0865 TCM Communication Circuit Low
    P0866 TCM Communication Circuit High
    P0880 PIVGN Power Supply Circuit
    P0882 PIVGN Power Supply Low
    P0883 PIVGN Power Supply High
    P0955 Backup Lamp Relay Output Open
    P0957 Backup Lamp Relay Output Low
    P0958 Backup Lamp Relay Output High
    P1026 VVL Systems 1 Performance
    P1028 VVL Systems 2 Performance
    P1086 Tumble Generated Valve Position Sensor 2 Circuit Low
    P1087 Tumble Generated Valve Position Sensor 2 Circuit High
    P1088 Tumble Generated Valve Position Sensor 1 Circuit Low
    P1089 Tumble Generated Valve Position Sensor 1 Circuit High
    P1090 Tumble Generated Valve System 1 (Valve Open)
    P1091 Tumble Generated Valve System 1 (Valve Close)
    P1092 Tumble Generated Valve System 2 (Valve Open)
    P1093 Tumble Generated Valve System 2 (Valve Close)
    P1094 Tumble Generated Valve Signal 1 Circuit Malfunction (Open)
    P1094 Tumble Generated Valve Signal 2 Circuit Malfunction (Open)
    P1095 Tumble Generated Valve Signal 1 Circuit Malfunction (Short)
    P1097 Tumble Generated Valve Signal 2 Circuit Malfunction (Short)
    P1102 Pressure Sources Switching Sol. Valve Circuit Low
    P1110 Atmospheric Pressure Sensor Circuit Malfunction (Low Input)
    P1111 Atmospheric Pressure Sensor Circuit Malfunction (High Input)
    P1112 Atmospheric Pressure Sensor Circuit Range/Performance
    P1122 Pressure Sources Switching Sol. Valve Circuit High
    P1130 O2 Sensor Circuit (Open) (Bank 1 Sensor 1)
    P1131 O2 Sensor Circuit (Short) (Bank 1 Sensor 1)
    P1134 A/F Sensor Micro-Computer Problem
    P1135 O2 Sensor Circuit (Open) (Bank 2 Sensor 1)
    P1136 O2 Sensor Circuit (Short) (Bank 2 Sensor 1)
    P1137 O2 Sensor Circuit (Lambda=1) (Bank 1 Sensor 1)
    P1137 O2 Sensor Circuit (Mid) (Bank 1 Sensor 1)
    P1139 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1)
    P1140 O2 Sensor Heater Circuit Range/Performance (Bank 2 Sensor 1)
    P1141 Mass air flow sensor circuit range/perfomance problem (low input)
    P1142 Throttle position sensor circuit range/performance problem (low input)
    P1143 Pressure sensor circuit range/performance (low)
    P1144 Pressure sensor circuit range/performance (high)
    P1146 Manifold Pressure Sensor Circuit Range/Performance Problem
    P1152 O2 Sensor Circuit Range/Performance (Low) Bank 1 Sensor 1
    P1153 O2 Sensor Circuit Range/Performance (High) Bank 1 Sensor 1
    P1154 O2 Sensor Circuit Range/Performance (Low) Bank 2 Sensor 1
    P1155 O2 Sensor Circuit Range/Performance (High) Bank 2 Sensor 1
    P1160 Return Spring Failure
    P1199 Differential Pressure Sensor
    P1230 Fuel Pump Controller
    P1235 Intake Control Valve Solenoid Circuit Low
    P1236 Intake Control Valve Solenoid Circuit High
    P1237 Exhaust Control Valve Solenoid Circuit Low (Positive Pressure)
    P1238 Exhaust Control Valve Solenoid Circuit High (Positive Pressure)
    P1239 Exhaust Control Valve Solenoid Circuit Low (Negative Pressure)
    P1240 Exhaust Control Valve Solenoid Circuit High (Negative Pressure)
    P1241 2 Stage Twin Turbo System (Single)
    P1242 2 Stage Twin Turbo System (Twin)
    P1244 Turbocharger Wastegate Solenoid A Range/Performance (Low Input)
    P1245 Turbocharger Wastegate Solenoid A Range/Performance (fail-safe)
    Vf-39 all the way!
