The Project STX Sedan Thread - Page 7
Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 91 to 105 of 162
This is a discussion on The Project STX Sedan Thread within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; Originally Posted by Pzary3233 5x114.5 Bolt Pattern!!!!!!!!!!! WTF!!!!!!!!!!!!!!! What??!? Did you buy the car used?...
  1. #91
    May 2005
    Phillytown, PA
    Quote Originally Posted by Pzary3233 View Post
  3. #92
    Registered User Pzary3233's Avatar
    Jan 2006
    Tallahassee, FL is home... Memphis, TN for school
    Alright, turning the wheels, and it's a spring like sound, it sounds like the springs are rotating when they should be stationary in relation to the strut housing.
    Sorry for the vagueness... I can go take a quick vid if needed
    2002 PSM WRX <- going back to stock Suspension parts GALORE for sale!
    The Project STX Sedan Build Thread
    Race hard or go home!
  4. #93
    Registered User ButtDyno's Avatar
    Apr 2003
    Alexandria, VA
    Check my thread for the part about the sproing - Mark from GC gave me advice on that and it did work. It sounds like it might be the same issue or similar.
  6. #94
    Jan 2006
    Quote Originally Posted by wrx wagone View Post
    yes...
    Quote Originally Posted by ButtDyno View Post
    Searching!
    Found it!
    That is sort of like the sound. I do get that sound but it's more of a continuous sound like a creaking door, but really loud.
  7. #95
    Jul 2001
    Plains of Eastern Montana
    the R32 is a pretty capable car, I wouldn't be surprised w/ another full year under their belts to be in thick of things this year (they faired pretty well last year)
  8. #96
    Jan 2006
    It seemed like a light car.
    The one big complaint that i had was the center diff noise, and the HEAVY STEERING!
  9. #97
    Jul 2001
    that's what 7.5 degrees of caster will do
  10. #98
    Jan 2006
    It sucked in the tight sections but was BEAUTIFUL in the flowing stuff!
    It was very interesting to get back in the WRX to limp it home with a plug in the tire... The steering was too light...
    Mike, any idea on the GC/RCE Plate bit?
  11. #99
    Jul 2001
    it's possible the spring is either turning on the bottom (strut perch) or the top (under the upper perch)
    here's one possible solution for the lower perch
    NASIOC - View Single Post - Ground Controls and shocks discussion
    the upper could possibly the bearing binding, this appears to be pretty common w/ the new WL plates, but I haven't really heard it much w/ the RCE plates (although JR was getting some creaking)
    also look at John's build thread- he found a little squeaking gremlin (and a fix )
  12. #100
    Jan 2006
    It is indeed the spring turning. I'm going to mark the spring position relative to the lower perch, and upper "cone" go for a drive and then check.
    I have a feeling it is binding at the bearing in the camber plate... :-( because my passenger side is quiet as can be!!!!
    Though that is another good idea, I'm going to try John's first and see if that helps!
    The GC tech guy almost had me pulling out my CC for their Camber plates!
  13. #101
    Registered User tuskenraider's Avatar
    Aug 2004
    Chicago area
    Well mine are a little cheaper if it comes to that............Koni race inserts, GC Coilover kit, GC F&R Camber Plates, Eibach 2.5" Springs - NASIOC
  14. #102
    Jan 2006
    Well humm... If I didn't just buy some STi wheels...
  15. #103
    Jan 2006
    Alright, it pains me to do this, but the project is on complete hold at the moment. Some things have come up and I need to possibly sell all the corner carving bits and pieces to take car of life.
    Look for a forsale thread in the near future with most all of the parts from this build...
  16. #104
    Registered User Web Foot STi's Avatar
    Jun 2003
    Portland, OR
    Well that sucks. Hope everything works out.
    Cones don't count at Hillclimbs.
  17. #105
    Jan 2006
    ^ Thanks...
    I think the plan is to run D Stock...
    STi wheels are posted:
    http://www.clubwrx.net/forums/person...-bbs-gold.html
