acronym stuff
Results 1 to 6 of 6
This is a discussion on acronym stuff within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Definitely a good thread but I didn't see anything about the STi Version(s). I know from time to time people ...
    Banned Subie do's Avatar
    Apr 2006
    Seattle WA.
    Post acronym stuff
    I know from time to time people talk about doing ver. 7 engine swaps and adding ver. 5 wings. Now you can look like you know what their talking about.
    GC chassis 1992-2000
    STI Version(S), year, and chassis code(s):
    I: 1992-1994 GC8A/B
    II: 1995 GC8C
    III:1996 GC8D
    IV: 1997 GC8E
    V: 1998 GC8F
    VI: 1999 GC8G
    *all GC body style*
    New GD chassis 2001-now:
    Japan:
    REV:
    A 2001
    B 2002
    C 2003
    D 2004
    E 2005
    F 2006
    G 2007
    In USA that would be:
    VII 2002-2003
    VIII 2004-2005
    IX 2006-
    I'm pretty sure that's how it goes. Mods or anyone else jump in if I miss anything.
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Deleting threadjack. Please only post something in here if it's relevant to terminology and acronyms. Ask questions about Stages, etc, in a another thread, or in the tech forums.
    --Ray
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    Registered User LogiMech's Avatar
    Mar 2008
    the sticks, Colorado
    I just saw an acronym, and I have no idea unless I'm just missing the obvious.. TGV/ TGV's
    Admin - Scooby Hooligan
    Weasel 555's Avatar
    UK,NY,AK,FL
    Quote Originally Posted by LogiMech View Post
    TGV/TGV's = Tumble Generator Valve
    heres a nice write up:
    Subaru Manifold
    ScoobyDMC #000,HawkEyeAlliance#000,Blobeye Syndicate #000, SQC-NY #009, "Dragon Slayer"
    "All We'll Drive"
    Subaru Worldwide/Rallying: facebook.com/groups/subarumad/
    Administrator ...De Rerum Natura TheJ's Avatar
    Bro do you even live in the Dirty South
    Good Stuff! Added it.
    -The J 𒂼𒄄
    "Driving most supercars is like trying to manhandle a cow up a back staircase. . . This is like smearing honey into Keira Knightly" -JC
    Registered User Scout01's Avatar
    Jul 2008
    A, A
    Quote Originally Posted by YBNormal07 View Post
    If you have any to add, please post them in a reply and I'll add it to the list and delete your reply.
    However, DO NOT post asking about general internet terms/slang/acronyms. You simply need to google those to find your answers.
    NOTE: This thread is subject to regular pruning.
    Acronyms & Basic Terminology
    • 4EAT – Four Speed Electronic Automatic Transmission
    • 5MT – Five Speed Manual Transmission
    • 5EAT – Five Speed Electronic Automatic Transmission (includes Sportshift)
    • 6MT – Six Speed Manual Transmission
    • ABS – Anti-lock Braking System
    • AFR (or A/F) - Air to Fuel Ratio
    • ALK - Anti Lift Kit
    • ALS: Anti Lag System (EM trick to keep the turbo spooled when off the throttle)
    • AT – Automatic Transmission
    • ATDC = After Top Dead Center (relative to piston location)
    • ATF – Automatic Transmission Fluid
    • AutoX – Autocross
    • AVCS – Active Valve Control Sysem
    • AVLS – Active Valve Lift System
    • AWD – All Wheel Drive
    • AWHP - All Wheel Horse Power
    • BBK - Big Brake Kit
    • BHP – Brake HorsePower (measured BEFORE transmission)
    • BOV – Blow Off Valve
    • BPV - By-Pass Valve
    • BTDC - Before Top Dead Center (relative to piston location)
    • CAI – Cold Air Intake
    • Cat – Catalytic Convertor
    • Catback -- Catback (after the Catalytic Converter) exhaust section
    • CBE = Cat Back Exhaust
    • CEL – Check Engine Light
    • CF – Carbon Fiber
    • Cf -- drag coefficient or coefficient of drag (airflow resistance)
    • CO2 – Carbon Dioxide
    • Diff – Differential
