What Do I need for a track day?
Results 1 to 5 of 5
This is a discussion on What Do I need for a track day? within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; Hi I have a stock 2007 wrx. I will most likely be getting summer tires before I go. Do I ...
    Registered User SubaruWRC's Avatar
    May 2007
    New Orleans
    Hi I have a stock 2007 wrx. I will most likely be getting summer tires before I go. Do I need anything else. I will be going to BeaveRun in PA. I was told I should have better brake pads and brake fluid. Do I need this or should I be fine with everything stock?
    STU 17
    Hawk-Eye Alliance #117
    WATCH THIS
    Registered User timb's Avatar
    Feb 2009
    Sebring Fl
    You do not really "need" any thing, however, if you run it really hard you will start to lose breaking (very spongy until none at all) because the fluid will boil, so you should consider stainless brake lines and a good fluid. Other than that, you can run on the track all day, unless your pads start to fade... You need a helmet too! Haha, have fun!
    STIzzy!
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    what's your goal? How hard will you be running the car?
    Oil change isn't a bad idea...
    Helmet is a must...
    If you'll have a little bit to spend... fluid lines and pads should probably be the first things to upgrade.. then tires.
    Safety equipment is a must too...
    You can get a helmet and a race jacket for a fair deal (under 200 total). If you need a place to get some quality safety equipment shoot me a PM... I know a guy lmfao
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  5. #4
    Registered User PurpleMongoose's Avatar
    Jul 2009
    Pittsburgh, PA
    You looking at autocross or flat-out on the north track?
    IIRC, they only require a brake fluid replacement in the past 3 months for the flat-out days...better parts are always a good idea though.
    BeaveRun does require helmets. Snell-rated, not just DOT.
    Here's the links for vehicle requirements:
    http://www.beaverun.com/pdf/vehicle%...ion%20form.pdf
    http://www.beaverun.com/pdf/Flat-Out...ch%20Sheet.pdf
    Maybe I'll see you there sometime. I like to hit the low-key ax every once in a while.
    Stink-Eye Mob #666
    2009 WRX Sedan
  6. #5
    Registered User car39's Avatar
    Jul 2005
    Downtown ct
    Porterfield makes a pretty good set of track pads for the 4 pot caliper. It's pretty simple to change front pads, just don't forget to pump the brakes before you move the car for the first time after working on it.
