Results 1 to 15 of 16
This is a discussion on How to get the turbo to spin up sooner within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Seems like the turbo doesnt get in to 2500-3000 rpm... any mods i can do to get the turbo to ...
    Jun 2005
    Seems like the turbo doesnt get in to 2500-3000 rpm... any mods i can do to get the turbo to spin up faster on 2005 wrx.
    Registered User br3ez's Avatar
    Apr 2004
    Bergen County, NJ / NEU, Boston
    if you do a search you will find that a simple up pipe and downpipe upgrade will significantly lower your amount of lag.
    2005 WRX
    UTEC Stage 2 (Catless)
    250.02 WHP
    249.27 WTQ
    Junior Tuned
    Registered User dviousboxer's Avatar
    Sep 2004
    FLORIDUH!
    catless uppipe will help you out alot
    " I'm a bad man"
    Registered User TurnWRX's Avatar
    May 2003
    CA
    Most turbo cars will take some time to spool up. 2.5k rpms in the lower gears and 3k rpms in the higher gears is normal for the wrx.
    Boba Fett BrianH's Avatar
    Oct 2003
    Kicking Babies
    Quote Originally Posted by valuepac
    go catless and get a custom tune.
    Jun 2005
    If i make some of these modification how much sooner will my turbo spin up..... also how hard is it to install a turbo gadge?
    Registered User racerWRX's Avatar
    Jun 2002
    steeltown
    just say no..............?????
    have you ever been 4 bagged ???
    Moderator
    Jul 2003
    Maryland
    Any decent mod at all will make a difference in spool time, but if you want to see a HUGE increase just drain and swap out your boost fluid.
    Registered User dingobite's Avatar
    Feb 2005
    ky, lou
    Sorry for tread jacking a little but was wondering do you guys with catless rides.
    How do you get your exhuast tested, ive read about this over in a bunch of post, but it only leaves me assuming you leave the TBE catless when its time to get tested ?
    Just really wondering and im super excited a might be able to hunt down a new 05WRX around august before their all gone.
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    Totally catless, your stock turbo will have pretty much no perceivable lag.
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
    May 2003
    CA
    Quote Originally Posted by dingobite
    Here in CA, it's pretty much the strictest state in the US as far as emissions go. So what we do when smog check rolls around, or when cars get sent to the state referee by the cops for illegal exhaust, is that you swap the stock exhaust up/dp back in, and/or return everything back to stock (a must for the state ref inspection).
    Feb 2005
    ky, lou
    Cool i heard one guy said he had better emissions after going catless left me in the blue a little after that one.
    Jul 2004
    elk grove ca
    Quote Originally Posted by 302@12psi
    yes the boost fluid and the muffler bearings make the hugest difference, things like halgogen fluid and oil dust will also have small benifits
    Registered User xdorgx's Avatar
    Aug 2004
    Moorpark, CA
    Quote Originally Posted by blackrex02
    I want an STi...and I want one NOW!
    Registered User Spectre186's Avatar
    Oct 2003
    Central FL/SoCal
    UP and DP with custom tune will be what you want...
    ericmarkpaul: i pooed myself last night while i was sleeping!