    Facebook / Myspace
    Mar 2006
    Everywhere
    P1247 Relief Valve Control Solenoid 1 Circuit Low
    P1248 Relief Valve Control Solenoid 1 Circuit High
    P1249 Relief Valve Control Solenoid 2 Circuit Low
    P1250 Relief Valve Control Solenoid 2 Circuit High
    P1282 PCV System Circuit (Open)
    P1301 Misfire Detected (High Temperature Exhaust Gas)
    P1306 OCV Solenoid Valve Signal 1 Circuit Malfunction (Open)
    P1307 OCV Solenoid Valve Signal 1 Circuit Malfunction (Short)
    P1308 OCV Solenoid Valve Signal 2 Circuit Malfunction (Open)
    P1309 OCV Solenoid Valve Signal 2 Circuit Malfunction (Short)
    P1312 Exhaust Gas Temperature Sensor Malfunction
    P1313 Misfire Detected Signal Circuit High Input
    P1314 Misfire Detected Signal Circuit Low Input
    P1400 Fuel Tank Pressure Control Solenoid Valve Circuit Low
    P1420 Fuel Tank Pressure Control Solenoid Valve Circuit High
    P1442 Fuel level sensor performance problem (travel distance)
    P1443 Vent Control Solenoid Valve Function Problem
    P1446 Fuel Tank Sensor Control Valve Circuit Low
    P1447 Fuel Tank Sensor Control Valve Circuit High
    P1448 Fuel Tank Sensor Control Valve Range/Performance
    P1475 Exhaust bypass valve solenoid Malfunction Low
    P1476 Exhaust bypass valve solenoid Malfunction High
    P1477 Exhaust bypass valve function
    P1480 Cooling Fan Relay 1 Circuit High
    P1491 Positive Crankcase Ventilation (Blow-by) Function Problem
    P1492 EGR Solenoid Valve Signal #1 Circuit Malfunction (Low Input)
    P1493 EGR Solenoid Valve Signal #1 Circuit Malfunction (High Input)
    P1494 EGR Solenoid Valve Signal #2 Circuit Malfunction (Low Input)
    P1495 EGR Solenoid Valve Signal #2 Circuit Malfunction (High Input)
    P1496 EGR Solenoid Valve Signal #3 Circuit Malfunction (Low Input)
    P1496 EGR Solenoid Valve Signal #4 Circuit Malfunction (Low Input)
    P1497 EGR Solenoid Valve Signal #3 Circuit Malfunction (High Input)
    P1497 EGR Solenoid Valve Signal #4 Circuit Malfunction (High Input)
    P1507 Idle Control System Malfunction (Fail-safe)
    P1510 ISC Solenoid Valve Signal #1 Circuit Malfunction (Low Input)
    P1511 ISC Solenoid Valve Signal #1 Circuit Malfunction (High Input)
    P1512 ISC Solenoid Valve Signal #2 Circuit Malfunction (Low Input)
    P1513 ISC Solenoid Valve Signal #2 Circuit Malfunction (High Input)
    P1514 ISC Solenoid Valve Signal #3 Circuit Malfunction (Low Input)
    P1515 ISC Solenoid Valve Signal #3 Circuit Malfunction (High Input)
    P1516 ISC Solenoid Valve Signal #4 Circuit Malfunction (Low Input)
    P1517 ISC Solenoid Valve Signal #4 Circuit Malfunction (High Input)
    P1518 Starter switch circuit low input
    P1521 Brake Switch Circuit Range Performance Problem High Input
    P1540 Vehicle speed sensor malfunction 2
    P1544 Exhaust Gas Temperature Too High
    P1547 Exhaust Gas Temperature Sensor Malfunction
    P1559 Air Intake System
    P1560 Back-up Voltage Circuit Malfunction
    P1570 Antenna
    P1571 Reference Code Incompatibility
    P1572 IMM Circuit Failure (Except Antenna Circuit)
    P1573 Communication Error (Time Over)
    P1574 Key Communication Failure
    P1576 EGI Control Module EEPROM
    P1577 IMM Control Module EEPROM
    P1590 Neutral Position Switch Circuit High Input for AT
    P1591 Neutral Position Switch Circuit Low Input for AT
    P1592 Neutral Position Switch Circuit Malfunction for MT
    P1593 TCM Communication Circuit Malfunction
    P1594 AT Diagnosis Input Signal Circuit Malfunction
    P1595 AT Diagnosis Input Signal Circuit Low Input
    P1596 AT Diagnosis Input Signal Circuit High Input
