This is a discussion on Teh Cone Dodgin' STX Wagon within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; Originally Posted by mycologist This will help motivate me hopefully to put mine on this week. You will like. Originally ...
You will like.
Again, on the ride into work I am simply amazed at how well this car is sorted out. The ride is a bit more rough than I thought it would be, but it is not bad at all. I still need to play with my Koni's a bit, but they're pretty close at the moment.
Also, ~4.5 deg. of caster is great. I'm getting this much from both the Com C mounts and my offset traverse link bushings.
All I need now is some additional b00st.![]()
~Stan
'04 WRB WRX Wagon (Build) - Hard Parked, AutoX Toy
'86 BMW 325es ~ "The Chump" ~ '11 Hyundai Elantra Limited ~ Daily Driven
"I was raised knowing there is a replacement for displacement, it's called engineering."
Somewhere around 50-75% of rebound is about right.
If you want to set up yourself, just start at full soft and dial the front until the bounce goes away. The rear is a bit harder to feel. Either use the same adjustment from the front or simply dial the rebound up to add rotation to balance the car.
