Page 10 of 20 FirstFirst 12345678910111213141516171819 ... LastLast
Results 136 to 150 of 289
This is a discussion on Teh Cone Dodgin' STX Wagon within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; Wow, AWESOME!!!!! I'm glad someone's Motorsports weekend went well.... See my build thread for the details......
  1. #136
    Registered User Pzary3233's Avatar
    Jan 2006
    Tallahassee, FL is home... Memphis, TN for school
    Wow, AWESOME!!!!!
    2002 PSM WRX <- going back to stock Suspension parts GALORE for sale!
    The Project STX Sedan Build Thread
    Race hard or go home!
  2. #137
    Jul 2001
    Plains of Eastern Montana
    congrats on the finish!
    curious- what'd they charge for the hub/bearing install? just did one side?
  3. #138
    May 2005
    Phillytown, PA
    One side, new hub needed, $550.
  4. #139
    Jan 2006
    Could be worse, glad they actually had the hub!!!
  5. #140
    Jul 2001
    Quote Originally Posted by wrx wagone View Post
    ouch!!!
  6. #141
    May 2005
    Phillytown, PA
    Quote Originally Posted by Pzary3233 View Post
    and where able to install all the parts that afternoon.
  7. #142
    May 2005
    Phillytown, PA
    So, I will be getting a new set of comp tires very soon. Like if not by the end of the week than early next week. I will be going with a set of the Dunlop Direzza Sport Z1 Star Specs. I that name isn't long enough, I don't know what is. Sometimes I think that the longer the name of a tire is, the faster it will go.
    I do feel that I have a bit of a dilemma and that is should I continue to use a 235/40/17, or should I make the jump to the maximum allowable tire per class rules and go with a 245/40/17.
    Tire Size Debate
    Pros: I will have more rubber on the pavement.
    Cons: I will have a bit taller tire which will have a negative impact on gearing and acceleration. I also am a bit concerned that I can actually fit a 245 under the rear fenders of my wagon legally.
    I have been giving this question some careful thought for quite sometime and still haven't come to a conclusion and to make matters worse this last weekend at the DC ProSolo, Greg McCance (last year's ProSolo Champion) was running on 245/40/17 Star Specs. He seemed to be doing just fine on his, beating me by 1.4 sec for the weekend and also getting 1.8 sec. 60ft. times as compared to my 2.0 sec. times. Acceleration does not seem to be a problem there.
    So racin' guys, what to do?
    Hmmmm... I can't wait.
  8. #143
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    235. Stars are wide. Really wide. I know - trust me.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
  9. #144
    May 2005
    Phillytown, PA
    Quote Originally Posted by 04.SPT.WRX View Post
    I figured you say as much, but the 245's are wider.
  10. #145
    Jul 2001
    I was in such a quandary over those two choices I started a thread over on nasioc last year on the subject. Most input (this was from some very good competitors) said the better gearing outweighed the additional rubber.
    Clearly a good competitor has successfully gone the other way (the 245/40 is still slightly shorter than oe- so there is still some gearing advantages)- tough choice, very tough choice.
  11. #146
    Jan 2006
    Humm... my gut reaction says more tire... Is the gearing difference REALLY that much more noticeable?
  12. #147
    Jul 2001
    I can't say between 245/40 and 235/40, but between oe height (25") 225/50/16 and 235/40/17 yes- noticeable
    the other thing that enters into the picture as well is the fitment of the tire to the rim a 235/40 on a 8" rim is almost perfect IMO- very "squared", a 245/40 while certainly not flopping around the rim is a probably a little less than optimal- sidewall stiffness is effected by the relation of rim width to tire width
    not an easy decision
    here's the thread, worth perusing
    235/40/17 vs 245/40/17 STX - NASIOC
  13. #148
    Jan 2006
    Ahh yes, that thread! I remember it!
    I was thinking 245/40s until I read that thread, now it's back to 235/40s!
  14. #149
    Jan 2004
    toledo
    JR
    It was great to meet you and great competing with you. And thanks for the kind words.
    The 245/235 battle comes down to what you want. I do not think you'll be disappointed with the 245's or that you'd notice the slight increase in height.
    As I said I can spin either set out of a corner.
    Mike makes a good point about fitment on an 8" but I really don't see drastic negative effects as far as sloppy turn-in or roll.
    I want as much rubber as legaly allowed on my car. The 245 Dunlops are certainly wide.
    Good luck with the wagon development, I'll be watching...........closely.
    Cheers
    Greg
    2002 78STX
  15. #150
    May 2005
    Phillytown, PA
    Quote Originally Posted by McCanixx View Post
    I had a great time meeting you as well. I always enjoy good competition to help make me faster. It's a shame I'm not going to the Toledo Pro and you're not going to the FL Pro.
    These are the exact points that I'm currently pondering. I may need to go with the 235 simply due to fitment issues on the rear fenders. I may not be able to legally get a 245 on my car. If I do go with the 235, I will only lose about a 1/4" in tread width which really isn't much.
    Thanks, If you have any tips to add, please feel free.
