launching the wrx
Results 1 to 7 of 7
This is a discussion on launching the wrx within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; best way to launch ur wrx any suggestions i let it out fast and smooth at about 5 grand let ...
    Registered User jcfuzzdog29's Avatar
    Nov 2007
    Paxinos, PA
    launching the wrx
    best way to launch ur wrx any suggestions i let it out fast and smooth at about 5 grand let me know if theres a better way
    May 2007
    orlando flawduh
    Launching Techniques? and How it fairs against competition?
    also, heres a writeup from another subaru forum
    "Being nice to your tranny and not out to launch
    There are two things you need to accomplish to get a good launch in the wrx.
    You need to launch under some boost,
    and you need to control the load on the engine so it stays near max torque rpm for the first few feet without banging the clutch and shock loading the drive train.
    There are several variations on the theme and each person will discribe it slightly differently but you want to engage the clutch quickly and smoothly so it slips just a bit with out just side stepping the clutch, or frying the clutch by holding it at partial engagement. The newer 2003 cars have a flow limit valve in the clutch line so you cannot just let up on the clutch and break things. It slows down the engagement just a bit. On the 2002's you'll have to do that yourself.
    One of the top WRX drag racers in the country describes the technique where you stage, and then let the clutch out a bit until you can tell it is just ready to engage (the friction point) is just a fraction of an inch away.
    Hold at a moderate fast rpm (everyone picks a slightly different number) I use about 3000 3500 rpm.
    Now comes the key to launching under boost.
    You can only build boost under no load conditions when the engine is accelerating at WOT .
    Just as the second yellow comes on, stomp the throttle to the floor from your stage rpm, the engine will take about a second to rev to red line. There is only .500 seconds between each of the yellow lights.
    Watch the tach and as the rpm swings by 5000-5500 rpm let up on the clutch quickly.
    (you can't wait for the green light you have to start leaving on the last yellow)
    Since you prepositioned the clutch right at the friction point there will be very little clutch motion, or shock, your engine will be very close to 5500 rpm when the clutch engages and under some boost because you floored the throttle a fraction of a second earlier. If you get all that coordinated you should have enough torque and energy stored in the flywheel so the engine does not bog.
    Hang on !!! you will be accelerating at over 1 G and hit red line in low in about 1.5 seconds.
    Be ready to shift !!!!!
    The biggest time loss that keeps folks at 2.x seconds is a slow shift, you have to shift quickly to get back under power in second gear before you complete the first 60'.
    Shift quickly and firmly but NOT VIOLENTLY !!! your not trying to break anything just be quick.
    I tell folks to hold the shifter in their fingers not to grab it like a club, this gives you more feel and makes you less inclined to try to rip the shift knob off the console.
    If you get it right its quite a ride."
    btw this doesnt belong in new member hang out =)
    desiree
    Nov 2007
    Paxinos, PA
    thats alot but i will have to practice that thanks man
  5. #4
    Registered User Littleguy's Avatar
    Jan 2004
    Houston, TX
    I'll have to try this too. I've been afraid to launch mine so far. thank you ma'am.
    2008 Satin White Pearl WRX Sedan
    SPT Springs, UR CAI, UR Catless DP, SPT Exhaust
  6. #5
    Sep 2011
    Katy
    /\ same
  7. #6
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Yeah, thanks Man!
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  8. #7
    Apr 2007
    8000' up in Colorado
    Quote Originally Posted by christiangordon View Post
    /\ same
    Nice bump of an almost 4 year old thread!
    Scott
