Cobb Ap Question for 06 WRX
Results 1 to 13 of 13
This is a discussion on Cobb Ap Question for 06 WRX within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I recently purchased this and I was wondering if the 06's needed an initialization connector? It seems I have everything ...
    Feb 2006
    I recently purchased this and I was wondering if the 06's needed an initialization connector? It seems I have everything except these connectors. Just wondering if these were needed to flash my ECU?
    Oct 2005
    California
    Don't you have a user's guide? I have an 05 and I do need the initialization connector (white connector) to flash my ECU. I don't know about the 06. Check out the manual.
    I might be back in the market for the new STI sedan!
    Feb 2006
    Yeah I got the manual....but it says 2002-2005. The Ap itself is for an 06.
    Registered User ansonowicz's Avatar
    Oct 2005
    LBC
    Quote Originally Posted by rayamana
    On my 06, it was just dangling in all it's glory under the steering column. it was tied to a white string.
    F4.21 have root access, will travel
    :wq! 6MT20G
    Quote Originally Posted by volcomsoldier19 View Post
    long haul, the wagon will give you happiness in the times of madness...
    Feb 2006
    Quote Originally Posted by ansonowicz
    So there was a connector that came with your Ap?
    Oct 2005
    California
    If you didn't receive that white connector, I suggest emailing or calling Cobb about it. There shouldn't be much of a difference between the 2005 and 2006, except maybe few revisions, but it should be the same process of reflashing.
    Oct 2005
    LBC
    The connector came with the WRX. It was tied underneath the steering column. Mine was specfically behind the "hood release" area.
    Good luck!
    :wq! 6MT20G
    Feb 2006
    Well it seems an initialization connector isn't needed for an 06. I just connected the two green connectors and flashed my ECU. Everything works fine now. I could really feel the difference from stock to stage 1.
    Oct 2004
    Westchester Cnty, NY
    Good luck!
    Are you sure you dont mean the green pieces that you put together to initate test mode?
    A white initlization connector should of came w/ your AP. I cant image the car doesnt require one anymore. Contact Cobb ASAP.
    2008 Satin White Pearl WRX Sedan w/ Navi
    2005 San Remo Red WRX Sedan w/ VF34 (traded)
    Pi Kappa Alpha | New England Flat 4
    Feb 2006
    Just verified with Cobb technical support: they said with 2.5L no initialization connectors are required.
    Oct 2004
    cool.
    Registered User The An$wer's Avatar
    Jan 2006
    Modesto, CA
    Had a quick question, did the cobb ecu make a noticable power difference?? Im looking to order it soon, but i just wana know if its worth the $645...
    Oct 2004
    Quote Originally Posted by The An$wer
    If you have an 02-05 then it makes about a 25whp difference, alone. Once you add parts and go up stages its infinite. I'm over 100whp more than stock using the Cobb AP.
    If you have an '06 they are saying that Stage 1 is pretty useless since its a 2.5L but just had an UP and TBE and your making amazing gains.
