Yes it is. You should be pretty much stopped before putting it into 1st.
This is a discussion on It hurts to downshift into 1st gear. within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; When I downshift into 1st gear I get this grinding noise, of course I have the clutch in. Only when ...
When I downshift into 1st gear I get this grinding noise, of course I have the clutch in. Only when I let the car slow down to about 10 mph or slower can I downshift smoothly. Is this normal?
btw, good to see some wrx owners in MN
i only downshift into 1st when i am at a complete stop....if you try downshift into 1st at a high speed you are forcing your tranny and scynros to make that shift and puttin unneccessary strain on them
05 STI![]()
Speed Comes At A Price...How Fast Can You Afford To Go?
If you want to shift into 1st at anything over 3-4mph, you'll need to rev the engine a bit to get it smoothly into gear. Heel-n-Toe!
Dino
- '03 WRX sedan - SOLD (Jan 07)
- '06 Infiniti G35 Coupe 6MT (Stock)
- '05 Volvo S60R - stock (Stock)
Originally Posted by TRex
no, heel and toe is braking while rev matching a downshift
you meant to say double clutching.
You are probably approcahing a stop and slowing down and braking if your downshifting to 1st from a roll. Thus you would use heel toe to rev match.Originally Posted by Redline927
Double clutching is for tractor trailers and Fast and Furious fanbois.
No he meant Heel & Toe. You need be below 5mph to engage 1st gear so you would have to brake and rev to match everything up.Originally Posted by Redline927
Damnit Wizzman you beat me to it!!!!
2008 Satin White Pearl WRX Sedan w/ Navi
2005 San Remo Red WRX Sedan w/ VF34 (traded)
Pi Kappa Alpha | New England Flat 4
Don't forget almost every race car driver using a gearbox with dog cut gears (no synchros) as the layshaft will need to be spun up as well (rev'd while in neutral). Please don't make comments like this that you obviously have no idea about.Originally Posted by wizzman
Thanks,
Chris
Moderator: Retired
2002 Subaru Impreza WRX Sedan 5MT - Road Rally - Best 1/4mi: 13.954 @ 97.36mph (3448 lbs)
2001 Mazda Miata 5MT - AutoX #99 (NNJ Region SCCA 2005 CStock Champion)
1988 BMW 325 (2.7L "i" conversion) Sedan 5MT - Daily Driver (AutoX soon!)
"If you can't drive this car fast you can't drive fast." --British Magazine, CAR, on the WRX
Not to be a ****, and we have the same name so this is hard.Originally Posted by fengshui
but you basically made his point for him. You said that race cars that dont have synchros need to double clutch. he said tractor trailers, they use old gearboxes (im sure some dont now a days), but regular cars do not require double clutching.
the only reason people now a days talk about DCing is b/c they heard Vin Diesel talk about it in TF&TF
I can put it in first easy at 25mph to downshift.![]()
2009 Honda Accord Coupe EX-L Belize Blue Pearl
2000 Yamaha R6
10.123 At 131.9mph (Dyno Drags)
111.1hp@wheel
2002 Aspen White 5MT WRX - Sold
Without matching revs? You must have magic synchros!Originally Posted by adam3482p
Dino
actually, i do it a lot. it's great for downshifting, highway exits, and keeping pasengers heads from bouncing around the cabin whenever you downshift.Originally Posted by D0WNxSH1FT
dR
I swear they are magic!!!Originally Posted by TRex
Edit: I just went outside and tried it. It goes in easy at 25 downshifting to first. And I tried it once rev matching and put in at 30 no problem. I mean I know its the Ra gearset but damn!!!
2000 Yamaha R6
111.1hp@wheel
Are you sure you dont mean Heel/Toe rev matching?Originally Posted by dark_rex
