The dizzle and loulegz thread - Page 754
This is a discussion on The dizzle and loulegz thread within the Mountain States forums, part of the Regional Discussion category; Originally Posted by oogie wish the exhaust would fit my car. what on the exhaust doesnt fit?...
  1. #11296
    Registered User adizzle02's Avatar
    Mar 2008
    Sandy Utah
    Quote Originally Posted by oogie View Post
    VF39'd and Clark Tuned
    BugEyeMafia #176
    Basshead Member #3
  3. #11297
    NJO
    NJO is offline
    Registered User NJO's Avatar
    Oct 2007
    SL,UT
    Quote Originally Posted by adizzle02 View Post
    the front of the mid pipe is like 3inches too short to mate up with a 2.5 exhuast... but im sure you could take it too like master muffler and get it too fit and it would still be cheaper than a normal exhasut
    EX BUGEYE MAFIA #193
    1996 Legacy Outback
    Ej20 swap/ with ALL supporting parts
    intake/turbo inlet/vf39/big tmic/headers/uppipe/downpipe/straight pipe/walbro fp/modded stock injectors/ and too much more
  4. #11298
    Registered User oogie's Avatar
    Oct 2008
    SLC utah
    Quote Originally Posted by NJO View Post
    hmm. you should text me and we could talk figures. See what we can do.
    Http://www.myspace.com/oogiesfaded
    tint
    wrx exhaust
    mud flaps
    Drop in K&N
  6. #11299
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    ya man for sure ill hit you up, what are you doing tongiht?
    1996 Legacy Outback
  7. #11300
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    and anyone have stock 06 07 wheels that they would be willing to part with?
    1996 Legacy Outback
  8. #11301
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    I do...
    But I would need to buy new wheels first.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  9. #11302
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    AHHHHHHH. so after getting my new turbo inlet hose in and my car still wouldnt boost i reset the ecu and reloaded stage 2 from the access port. then it still wouldnt boost above 9ish. i went in to work today and smoke tested it again... didnt find anyhting that shows up under that lowe of pressure. but its starting to lead me to believe i have a problem perhaps with my software or my ecu? anyone have any ideas?
    1996 Legacy Outback
  10. #11303
    Mar 2008
    Sandy Utah
    i would try swapping in a borrowed BCS. Thats the same problem i was having but i was only hitting 7psi. I got a new one and problem solved
    BugEyeMafia #176
    Basshead Member #3
  11. #11304
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    i switched one with my friends 05 and it didnt change... would i need to reset my ecu or anything initialize it when i put it on?
    1996 Legacy Outback
  12. #11305
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    ok, so another thing ive found while searching was about the "restrictor pill"? i know that its in one of the lines and i think its on one of the ones after the t fromt the ebcs. would this caus emy problem if its missing? prior to my knowledge of this restricotr pill i had to replace several lines from the waste gate due to cracking and breaking. i hope i didnt replace it...
    1996 Legacy Outback
  13. #11306
    Mar 2008
    Sandy Utah
    it could..its in the small line to the left of the BPV you can feel it if its in there. CobbTuning.com - How Subaru’s Factory Boost Control System Works
    and you checked all the boost hoses to make sure there are no small cracks that maybe you didnt see?
    BugEyeMafia #176
    Basshead Member #3
  14. #11307
    Oct 2008
    SLC utah
    i need to find an amp for 2 12's. anyone got somethin sitting around? not to expensive?
    tint
    wrx exhaust
    mud flaps
    Drop in K&N
  15. #11308
    Nov 2006
    Denver Metro Area
    Yup
    That'd be it.
    You're hitting mechanical boost. The signal has to be restricted by a 3port boost control solenoid (no pill) a manual boost controller (no pill) an electronic boost controller (no pill) or a 2 port bleed style boost control solenoid (stock... has pill in the line)
    either buy a 3 port, a hallman MBC, a Blitz EBC, or a pill. If you buy anything other than the pill you need a tune though!
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  16. #11309
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    7 to 7... a long day at work.
    1996 Legacy Outback
  17. #11310
    Oct 2008
    SLC utah
    ya, im working about the same. you should keep up around here
    tint
    wrx exhaust
    mud flaps
    Drop in K&N
