Flip a WRX in Autocross
Results 1 to 15 of 15
This is a discussion on Flip a WRX in Autocross within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; I notice in alot of wrx autocross videos that around tight turns one of the wheels may lift up. Is ...
    Registered User The Gator's Avatar
    Nov 2011
    New York
    I notice in alot of wrx autocross videos that around tight turns one of the wheels may lift up. Is it a legitimate concern to worry about flipping the car during autocross, or is it nothing to worry about?
    PS: I know stupid question
    - Nicky -
    2006 WRX Steel Gray
    23:4--3:6--27:1
    Registered User G8toWRXDave's Avatar
    Sep 2011
    Western NY
    The center of gravity is so low the car will slide before it flips.
    Now if there was excessive speed, car slides off the pavement into the grass, then it could flip.
    Sent from my DROIDX using Tapatalk
    2011 WRX Limited - Dark Grey Metallic
    [Cobb stage 2 93+ SF Intake] [Invidia Catted DP] [SMY Gauge Cluster w/Boost and Volt Gauges] [Monkeybone Racing Heater Vent Gauge Panel w/Oil Pressure and Temp Gauges]
    [Cobb Heatshield] [Kartboy SS] [Weathertech Floorliners] [Hardwired V1 w/Remote Display] [Complete Aftermarket Audio System] [Lighted WRX fender badges]
    Nov 2011
    New York
    Thats what i figured. I have never really heard of one flipping outside of rallycross. It was just something bugging me. Thanks.
    - Nicky -
    2006 WRX Steel Gray
    23:4--3:6--27:1
    Apr 2004
    Southeastern PA
    A curb or other low profile obstacle (an uneven seam of tarmac) can easily induce a flip.
    Mods & Pics
    Nov 2011
    New York
    That would be unfortunate.
    - Nicky -
    2006 WRX Steel Gray
    23:4--3:6--27:1
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Large city riots usually induce a flip as well.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    Nov 2011
    New York
    I agree.
    - Nicky -
    2006 WRX Steel Gray
    23:4--3:6--27:1
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Sasquatch View Post
    A WRX is pretty hard to flip. I slid sideways into a storm drain at about 50mph and the car didn't come close to flipping, it just put the axle through the transmission housing, out the other side, and crumpled the frame. Low center of gravity causes it to slide before the wheels come up, and in my experience, if you catch an edge it will just shatter the tires/hubs and rip the undercarriage off the car.. not that it's impossible to roll the car, I'm sure I could if I tried.
    Registered User Karlosnived's Avatar
    Sep 2011
    OSU
    You'd have do some pretty serious stuff to get it flip. I hit some ice with mine and put it into a really mean slide, then ended up "parking" on the curb fairly well. when it first hit the curb it just snapped perpendicular to it then when went right up and over, i don't even think the body rolled much.
    2004 wrx 5-door, freshie in college, miss my car
    Registered User Annihilator817's Avatar
    Oct 2011
    New England
    Its a legitimate concern.
    The main reason you are seeing the rear wheel lift has little to do with the possibility of flipping the car though, in fact, it reduces the possibility. It happens because poeple are using larger rear swaybars to reduce rear traction and induce rotation. As was previously mentioned, as long as the car loses traction it is unlikely ot flip.
    However, every year RS/WRX/STI all have VERY soft suspensions from the factory. When you start upping the traction with sticky street tires or r-comps, and don't upgrade the dampers to control the roll in the transitions, you are greatly increasing the risk of rolling the car in a quick transition (think slalom). The stock dampers provide basically NO control in transitions, and the car is literally flopping back and forth, building inertia. For this reason, you should NEVER run r-comps on a Subaru at an autocross (or any car for that matter) without upgrading teh dampers.
    FWIW, I've had an RS on 225/45/17 RT-615's up on two wheels in a quick transition, and ended up black flagged for the rest of the day. I upgraded the dampers before the next event, problem solved.
    -Ken
    Good judgement comes from experience, and experience comes from bad judgement.
    It's to their credit that they black flagged you. I always wondered about something like that, especially in some of the rough concrete parking lots used sometimes, because there's just so much traction and the cars are all road cars.
    Registered User SamXp's Avatar
    Nov 2010
    Winston-Salem, NC
    Quote Originally Posted by Annihilator817 View Post
    -Ken
    Very well said. You're obviously going a lot quicker than the average car at an AutoX, though. Most don't go nearly fast enough to induce a flip.
    Oct 2011
    New England
    That is a good point, and applies just about everybody that participates in this sport. As the skill level goes up, the level of prep has to go up for safety reasons.
    As anyone starts to develop more driving skill, and also as they learn to get the most out of their setup, they tend to find that limit right before the car breaks traction, and they can drive at that limit more often, and thus, more likely to get into sticky (no pun intended) situations with their car....
    This was my rookie year back in 2008 (eh, it must have been 2009 since the class is ST not STS)
    The car is not in a transition, its in a sweeper in full acceleration. Setup was 100% stock with a 25mm RSB and 225 RT-615's.
    Palmyra, NJ
    WOW That's a sick picture! I'm guessing black flagged means you cannot continue to compete? I don't know much about Auto-X.
    Oct 2011
    New England
    Correct. Black flag means fix the problem, or find another ride. So i just hopped in a friends car for the rest of the day....