    P1597 TCS Signal Circuit Low Input
    P1598 TCS Signal Circuit High Input
    P1600 Improper CAN Communication
    P1601 Tranmission Ctrl Unit Comms Malfunction
    P1698 Engine Torque Control Cut Signal Circuit Malfunction (Low Input)
    P1699 Engine Torque Control Cut Signal Circuit Malfunction (High Input)
    P1700 Throttle Position Sensor Circuit Malfunction
    P1700 Throttle Position Sensor Circuit Malfunction for AT
    P1701 Cruise Control Set Signal Circuit Malfunction for AT
    P1703 AT Low Clutch Timing Solenoid Valve Circuit Malfunction
    P1706 AT Vehicle Speed Sensor Circuit Malfunction (rear wheel)
    P1707 AT AWD Solenoid Valve Circuit Malfunction
    P1708 Throttle Position Sensor Circuit Low Input
    P1709 Throttle Position Sensor Circuit High Input
    P1710 Torque Converter Turbine 2 Speed Signal Circuit Malfunction
    P1711 Engine Torque Control Signal #1 Circuit Malfunction
    P1712 Engine Torque Control Signal #2 Circuit Malfunction
    P1714 Throttle Position Sensor Power Supply Circuit
    P1716 ATF Temperature Sensor 2 Circuit Low
    P1717 ATF Temperature Sensor 2 Circuit High
    P1718 AT CAN Communication Circuit
    P1719 ECU Communication Circuit
    P1760 Lateral Acceleration Sensor Performance Problem
    P1761 Lateral Acceleration Sensor Circuit Low
    P1762 Lateral Acceleration Sensor Circuit High
    P1798 Gear 1 Engine Breaks
    P1799 Interlock
    P1817 Sports Mode Switch Circuit (Manual Switch)
    P1840 Transmission Fluid Pressue Sensor Switch A Circuit
    P1841 Transmission Fluid Pressue Sensor Switch B Circuit
    P1842 Transmission Fluid Pressue Sensor Switch C Circuit
    P1843 Transmission Fluid Pressue Sensor Switch D Circuit
    P1844 Transmission Fluid Pressue Sensor Switch E Circuit
    P1870 Front Left ABS Sensor Signal
    P1871 Front Right ABS Sensor Signal
    P1872 Rear Left ABS Sensor Signal
    P1873 Rear Right ABS Sensor Signal
    P1874 Circuit of R-Diff Oil Temp. Switch
    P1875 Circuit of Centre Differential
    P1876 Not Suitable Diameter Tyre
    P2088 OCV Solenoid Valve Signla A Circuit Open Bank 1
    P2089 OCV Solenoid Valve Signal A Circuit Short Bank 1
    P2090 OCV Solenoid Valve Signal B Circuit Open Bank 1
    P2091 OCV Solenoid Valve Signal B Circuit Short Bank 1
    P2092 OCV Solenoid Valve Signal A Circuit Open Bank 2
    P2093 OCV Solenoid Valve Signal A Circuit Short Bank 2
    P2094 OCV Solenoid Valve Signal B Circuit Open Bank 2
    P2095 OCV Solenoid Valve Signal B Circuit Short Bank 2
    P2098 Post Catalyst Fuel Trim System Too Lean Bank 2
    P2099 Post Catalyst Fuel Trim System Too Rich Bank 2
    P2100 Throttle Control Motor Circuit Open
    P2101 Throttle Control Motor Circuit Range/Performance
    P2102 Throttle Control Motor Circuit Low Input
    P2103 Throttle Control Motor Circuit High Input
    P2109 Throttle Angle Sensor Closed Position Error
    P2111 Throttle Valve Open Stick
    P2122 Accelerator Position Sensor D Low Input
    P2123 Accelerator Position Sensor D High Input
    P2127 Accelerator Position Sensor E Low Input
    P2128 Accelerator Position Sensor E High Input
    P2135 Throttle Position Sensor Circuit Range/Performance
    P2138 Accelerator Position Sensor Circuit Range/Performance
    P2707 Shift Solenoid F Malfunction
    P2709 Shift Solenoid F Electrical
    Vf-39 all the way!
    Facebook / Myspace
    Dec 2008
    Virginia
    Thanks man, what should my next step be?
    Mar 2006
    Everywhere
    Wow, took me a little long to respond
    I would say replace the sensor (if you haven't already)
    Vf-39 all the way!
    Facebook / Myspace
