Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on It hurts to downshift into 1st gear. within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Originally Posted by D0WNxSH1FT Are you sure you dont mean Heel/Toe rev matching? Yeah, I'm curious to know how you ...
    Registered User TRex's Avatar
    Dec 2002
    Quote Originally Posted by D0WNxSH1FT
    Yeah, I'm curious to know how you are able to use double-clutching to help with 'head bobbing' (only good when you are on a date). I'll double-clutch sometimes when going from 2nd to 1st (when too lazy to heel-n-toe), but only cuz my synchros suck when cold.
    How does DC help smooth it out without H-n-T?
    Dino
    - '03 WRX sedan - SOLD (Jan 07)
    - '06 Infiniti G35 Coupe 6MT (Stock)
    - '05 Volvo S60R - stock (Stock)
  2. #17
    Moderator fengshui's Avatar
    New Jersey
    OK Lets just clarify this again to clear up the BS. There is rev matching by clutch-in-shift-rev-clutch-out, then there is clutch-in-shift to N-clutch out-rev-clutch in-shift-clutch out. The latter is called double clutching and doesn't wear your synchros as much as what most folks here are doing which is single clutch rev matching. If you just press and depress the clutch once, all you are doing is spinning the engine, but not the input/lay shafts of the transmission which are dropping once you begin shifting. Feel free to single clutch with modern synchro transmissions, but if you ever aspire to driving a racing transmission, I'd learn to double clutch when rev matching. Heel toe is just applying the brakes while rev matching. If it still doesn't make sense or to see it graphically, buy a book.
    -Chris
    Moderator: Retired
    2002 Subaru Impreza WRX Sedan 5MT - Road Rally - Best 1/4mi: 13.954 @ 97.36mph (3448 lbs)
    2001 Mazda Miata 5MT - AutoX #99 (NNJ Region SCCA 2005 CStock Champion)
    1988 BMW 325 (2.7L "i" conversion) Sedan 5MT - Daily Driver (AutoX soon!)
    "If you can't drive this car fast you can't drive fast." --British Magazine, CAR, on the WRX
  3. #18
    Registered User scottigee's Avatar
    Mar 2004
    Southern Cali
    fenshui is on point
    Just because you don't NEED to double clutch with today's transmissions doesn't mean that it ain't a good idea. In fact it's a great idea and it prolongs the life of your syncros. What's more it allows the 1st gear downsift that the syncros aren't shaped to handle.
    If you want to master the manual transmission you must learn to double clutch properly AND you must learn to heel toe downshift to optimize power and weight transfer while minimizing powertrain loss and wear.
    To downshift into first you should really be double clutching. That's what your syncros are telling you with that grinding noise.
    Pushin' a Honda but scoping the Scoobies.
  4. #19
    Registered User Redline927's Avatar
    Jun 2004
    New Jersey
    Quote Originally Posted by wizzman
    You are probably approcahing a stop and slowing down and braking if your downshifting to 1st from a roll. Thus you would use heel toe to rev match.
    Double clutching is for tractor trailers and Fast and Furious fanbois.
    ive gotten into the habit of double clutching when i want to drop down a gear...and i can do it just as fast as single clutching.If a passenger had ear plugs in, and were looking out the side window, they couldnt tell i downshifted...takes a lot off the synchros (given slightly more clutch wear over time maybe), but i recommend it. It is not just f&f and tractor trailors only....chris (fengshui) explained everything perfectly...what i meant by saying double clutching into first is just that...i do it if im rolling slowly and want to put it in first, most of the time the shifter wont fall into place easily unless i double clutch...if im rolling 5 mph and wanted to put it into first, i see no reason to put my foot on the brake (heel-toe), i would just double clutch.
    if you are talking from a race perspective and approaching a turn fast as crap and braking hard...yes, heel toe would be necessary.
    hope that clears some stuff up.
  5. #20
    Jun 2005
    South Dakota
    I don't have a WRX yet, but I learned to drive in a 49 Chevy pickup. No synchros. I only use a clutch when I'm stopped or when I'm doing a test drive and the salesman is in the car. I rev-match clutchless and it works on most cars and trucks I've driven unless the gear ratios are too far apart. Saves wear and tear on the throw-out bearing and clutch surfaces.
    I haven't tried it with a WRX yet because I don't want to be hard on a car I don't know, so please comment. Is it necessary to use the clutch in a WRX other than from a stop?
  6. #21
    Moderator timber's Avatar
    St. George, Ut.
    Quote Originally Posted by Marlon Elliott
    I would highly reccomend using the clutch, just because the tranny is the weak link in the WRX, and if you do miss a shift, there is a good chance something is gonna break. This is just my opinion tho..
    "Never Launched"
    Dougie
    - Founder, 250,000 mile club
    -5,000 posts
  7. #22
    Registered User IronMedic's Avatar
    Jan 2005
    Puyallup WA
    i get this burning sensation between my legs when i shift down to 1st, is that normal?!?!?!?
    2005 Nissan 350z roadster
    Originally Posted by BrianH
    I can hit 10K more posts before a neon R/T will hit 60mph.
  8. #23
    St. George, Ut.
    Quote Originally Posted by IronMedic
    Have you seen your doctor about that??
    "Never Launched"
    Dougie
    -5,000 posts
  9. #24
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Take your hand away from that!!! That is not the gear shift selector knob. A common noob mistake
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  10. #25
    Jan 2005
    Puyallup WA
    holy smokes!! i can shift into first now! and this whole time i thought it was the lube! muhahaha!
  11. #26
    Registered User book'em's Avatar
    Jul 2005
    Minneapolis, Minnesota
    I gotten that feeling before too. However, it's usually associated with female anatomy not downshifting.
  12. #27
    Jul 2003
    PA
    Quote Originally Posted by book'em
    wait..I'm confused...so you have "female anatomy" down there????
