Slicks
Results 1 to 6 of 6
This is a discussion on Slicks within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; Does anybody put slicks on their car? How does AWD work with slicks? Are slicks pointless because our cars can ...
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    Slicks
    Does anybody put slicks on their car? How does AWD work with slicks? Are slicks pointless because our cars can launch hard as hell anyway because of the AWD?
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Quote Originally Posted by bcyb1029 View Post
    Depends on your definition. Slicks are definitely going to improve your 60 footer time...BUT...you will likely snap an a shaft or axle due to the hook up. The stock tires are fairly sticky themselves, and in fact, you need to raise the pressure fairly high to make the spin well in order to avoid extreme shock to the powertrain. You WANT the tires to spin with the stock setup, otherwise something is liable to break.
    Have you launched it yet?
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Jun 2006
    it depends on what you want to do also, slicks will help you out big time for handling, ie. auto crossing
    Feb 2006
    Chicago
    Yes, I like to slip it. I also have fuzion XR-i's, I ditched the potenza re92's a long time ago. By stock set up do you mean drive train or engine? I have a act stage 1 clutch and my engine is def. not stock.
    Jun 2006
    Launch Techniques: READ ME FIRST
    some good reading there. In a nutshell: you need something to slip, be it your clutch or your tires, or else all that shock is absorbed by your transmission and you will blow it up eventually.
    Jul 2003
    PA
    Quote Originally Posted by jester458 View Post
    hehe....I'd like to see someone use drag slicks in an autocross. Can you say crumbling side walls?
    I realize you meant road slicks, but this thread is about drag racing...totally different type of slick. Major drag slicks are called "wrinkle walls" for a reason...and it is a reason that doesn't translate well to turning corners at high g's.
