ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Community - Meet other Enthusiasts > Motorsports Talk
Motorsports Talk Auto-X, Drag Racing, Track, Rallying, F1.
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 09-23-2002, 07:59 AM   #1 (permalink)
LemonHerb's Avatar
Send a message via AIM to LemonHerb
Slip the clutch, drop the clutch? Whats the differnce
I read a lot about how people say you shouldnt drop the clutch and slip it instead. Whats the differnce here. I mean I figured there was about one thing you could do with it and thats just let it out. Most of this is in responce to a 4 or 5k launch.
LemonHerb is offline   Reply With Quote
Old 09-23-2002, 08:56 AM   #2 (permalink)
Moderator
TypeC's Avatar
Re: Slip the clutch, drop the clutch? Whats the differnce
Quote:
Slipping the clutch is just that. You release the clutch pedal slowly. The more you release, the more your car will bog. The less you release, the more the revs will stay up, BUT it'll also wear your clutch down more.
Dropping the clutch is just letting off of the pedal completely all at once. This is good for consistancy, but slipping gives the best overall control (I do the dropping method).
hth, -C
__________________
Street Racer Emeritus
'02 2.5L WRX - Retired
TypeC is offline   Reply With Quote
Old 09-25-2002, 04:23 PM   #3 (permalink)
Send a message via AIM to Samirr76
Dropping is the best way to bog and strip all the teeth off your first gear.
__________________
02 WRX Silver, 03 Baja Yellow
Samirr76 is offline   Reply With Quote
Old 09-25-2002, 07:20 PM   #4 (permalink)
CustomS10's Avatar
Send a message via AIM to CustomS10
ok dropping the clutch is bad for your differential and tranny and slipping the clutch is better for your car unless u hold it to long and <sniff sniff> burnt clutch....practice makes perfect. Search the site and you'll find so many views on this topic
__________________
-Ben-
Spark it or Park it!
CustomS10 is offline   Reply With Quote
Old 09-26-2002, 11:52 AM   #5 (permalink)
Moderator
TypeC's Avatar
Quote:
Wrong. Dropping the clutch with no power does that. If you build boost, dropping the clutch will net consistant times. Your wheels will spin which gets rid of that huge BITE that happens when you drop it and bog. Something has to slip whether it's the tires of the clutch.
__________________
Old 09-26-2002, 11:53 AM   #6 (permalink)
CustomS10's Avatar
Quote:
after a few times of dumping the clutch u can better believe u will leave your tranny behind on the ground and the diff will be in 348975493857 pieces
__________________
-Ben-
Old 09-30-2002, 06:55 AM   #7 (permalink)
Moderator
TypeC's Avatar
Quote:
I'm sorry but you're DEAD wrong. This is the kind of misinformation we DON'T need here. After 200+ passes, and nearly 2 yrs of racingwith dropping the cluth under boost (and spinning the tires) when my tranny was taken apart (for inspection) by a shop the gears, synchros, and clutch were 100% perfect. The shop guy that I only had 1K miles it was that perfect.
So in short, you're wrong. There is a proper way to dump the clutch while not hurting your tranny.
-C
__________________
Old 09-30-2002, 07:27 AM   #8 (permalink)
CustomS10's Avatar
-C
i may not be a tranny specialist nor do i claim to be one. But a someone who works on tranny's stated that it was bad. hold on i'll get the exact post for you by noon time. an AWD i dont see how that can be good for the tranny. IMHO you have the 1 sweet WRX tranny, unlike alot of other people who busted and broke theirs. I myself would rather slip it and be safe then dump it and be sorry
__________________
-Ben-
Old 09-30-2002, 07:38 AM   #9 (permalink)
Moderator
TypeC's Avatar
Right, I'm not talking about what someone thinks is bad, I'm talking about what I (and others) have shown through example to not be bad. This is also done in the DSM world. So, no matter what you post, this doesn't change the reality of this experience. In other words, don't post "after a few times of dumping the clutch u can better believe u will leave your tranny behind on the ground and the diff will be in 348975493857 pieces" when that is not based on any facts nor personal experiences.
Again, if you launch on boost and spin the tires, there isn't as much shock as when everything bites.
__________________
Old 09-30-2002, 07:40 AM   #10 (permalink)
CustomS10's Avatar
correct me if i'm wrong but tire spinning is bad in a drag or street race. Grip is good. So dumping the cluth and spinning would be the exact same thing time wise as slipping it and getting no spin..correct or am i mistaken?
__________________
-Ben-
Old 09-30-2002, 09:55 AM   #11 (permalink)
VetteVert's Avatar
Send a message via AIM to VetteVert Send a message via Yahoo to VetteVert
You are mistaken. You want some slip at launch (with a drop) so it's not so hard on the drivetrain and to keep the car in boost. Slipping the clutch overheats it and will glaze it over time....it won't grab as hard.
VV
VetteVert is offline   Reply With Quote
Old 09-30-2002, 10:02 AM   #12 (permalink)
CustomS10's Avatar
Quote:
VV
can you explain that again u said i was mistaken but then u said slipping is what you wanted? did u word it wrong or am i not picking it up
__________________
-Ben-
Old 09-30-2002, 10:09 AM   #13 (permalink)
VetteVert's Avatar
One or the other. No, you do not want to slip the clutch for optimum launches. You want to dump, but with some tire spin. When you dump and bog, nothing is slipping, and all the force is being absorbed by the drivetrain. When you dump the clutch and spin a little, the shock is much reduced by the wheels slipping slightly (which also keeps you in boost, i.e. good ). When you slip the clutch you heat the clutch (hence the smell). When you finally do let go of the clutch it won't grab like the non overheated clutch will. Enough slipping will also glaze your clutch disk, causing it to slip even when you don't want it to.
VV
Old 09-30-2002, 10:12 AM   #14 (permalink)
CustomS10's Avatar
so which do you use/think is better? u gave good arguments from both sides
__________________
-Ben-
Old 09-30-2002, 10:18 AM   #15 (permalink)
VetteVert's Avatar
I use the drop method (with slip). Netted me 3 1.9 second 60's first time at the strip.
VV
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
