I am moving from STX to ESP this year... any thoughts on a new combo?
This is a discussion on STX Wheel and Tire Choice within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; Originally Posted by jcroy66 As for what are the ESP and SM WRXs running? Hmm, if there were any national ...
Step 2 Racing
http://www.step2racing.com
Your no longer limited to 8"- a lightweight 8.5 or even 9" would be niceNo longer limited to 245 as well
Sizing is somewhat limited in both the A6 and 710, the Victoracer comes in a 255/40/17 which would be a pretty nice size
But I can imagine that it would be hard to find a 17x9 Wheels with 110-5 bolt pattern AND the right offset to get the 255 tires to no rub...
What would be your suggestions on a wheel to fit the bill without going custom?
17x9's are pretty hard to find- a fair # of 8.5" rims available in 5x100 though
On a sedan w/ the fenders rolled I would think 255's would be fine.
SP is a pretty competitive class (aren't they all) a good wide R compound is going to be a must.
17-9's 5-100 owner, definatley nice to have a set in thea garage.![]()
"Failure is an orphin, sucsees has many fathers's"
nice cone!
So Did you have a lot of rubbing issues? What tires/sizes are you running?
Thanks!
Very true, but I don't want to play with STis...
What spring rates are you running? I am thinking about somewhere in the 500 -600lbs range.
10k 8k. I dot know if that question was for me, but I will answer anyway.
Hey guys,
Found some pretty sweet deals, need help considering the tradeoffs(will be running 235-stones or azenis):
17x7.5 dirt cheap Volk te37 15.5lbs $587set
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
17x8 Cheap 5zigen fnor-1 17lbs, $150/ea = $600
http://www.edgeracing.com/wheel/210/
17x8 Almost cheap Enkei RPF1 -tirerack 15Lbs, $235/ea = $940
I think the 235's will fit fine on 7.5, will the fit perfectly square? is the 1.5lbs worth the .5" in wheel? I'm thinking no, it might be a slightly narrow rim, but for the price and the weight, how can i beat em?
That's the order i think i'd buy them in. My budget prefers it, if i go with enkeis, i'll be springless, shockless, swayless or some combo thereof for 6 mos i'd prefer not to be.
Thanks!
