| Home | Forums | Gallery | Register | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| Motorsports Talk Auto-X, Drag Racing, Track, Rallying, F1. |
| Advertise On ClubWRX | ||
LinkBack | Thread Tools | Rate Thread | Display Modes |
#77 (permalink) |
I'm sorry, I wasn't clear on the fact that you have to have a serious clutch to use this method. I have a triple disk cerametallic clutch. My friend has a twin. Yes, it will eat your clutch up, but that's part of racing. Even with this abusive method, if you have a good clutch you should be good for a season of racing. My thought is.... I would rather lunch my 1500 dollar clutch than my 4500 dollar driveline
![]() Having said that, wear and tear is part of racing...if you can't afford to break your car, don't race it. That is why I had to stop racing.
__________________
11.1 @ 131 Last edited by fre; 11-15-2006 at 07:59 PM. |
#78 (permalink) |
how about doing this on a Dirt road? what about Sand dunes? Since you want a bit of tire slippage when you drop the clutch, is it good since the tire will spin in for a second?
__________________
IM THE JUGGERNAUT B!TCH
#79 (permalink) |
Launching on a dirt road is definitely easier on your driveline, but you will probably sit there spinning for quite some time on dirt. You also tend to fling a lot of rocks up causing some nice dings. Really no point in launching on dirt, because you would be better off rolling out. Even then I spin like crazy once I hit boost.
__________________
11.1 @ 131 |
#80 (permalink) | |
Moderator
Quote:
LOL..it's a rally based car. You really won't know just how much fun you can have with the Impreza platform until you dirt or mud it up at least once! No...spinning in gravel will not hurt anything except maybe your paint.
__________________
tEh PriUs=teH faSTah!@@! ![]() SOLD: 05 SWP Legacy GT Limited 5MT, 13.3ish@105 (stage 2) crappy stock clutch SOLD: 04 MPS/SW WRX Sti. 12.971 @ 103.97 (stock) 278 AWHP/283 AWT, Catback exhaust 306 AWHP/341 AWT, Stage 2 (Scott) Moderator-STi, Drag Racing, Car Purchasing, and Tutorial Forums |
#82 (permalink) |
So ive read this thread twice i just wana make sure i got the clean cut concensous on how to launch AWD cars.
1.Clutch in blip throttle to build what ever boost you can 2.Before green light floor it 3.drop clutch (now would it be a side-step or like a omg i stepped in dog crap thing) 4. make sure you get alteast a bit of tire slip so save drive train 5. keep tires at aorund 40psi to ensure spin Once im just tryin to have a post were its like heres a question heres the general concenous answer. Thanks in advance. |
#83 (permalink) |
I've launched a few times, and my method is this.
1. Clutch disengaged, neutral. 2. 1st gear, bring RPM's to about 4k 3. Blip throttle in 2-300k incriments at a time to keep spool After this I like to bring the clutch out at a mild pace, not dropping it or slipping it but sort of in between. I've done the wheelspin and I've done the slipping but I practiced and made a hybrid. I didn't like the feeling of the clutch after slipping, felt squishy like it wouldn't engage into 2nd. And the wheelspin looks and sounds cool out of an AWD car, but if I wanted that much I'd of just bought a RWD. After a few practice runs I can now lauch without any glazing and my clutch engagement hasn't moved an inch. Also, practicing the same methods in my daily driver (Del sol) like it was my WRX helped out a ton. Made it able to practice different kinds without worrying about hurting my baby. And yes I know FWD launch is like 1337 times different, but I launched like I thought it was a AWD.
#84 (permalink) | |
Quote:
Sideways floating is always a good time.
__________________
11.1 @ 131 |
#85 (permalink) |
Alright so it was rainy tonight and went out to try some launches but I couldn't figure out one friggin way to "build" boost when im revving. It was still in vac the whole time, every time... how do you guys launch on boost I am deffinetly missing something here. BTW I would make a tree in my mind
holding it at 3.5k then right when im ready to launch I rev it to 5k.
__________________
Sold the WRX bought a '06 Evo IX MR and sorry to say never looked back
#86 (permalink) | |
Quote:
You won't build up boost without anti lag. You have to slip the clutch to build boost. As your car loads the driveline you will build all your boost, which is why awd cars have that slow roll out appearance in the first split second of launching. The idea is to slip the clutch just enough to avoid bogging. It is a fine line to walk.
__________________
11.1 @ 131 |
#87 (permalink) | |
Quote:
http://videos.streetfire.net/video/w...2d01701c82.htm |
#89 (permalink) |
I dont get it...
Ok i have been driving manual trans for a short period of time roughly 2 months. I just read about dropping the clutch but dont seem to understand. When i tried to do so i put my car in first gear rev to 2000 rpms and let the clutch out completely, this resulted in a stall. So my question is How does dropping the clutch work? am i supposed to rev higher? or am i suppose to let it out quicker than slipping the clutch? And from what i have read so far dropping the clutch is worse for the the car than slipping for short periods of time correct?
#90 (permalink) | |
If you are that new to driving a manual, I would suggest getting more comfortable with it before attempting to launch the car...
But your problem is that 2000 rpms is WAY too low. Dumping the clutch at 2000 - 4000 or so is asking for trouble IMO. You either want to slip the clutch or slip the tires (spin). FWIW, I launch at 5500 - 6000 rpm with overinflated tires. I don't side-step the clutch, just a quick release. VV Quote:
| Thread Tools | |
| Display Modes | Rate This Thread |
