Teh Cone Dodgin' STX Wagon - Page 2
Page 2 of 20 FirstFirst 123456789101112 ... LastLast
Results 16 to 30 of 289
This is a discussion on Teh Cone Dodgin' STX Wagon within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; nice thread OTS springs- you can post the spring rates- your among friends yup liquid filled are the rear bushings- ...
    Jul 2001
    Plains of Eastern Montana
    nice thread
    yup liquid filled are the rear bushings- I was hoping you didn't have to resort to drilling and cutting
    is the offset in the bushing fully rearward or full forward (I'm thinking rearward but would like to be sure)
    Paul as you already have the bushings ready to go- your install will be much simpler- remove the subframe, remove the two (very high torqued) bolts, pry the end of the arm down until you can reach the rearward nut holding the bushing onto the arm-remove, put you new one on, torque the rear nut, torque the two bolts, re-install subframe
    JR- that's a good idea on scales and alignment tools- you guys will recoup the costs quickly!
    Did they happen to send you dynographs when they revalved them?
    These are single adjustable correct? I'd suggest starting at full soft and working up (taking good notes) slowly- once you get them roughed in then you can you can fine tune front vs rear.
    Mike
    May 2005
    Phillytown, PA
    Friends can always send me a PM and ask. I think I already told you anyhow.
    The offset in the bushing moves the pivot point of the control arm away from the centerline of the car.
    Tein's shock dyno is broken. I'm really quite a bit upset about this as this really doesn't give me any baseline to work off of.
    Tein calls them a double adjustable, with combined compression & rebound adjustment, but from talking with some people that have experience with the damper, there really isn't much that changes with compression over the range. So, I'm almost thinking of them as a single adjustable damper. Again, this is all a guess as I don't have dyno plots.
    Registered User rtstone's Avatar
    New Jersey
    Quote Originally Posted by wrx wagone View Post
    Hey Tyler! Hopefully I'll get to see you out at some events this year?
    These bushings are legal as they are an offset bushing that uses the OE mount.
    So it is the mount that is the problem? So if I bought the Perrin kit it would be illegal, but the whiteline isn't becuase you are not replacing the mount? confused.......
    I hope to get out this year too, but already the first two events I am going to have to scratch off the calendar, my daughters Christening is April 19th, and I am doing the Pocono east course HPDE on May 3rd so those weekends are out of the picture. I am going to try to get a few events but by no means worried about being competitive.
    2006 WRB WRX Wagon
  6. #19
    Registered User Pzary3233's Avatar
    Jan 2006
    Tallahassee, FL is home... Memphis, TN for school
    Quote Originally Posted by rtstone View Post
    That is incorrect. You buy the Whiteline ALK, and you are illegal. you must by the offest bushing that does in the STOCK bracket.
    JR, that's interested on the brace and as I read it again that does sound like it is legal! Send a friend a PM on those rates :-)
    By the way, those red 4 pots also make a nice little indention in your forehead!
    2002 PSM WRX <- going back to stock Suspension parts GALORE for sale!
    The Project STX Sedan Build Thread
    Race hard or go home!
  7. #20
    May 2005
    Phillytown, PA
    Quote Originally Posted by Pzary3233 View Post
    That whole line of discussion just confused me, so I'm going to clarify. I think we'll all talking the same thing, but just to be sure...
    Tyler, you are correct. Any ALK replaces the stock mount with a lower mount. It is the act of replacing the mount that makes the ALK illegal. The Whiteline KCA375 bushing is simply an offset bushing that reuses the stock OE mount and is therefore legal. Also, the KCA375 bushing is NOT an ALK.
    Paul, PM sent.
  8. #21
    Jan 2006
    Thanks for the better clarification.
    PM responded.
    I must say I am a big fan of these build threads, it makes it easier to keep our builds in mind when talking about setup!
    Do you guys have any big events up your way mid summer? I've gotta go visit family!
  9. #22
    New Jersey
    thanks for the clarification
    I didn't know that the mount was different than stock on the ALK. got ya.
    So I am interested in the difference in caster you see whith that bushing, and also to see how that translates to feel and response in the car. Seems like a worthy mod.
    I was looking to go to all group n bushings but I am going to wait till next year and hopefully redo my entire suspension
    2006 WRB WRX Wagon
  10. #23
    Jul 2001
    the ALK does three things- removes some of the anti dive/lift that the factory dialed in, increases static positive caster, provides a firmer rear bushing
    the ALK mount is different than stock- thus the requirement of shimming the subframe slightly
    the offset bushing accomplishes two- typically adding more caster (usually in the .5 degree range) and adding a firmer bushing
    visiting w/ WL a person could orientate the bushing another 90 degrees and have some effect on anti-dive/lift, but you'd see no change in caster
    JR my memory sucks- I'll send you a pm
  11. #24
    May 2005
    Phillytown, PA
    I'm planning on having a big event on the weekend on Aug. 9-10th. It's our Hobert memorial. Two day event, run very much like a national event. We'll should also have a good bit of national competition as well from our Region, WDCR, & NNJR
  12. #25
    Jul 2001
    finally got under the car and got this figured out
    the offset goes outboard of the center line "pushing" the wheel slightly forward (positive caster)
  13. #26
    May 2005
    Phillytown, PA
    Bingo.
  14. #27
    Jan 2006
    That would be about the right time for me to head up there... humm... Keep me posted!
  15. #28
    May 2005
    Phillytown, PA
    Also to update, I had a very nice discussion with Poltec about my issues with my rear endlinks. I'm going to get them measurements over the weekend, and they will get me the length endlink I require. So far, I've been very pleased with their service.
    Update on Poltec: I got Poltec a few measurements of my rear swaybar dimensions to make sure the replacement parts they send will work. They should be sending the parts out today.
    Sadly I will not have my coilovers back before this weekend, so I'm going to miss our first event. It's not a points event, but I was hoping to start collection some setup data. I actually may have a weekend off from working on the car which would be quite nice.
    Will do.
  16. #29
    Jul 2001
    JR did you have to send your coilovers back in?
  17. #30
    May 2005
    Phillytown, PA
    I did send my rear dampers back to Tein. The whole process has been a little backward, but they have been very helpful. Paul over in their tech dept. so far has been fantastic.
