Best advice....
Put ice in your I/C sprayer (You have an STI, right?) USE IT!!
If the line to get up to the light is long... shut the car off and push it. If your I/C gets too hot while idling, it'll drop your time by 1/2 second or more. If you can, push it with the hood open. Cooless=your friend.
Avoid the burnout puddle at all costs.... you don't need it, and if you drive through it, you'll slip and lose time.
Take out any extra weight..... spare tire, speaker boxes, dead bodies... whatever
Go to the track with less than 1/4 tank of the highest octane fuel you can get... throw in 1/2 bottle of Sea Foam... it helps.
Turn off all electronic accessories (stereo, headlights, etc... all of that causes drag on the alternator.
Put your stock wheels/tires on..... unless you have lighter aftermarket ones. Heavy/big wheels may improve your handling, but will DRAMATICALLY slow down your straight-line performance.
Leave your DCCD at 50/50... you want all the traction you can get.... thats your subaru advantage.... that's what will allow you to jump on the big HP V8 cars (Cobras, SRT chargers, Vettes, etc)
Run the RPMS to 4000-5000... and slip the clutch, DO NOT DUMP IT... a clutch is much easier to replace than a tranny)
I use the Autometer DPSS stage 2 digital tach/shift light. If you're serious about drag racing, it's worth it's weight in Gold. Even just a basic shift light is extremely valuable.
Time your "slippage" around the 2nd light, so that by the time you actually start moving, the 3rd light has already gone off.
Wait a while between runs.... let your car cool down.
Go at night.... when it's cool... don't try to drag race on a hot summer day, you'll do lousy.
****The cooler you can keep your car, the better you'll do.
