Teh Cone Dodgin' STX Wagon - Page 18
Page 18 of 20 FirstFirst ... 891011121314151617181920 LastLast
Results 256 to 270 of 289
This is a discussion on Teh Cone Dodgin' STX Wagon within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; So ... where are these alleged new goodies?...
  1. #256
    Apr 2004
    Southeastern PA
    Mods & Pics
  3. #257
    May 2005
    Phillytown, PA
    Quote Originally Posted by 04.SPT.WRX View Post
    In my garage waiting to get put on.
  4. #258
    Apr 2004
    Southeastern PA
    Quote Originally Posted by wrx wagone View Post
    In my head waiting to get put on.
    :yawn:
    Mods & Pics
  6. #259
    Registered User 012.5RS's Avatar
    Feb 2008
    PA
    lookinh good man, id also be interested in a snow x and even a rally x. Ur thread has also been helpful to me. i wanna eventually auto x my bugeye and am gonna be starting on getting parts and the suspension tuned over the fall/winter to hopefully be rdy for next year.
    Power Is Nothing Without Control.
    Bugeye Mafia #221
  7. #260
    Oct 2005
    Late Devonian
    Hey JR & Mike,
    I tossed a coin to decide which of your threads to hijack, & JR won.
    I missed the boat on RCE wagon springs it seems after talking to Myles on the phone (unless I can drum up 20 customers).
    He is pondering whether it would work out to run a set of yellows in the front and a set of blacks in the rear.
    Any thoughts on how that combo would play out in terms of balance and drop?
  8. #261
    Oct 2005
    Late Devonian
    Sorry if that came out of the blue or was rudely put. I just thought you guys would be most likely to have some experience with people running this combo. I'll start my own thread on it & sorry for the hijack.
  9. #262
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    JR's moving this weekend. Between house buying & engine rebuilding, he hasn't had much time to be on the forum.
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
  10. #263
    Oct 2005
    Late Devonian
    Quote Originally Posted by devilfluff View Post
    In that case, sorry if I seem impatient
  11. #264
    Jul 2001
    Plains of Eastern Montana
    Hey JR & Mike,
    the spring rates are close enough that part of the equation would work
    the black springs lower a little less- so on the rear w/ a wagon where you see some additional drop- it may turn out to be a even drop front/rear
    one thing to remember is that the stated drop for the yellows is for a STi- as the STi starts life a .5" lower than the WRX you need add an additional 1/2" to the lowering which could make it too low?????????
    Mike
  12. #265
    Oct 2005
    Late Devonian
    Mike
    Thanks Mike, I think that is going to be too low for my driveway (aside from potential geometry issues). Looking at their 23mm + 12mm would be 35mm total in the front. I finally found the numbers from the RCE wagon specific springs thread where the guy mounted the yellows on a saabaru and he ended up saying ~40mm for the front drop.
  13. #266
    Jul 2001
    what about black and black? any issues w/ the rear possibly being too low could be resolved easily w/ a spacer
  14. #267
    Oct 2005
    Late Devonian
    You know, that is a real good thought. I really don't want much drop, just the rates.
    Hmmm, looking at their site they say (for STi) 15mm/10mm, so that would be like 27mm/22mm. That sounds reasonable. But the one example I found so far was supposedly at 13.5" F&R, so (after subtracting 8mm for lowering camber plates) 35mm/26mm which again sounds like a lot in the front. I'll have to search some more - thanks again.
  15. #268
    Jul 2001
    what dampers are you running?
    if they can handle the rates, the STi Tarmac springs might make a good choice- that's what I ran on my wagon- (I also had the RCE lowering plates) lowering was just about an even 25mm front/rear
  16. #269
    Oct 2005
    Late Devonian
    I'll run the Konis - I don't have the plates, sorry that was not clearly explained but the wagon example I was basing the drop from had them. Was yours 25mm with the plates or without (I assume with, putting me at ~18mm F/R)? Either way sounds pretty good actually.
  17. #270
    Jul 2001
    that was w/ the lowering plates- the lowering plates (~8mm) lowering is about the same you see in the rear w/ a wagon- so basically lets you run sedan springs and get an even drop f/r- of course it's ~ 8mm lower than they would be on a sedan that had oe tops
    the other option is use a non-lowering camber plate in the front (RCE or Vorshlag) and then use a small spacer from Paranoid on the rear- you'd be looking at closer to a 20mm drop w/ that setup
    I just re-looked up my ride heights and it was 30mm of lowering, not 25mm
