Results 1 to 7 of 7
This is a discussion on someone wanna explain the "stages" within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; so how do these stages work? what mods are done does the dealer do this you its your own work...
    what mods are done
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    There is no hard rule about what the various stages mean. Different manufacturers or tuners have different parts that go with each stage. Dealers are usually NOT involved in this.
    Do some searching and visit turboxs.com for a start...
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Generally (and this is very general)
    Stage 1
    Catback,
    intake, (WRX responds better to this mod at this point)
    BOV (although this is not a performance mod at this point).
    Possibley some boost control
    Stage 2
    All of the above +
    Downpipe, upipe (WRX only)
    Possbly some engine management/boost control
    Stage 3
    All of the above +
    (here is where it can get a little more vaque as to the line drawn in the sand)
    Engine management
    upgraded turbo
    Stage 4
    All of the above +
    Upgraded IC
    Upgraded fuel pump
    Upgraded injectors
    Stage 3 and 4 are virtually interchangeable IMHO, since if you upgrade your turbo, it is necessary to provide the support mods to ensure a safe running vehichle that won't detonate, etc.
    Also, it is feasible to have engine management from the point of stage 1.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Oct 2002
    The Old Folks Home
    ^^^ Stage 3 is a turbo upgrade? What mod path is that, just out of curiosity?
    TurboXS and Cobb are basically the same for Stages 1 and 2:
    Stage 1:
    Engine Management
    Stage 2:
    Engine Management
    Turboback exhaust
    May or may not include uppipe for Cobb.
    Stage 3 (TurboXS)
    Above, plus upgraded top mount intercooler and different map for EM
    TurboXS Stage 4 and Cobb's Stage "2.5" is:
    Upgraded turbo
    Bigger Fuel Injectors
    Fuel pump upgrade (optional with Cobb)
    Uppipe
    Everything that went into Stage 2.
    --Ray
    Proud owner of a N.E.R.D.
    Jul 2003
    PA
    It's an amalagmation, since many stage 3 upgrades are merely tweaking of the stage 2 installs. Notice I said that once you are at Stage 3, the line becomes very vague. After intake/exhaust/EM (stage 2), with the exception of a turbo upgrade, any new installs are minor performance enhancers IMO. I'm addressing performance only, not tuning issues such as A/F (injectors, better map, bigger IC, fuel pump, etc.) which is essentially what non-turbo upgrade installs do for you.
    The one upgrade I didn't mention that is actually a pretty good performance enhancer with good tuning is water injection, but his is a somewhat rare install.....which one day I'll do also!!
    I'm not a big believer in naming these "stages" to begin with, since there is no prescribed or agreed to path in the market....which is a good thing since you don't want the exact same thing everyone else has...or at least I don't (in the long run).
    Oct 2002
    The Old Folks Home
    Yeah, there's a segment of people on the forum that don't like the stage thing. I can respect that, but the TurboXS path has kinda been taken as the baseline for quickly explaining how modded your car is. With the exception of the Vishnu guys, Stage 1 and 2 are pretty well understood by most people that travel in WRX mod circles.
    --Ray
    Registered User WRC_Obsessed's Avatar
    Jan 2002
    Boston/NNJ
    Check out this thread. Read this and you should have an good understanding if you don't already.
    Stage understanding?
    -Brian
    Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