    • DP -- Down Pipe
    • DC -- Double Clutch
    • DCCD -- Driver Controlled Center Differential
    • DOHC – Dual Overhead Camshaft
    • DRL = Daytime Running Lights
    • EBC – Electonic Boost Controller
    • ECT - Electronically Controlled Transmission
    • ECU – Electronic Control Unit (engine control unit)
    • EFI – Electronic Fuel Injection
    • EG – Subaru 6-cylinder engines (up through mid to late 90’s)
    • EG33 – Subaru 3.3 litre 6-cylinder engine code (SVX)
    • EGT - Exhaust Gas Temperature
    • EJ – Subaru 4-cylinder engines (early 90’s and newer)
    • EJ20 – Subaru 2.0 litre 4-cylinder engine code
    • EJ205 – Subaru 2.0 litre turbo engine (US WRX)
    • EJ22 – Subaru 2.2 litre 4-cylinder engine code
    • EJ25 – Subaru 2.5 litre 4-cylinder engine code
    • EJ255 – Subaru 2.5 litre turbo engine (US Forester XT, Baja Turbo)
    • EJ257 – Subaru 2.5 litre turbo engine (US WRX STi)
    • EM - Engine Management
    • EMS = Engine Management System
    • EWG - external wastegate
    • EZ – Subaru 6-cylinder engines (post EG series H6 engines)
    • EZ30R – Subaru 3.0 litre 6-cylinder engine code (BL/BP Legacy and new Outback)
    • FDR - Final Drive Ratio
    • FHI - Fuji Heavy Industries
    • FMIC – Front Mount Intercooler
    • FWD – Front Wheel Drive
    • FSB -- Front Sway Bar
    • H4 – Horizontally Opposed 4 cylinder (boxer)
    • H6 – Horizontally Opposed 6 cylinder
    • HF - High Flow (usually used in conjunction with a catalytic converter)
    • HID – High Intensity Discharge (headlights)
    • HT-- Heal and Toe
    • IC -- Intercooler
    • JDM – Japanese Domestic Market
    • LHD = Left Hand Drive
    • LSD – Limited Slip Differential
    • MAF or MAS – Mass Air-Flow Sensor
    • MAP – Manifold Absolute Pressure Sensor
    • MBC – Manual Boost Controller
    • MIL – Malfunction Indicator Lamp (CEL)
    • MT – Manual Transmission
    • MY – Model Year
    • NOS - Nitrous Oxide
    • OBD - On Board Diagnostics
    • OE – Original Equipment
    • OEM – Original Equipment Manufacturer
    • OL/CL - Open Loop / Closed Loop
    • Pinks --certain STI parts... springs, swaybars, injectors, timing belts. Due to their color.
    • Pot -- (ie. 4-pot brake) pistons on caliper.
    • P&P -- port and polish of cylinder heads to improve airflow.
    • PPG -- Pfitzner Performance Gearbox
    • RallyX – Rallycross
    • RHD = Right Hand Drive
    • RPM - Revolutions Per Minute
    • RSB -- Rear Sway Bar
    • RWD – Rear Wheel Drive
    • SOA – Subaru Of America
    • SOHC – Single Overhead Camshaft
    • SPT = Subaru Performance Tuning
    • SWRT = Subaru World Rally Team
    • STi (pre-06) / STI = Subaru Technica International
    • TDC = Top Dead Center (relative to piston location)
    • TMIC – Top Mount Intercooler
    • TBE -- Turbo Back Exhaust
    • TGV - Tumble Generator Valve
    • TR - Tuner Ready (aka '06 WRX TR)
    • TSB - Technical Service Bulletin
    • TT – Twin Turbo
    • UDP – Under Drive Pulley
    • UP -- Up Pipe
    • USDM -- United States Domestic Market
    • VDC – Vehicle Dynamic Control
    • VIN – Vehicle Identification Number
    • VTD – Variable Torque Distibution
    • WGA - wastegate actuator
    • WHP – Wheel HorsePower
    • WOT – Wide Open Throttle
    • WRB = World Rally Blue
    • WRC = World Rally Championship (competiton or WRC Spec cars)
    Impreza Bodies:
    • GF = 5-door Impreza body
    • GG = Impreza Wagon
    • GM = 2-door (old gen) Impreza body
    • GC = 4-door (old gen) Impreza body
    • 0 = 1.6L (not certain about this one)
    • 2 = 1.8L
    • 4 = 2.2L
    • 6 = 2.5L
    • 8 = 2.0L
    • GD = New Gen Bodies
    Thanks to:
    Uncle Meat of the Cobb Tuning WRXForum.com, LegacyGT Forum, XimportnWRX, MidKnight, Max, Jhokur, anukaoen, nofear6235
    This was pretty cool...
