Results 1 to 5 of 5
This is a discussion on Best shift points for the 08? within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; just wondering what you guys think for shifting... whats good for best gas mileage and whats best for race shifting?...
    Banned WaWaWRX's Avatar
    Jun 2008
    West Chester/Boston
    Not sure about the '08 WRX, but I've had best gas mileage shifting 4000-4500 RPMs
    Regardless of car or model:
    For max efficiency, try shifting at 3/5 max torque rpm, earlier if possible.
    For max speed, keep the needle between max torque rpm on the low end and max hp rpm on the high end. This means every shift cannot fall below max torque rpm when shifting up.
    Check the motor's specs for max torque and hp rpm.
    Feb 2008
    Portage, IN
    Quote Originally Posted by idipskoalmint View Post
    really!? Anyone else confirm this for an STi?
    Registered User tuskenraider's Avatar
    Aug 2004
    Chicago area
    I'd figure shifting before the turbo starts spooling agressively, 3500 rpm. You could also go a little higher and skip a gear or two. In a racing application, it depends what you are doing and what is coming up in front of you. Straight line, I'd say 6700 rpm.
