Results 1 to 11 of 11
This is a discussion on Quick info about autocross within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; I have a 2002 WRX wagon slightly modded, i'm into drag racing as of right now but i'm looking to ...
    Registered User stiwgn02's Avatar
    May 2007
    Mass
    Thumbs up Quick info about autocross
    I have a 2002 WRX wagon slightly modded, i'm into drag racing as of right now but i'm looking to get into auto-x, and time trial
    Should I go with the full cusco under body and zero 2 suspension.
    or keep a stock underbody and go wiht the TEIN Hg suspension
    Currently I have a Cusco f. strut bar and Front sub-frame connector
    thanks for the help
    Registered User Ludicrous Speed's Avatar
    Sep 2006
    MD
    I would go with spending $30-40 on an event first to realize that it will take a lot more than bracing and a suspension to make you quick. My first autox was done in 40 degree weather and my times in DS were about 55 seconds or so. The STX WRXs were doing about 50. Evo/STi (STU and SM) times were about 45. Then one of the instructors took his HS Prius and consistently put down 41 second times.
    To paraphrase Lance Armstrong: It's not about the car.
    You must unlearn what you have learned!
    May 2007
    Mass
    cool thanks for the hint.
    02' WRX Wagon
    Engine Mods:Mild
    Int/Ext Mods: STI Stuff, Sparco
    Suspension/Brakes: Stage2 w/ sslines, Cusco bits
    May 2005
    Phillytown, PA
    VERY IMPORTANT: You need to prep the car to the class. Something as simple as a ladder brace is going to throw into a higher class like SM, and unless you are willing to spend a butt load of money on the car you will never have a good chance to consistently place well.
    A good place for an '02 WRX is STX. Read the rules for this class and mod accordingly.
    Even more important than this is Ludicrous is right, driver is so much more important than the car.
    May 2007
    Mass
    cool thanks man
    02' WRX Wagon
    Engine Mods:Mild
    May 2007
    behind the wheel
    ha! it'd been sweet to see the Prius lay it down
    Rogan o_0
    '01 Dodge 2500 CTD 6-holed hand-shaker - 3850# dual disk
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties
    Registered User STiDriven's Avatar
    Apr 2004
    St. Louis
    Well I would tell you to not buy anything right now (except fresh tires), but learn to drive the car first. Then based on your driving style, what you would like the car to do, and what class you want to run in, buy parts from there.
    Registered User Web Foot STi's Avatar
    Jun 2003
    Portland, OR
    What sort of mods have you done? You may have already bumped yourself into a high auto-X class.
    Cones don't count at Hillclimbs.
    May 2007
    Mass
    suspension i only have a cusco front subframe.
    motor has many bolt ons
    brakes are pads and sslines
    02' WRX Wagon
    Engine Mods:Mild
    Jun 2003
    Portland, OR
    It sound's like you are in SM, or, depending on the crossmember, Prepared. Not a good place to cut your teeth. The only higher class is Mod.
    May 2007
    Mass
    thanks for the help i'm preparing for my first event in early october wiht a hyundai buddy. i'll let you guys know how i do then. wml
    02' WRX Wagon
    Engine Mods:Mild
