Results 1 to 11 of 11
This is a discussion on When to shift within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; What RPM's should I be shifting at for each gear? How about on the launch, what RPM should the tach ...
    Registered User 321wings's Avatar
    Jul 2008
    When to shift
    What RPM's should I be shifting at for each gear? How about on the launch, what RPM should the tach read?
    You shift when you can safely reduce the load by entering a higher gear.
    Launch @ whatever RPM you feel comfortable with. I'll usually go @ 4K when Auto-Xing
    Registered User Jebus's Avatar
    Oct 2007
    Portland
    3.14159265.... always.
    Jul 2008
    Shift at Pi RPM's huh? I'm not sure I can get the engine to idle that low!
    Registered User Mattcr2d2's Avatar
    Apr 2008
    Denver, Colorado 3oh3
    daily driving no more than 3,500-4,000 at most,
    for high preformance, dyno ur car and shift so u go from peak hp to peak tq if you can ie, 4K= max tq, -7000=max hp, shift so rpms will drop to about 4 k so shift about 7.2k make sense?
    Jul 2008
    Quote Originally Posted by Mattcr2d2 View Post
    Yup, that's all I wanted to know. Thanks. I still like the idea of shifting at "3.1415926 always". It's easier to remember
    Registered User ROHDEREX's Avatar
    May 2007
    Waukesha, WI
    I usually shift at no higher than 3.5 around town and at or around 6k (cuz after that the peak hp tapers off) when I'm havin fun.
    Registered User Black X Dahlia's Avatar
    Apr 2008
    baton rouge, la
    Quote Originally Posted by Jebus View Post
    Lmao....
    How Fast Can You Afford To Go?
    Registered User Web Foot STi's Avatar
    Jun 2003
    Portland, OR
    Red line the tach in first then 6,400 rpm is a nice compromise for the rest of the gears. You want max area under the HP curve.
    Around town I short shift at about 3,000 rpm...
    Cones don't count at Hillclimbs.
    Registered User rex01752's Avatar
    Mar 2006
    Marlborough,Ma
    Around town i shift between 2500 and 3000 to save gas. When driving sporty i shift no higher then 6k in first then no higher then 5.5k in every other gear.
    Bugeye Mafia Member #171 For Life No Matter What It Takes
    Apr 2008
    baton rouge, la
    Quote Originally Posted by Web Foot STi View Post
    I like this info
