the use of intercooler water sprayer
Results 1 to 15 of 15
This is a discussion on the use of intercooler water sprayer within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I'm going to hopefully be a 2005 sti owner and was just wondering how you use and when to use ...
    Sep 2005
    I'm going to hopefully be a 2005 sti owner and was just wondering how you use and when to use the intercooler sprayer. i know it cools the inter cooler but is it really that necessary? How often should you use it? is it something you need to refill everyday? any answers will help this noob a lot.
    thanks
    Mar 2002
    Calmer than you are
    the USDM sprayer is pretty useless. Its not meant for frequent use, and I believe that it uses water from you winshield washer bottle.
    the JDM version has a 12L resevoir in the trunk and works at much higher pressures.
    go f*** yourself
    Registered User ILikeMy2.5RS's Avatar
    May 2003
    Lowell, MA
    The STI's water tank for the ic is actually in the trunk.
    Registered User rallymaniac's Avatar
    Nov 2003
    Special Stage
    Quote Originally Posted by ILikeMy2.5RS
    Blarg, you n00b
    Straights are for fast cars...
    Turns are for fast drivers...
    Colin McRae
    My PHOTOGRAPHY
    Mar 2002
    Calmer than you are
    I stand corrected. well technically I RECLINE corrected. Is this a new development? Did they USED to use the same resevior as the windshield?
    go f*** yourself
    May 2003
    Lowell, MA
    I'm not positive but I don't think that it's windshield washer fluid. I'm fairly certain its just water.
    Apr 2004
    Southeastern PA
    I guy I work with has an 04 STi. 04+ USDM has always been in the trunk. I do not think he ever uses it - I'll ask tomorrow. The owners manual says not to use washer fluid.
    Mods & Pics
    Mar 2002
    Calmer than you are
    I've seen people use it before...but its possible that they were putting windshield fluid in the other resevior....because it evaporates faster and leaves your intercooler squeaky clean.
    of course the reason it evaporates faster is because it takes less energy to vaporize it...but that's just science stuff...we don't really get into that.
    I'm working on a really really complex intercooler sprayer that WILL actually be usefull...bleah...now if god910 would just hurry up with that tank he's making.....
    go f*** yourself
    Sep 2005
    Australia
    You dont put washer fluid in the water spray resevoir...
    Maybe add some alcohol base fluid like metho or isopropyl to the water...
    the STI setup is cheap n nasty with lil plastic nozzles...
    May 2005
    North Cali
    just incase you get thirsty
    10" Nike
    Mods- Gel Pad, Shoe Cleaner
    Scooby Dooby Doo
    Registered User racerWRX's Avatar
    Jun 2002
    steeltown
    its like the water/flower trick......open up the hood and get someone to check the i.c. for you and......blamo hit the sprayer.
    have you ever been 4 bagged ???
    Registered User WrxRick's Avatar
    Houston
    The Windshield spray IS different from the Intercooler Sprayer. They are both in seperate locations as well. The STi IC sprayer uses ONLY distilled and pure water. The container for it is in the trunk.
    when the turbo spins the bull**** ends
    My mods
    Registered User RHONE's Avatar
    Jun 2005
    whittier
    i installed one in my car, w/ a 2 gallon tank and a ford truck super pump window washer all mounted in the trunk, the switch is mounted next to the mirror adjuster in the extra hole. i run straight tap water in mine and it works good. i spray it all the time, my ic used to get way too hot to touch before, now the hottest it gets is warm with the fins still cool to the touch, when it is cool outside it just stays cold. i also have my ic at full tilt w/ the blarg mod, next will be the gauges so i know how good it really works. if you have one you might as well use it cooler air means a better running car right???
    Jul 2005
    Quote Originally Posted by RHONE
    Cooler air means more oxygen per cubic unit of input gas, because the gas will be at a lower pressure. Cooler air is equivalent to running higher boost as both increase the molar oxygen content per unit of input gas.
    Quote Originally Posted by mike05STi
    I'd love to have a tree house for adults in my backyard.
    Apr 2004
    Southeastern PA
    Quote Originally Posted by racerWRX
    Oh, that's good!
    Mods & Pics
