02 wrx shaking violently help!
Results 1 to 7 of 7
This is a discussion on 02 wrx shaking violently help! within the New Cars/Prototypes Forums forums, part of the Community - Meet other Enthusiasts category; Okay everybody I am new to this page and am seeking some help considering I can't find it anywhere else ...
    Nov 2014
    Okay everybody I am new to this page and am seeking some help considering I can't find it anywhere else . I have General mechanic knowledge and just picked up a 2002 wrx sedan 2.0 with a blown trans . I purchased a new trans out of an 03 wrx and installed it last night . On the test drive I drive around for a bit and had no issus but never hit over 40mph in town . Now I hopped on the freeway and as soon as I hit right around 60 mph the whole car started vibrating violently until I conpletly stopped . Car still idled fine . As soon as I started driving again the vibration was gone and drive 100 percent normal until I hit about 60+ mph once again . Everything is right and wheels are balanced any suggestions ? Could the rear diff be the wrong gears ? The guy I bought it from said he replaced the diff a week before the trans blew and said he was cruising on the freeway when it happend ? I was thinking that or the driveline what do u guys think ?!!
    Aug 2012
    Tucson, AZ
    What's vibrating exactly? Only at highway speeds? Feel it in the steering wheel?
    Stinkeye member 520
    Aug 2012
    Tucson, AZ
    Honestly due to my experience with complaints of vibrations at highway speeds without applying brakes it's been a wheel balance issue. Depending on which wheels are out of balance you'll either feel it in the seat, the steering wheel, or all of the above if bad enough. Loose wheels may have the same effect.
    Also if the tires are choppy, wavy, feathered this causes it as well.
    If it were to be driveline related and assuming everything was installed right you would probably feel it at all speeds and would have noises associated with the vibrations
    Stinkeye member 520
  5. #4
    Jul 2012
    Rocky Top
    Sounds like the viscous coupling. I had the same symptoms with my car a while back.
    I would suspect wheel balance, wheel bends, rotors, tires, maybe shocks, etc. first though.
  6. #5
    mrd
    mrd is offline
    Registered User mrd's Avatar
    Nov 2010
    Livermore,CA
    Does it stop vibrations if you slowdown or increase the speed?
  7. #6
    Nov 2014
    That's the thing that confuses me is it will not shake at all in town until u hit the freeway like I said before it will shake until u stop and u can't feel it in the steering wheel . Feels like undercarriage vibration . Could a bad cv axel cause that ? I have new lower ball joints and tie rods . I just pulled my diff and on the ring and pinion it say 3.79 is that the correct one for a 2.0 with a 03 trans ?
  8. #7
    Nov 2014
    Vicious coupling what is that lol . Anyone know is the ring and pinion should say 3.79 on it ?
