Rev-limiter
Results 1 to 4 of 4
This is a discussion on Rev-limiter within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; Can anyone tell me if my 09 WRX has a permanent rev-limiter? I noticed that it cuts out at red/yellow ...
    Registered User GunslingerRC's Avatar
    Nov 2008
    Okanagan, Canada
    Rev-limiter
    I noticed that it cuts out at red/yellow line, which is 6500 rpm, yet the tach goes to 8000 rpm.
    I thought maybe this would change as I put more miles on the odometer, but I'm up to around 3000 miles and still notice the limiter at 6500 rpm.
    Just wondering, as it'd seem there's 1500 rpm I'm sort of missing. (Not that I plan on running to 8000 rpm all the time.)
    Thanks.
    Too cold to ride... so I'll drive instead.
    Dec 2003
    Dallas, TX / Sterling, VA
    Quote Originally Posted by GunslingerRC View Post
    Thanks.
    You're gonna spin a bearing, experience valve float, and/or break something in your valvetrain if you ever run 8000 rpm on a stock motor. Just because it has the numbers on the tach it doesn't mean the car can do it stock.
    On top of that, you're stock turbo is gonna run out of unf long before you get to 8k. You're not missing anything. If you were to get a larger turbo, say an FP Green, then I'd say you'd be fine to raise it to 7250 tops.
    Registered User shamrock's Avatar
    Aug 2008
    motor city
    Quote Originally Posted by brfatal View Post
    +123456^^^^^^^ to everything he said. Ever read the spun bearing threads. Revving that high, your just asking for problems. Plus like said above, boost runs out before 6K. STAY WAY AWAY FROM YOUR REV LIMITER, sheeesh, I dont go higher than5,500 rpms
    2004 wrb WRX "Bugeye"
    http://www.misubie.com/
    Nov 2008
    Okanagan, Canada
    Quote Originally Posted by shamrock View Post
    I guess that would explain the knocking and pinging I get every time I accelerate... JUST KIDDING!.
    Thanks for the advice. I'll get around to reading the spun bearing thread at some point, and hope I never need to refer back to it.
