Rev up to about 4k RPM, don't dump the clutch, but quickly ride the clutch. in one swift and steady motion let out just a bit faster than riding the piss out of the clutch. if you let out too quick, you will bog the car down and ***k up your clutch. if you do it too slow, you will burn up your clutch and smoke the piss out of it. basically, just a bit slower than dumping it. be ready, becase as soon as the clutch is finally all the way out, it will be time to go to your next gear.
LinkBack URL
About LinkBacks
...i can cut consistent 1.7's at this point, at the cost of the stock clutch and a lot of damage to the trans....good luck
Even if a sticky was made it would be glanced over and missed like every other sticky on this forum.
