Lift time FTW! Going right now!
This is a discussion on The Project STX Sedan Thread within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; This weather FREAKING SUCKS! So this spring clunk sound up front in slow turns is driving me up the wall! ...
I got my 225/50/16 Kumho MXs today, they actually fit in the back seat! I'm getting them mounted up tomorrow I hope!
2002 PSM WRX <- going back to stock Suspension parts GALORE for sale!
The Project STX Sedan Build Thread
Race hard or go home!
Alright lift time was rushed so I had just enough time to mount, balance, and install my IA performance KPH to MPH converter before I got kicked off.
Then now what everyone is waiting on:
So I got the car aligned today, thank you to my good friend Donald!
Front:
Camber -2.5 Degrees
Cross Camber -0.1 Degrees
Caster: 3.4 Degrees (WITHOUT the offset bushings)
Toe: -1/16 toe (ie Toe out)
Rear:
Camber -2.1 Degrees
Cross Camber -0.1Degrees
Toe: 0
So a BIG $#^%$$@%$$ to the camber plate and spring combo! the RCE plates still have a lot of adjustment left in them but the spring hits the plate at around -2.7 degrees of camber... So we backed it off to -2.5 degrees to be safe until I figure out what is going on.
I am STOKED about the rear camber! That is with Group N Top Mounts, and a STOCK wagon strut. No eccentric bolts or Adjustable lateral links. this is STOCK STUFF!
All of the alignment stuff was done with me in the car after it was roughed out so it should be spot on while driving the course. Now i just have to call RCE and get some info from them.... UGH!
A note on ride height: 35mm lower was a tad bit too much lower than I should have gone, I raised it back up a bit because I noticed that the bump stops were chilling out way up top and I had not taken any hits where I felt that it should have been riding on the bump stops. once that was fixed and the alignment done, the car rides like a dream, the dampening of the Konis feels spot on, and the car handles VERY WELL in the wet stuff. Really controllable, turn in feels good, etc.
The Kumho MX tires ROCK!!!!! I can already tell a huge improvement over the grip of the Hankook R-S2, They also feel much better in the wet stuff as well.
geez- good alignment guys! nice to see folks w/ some pride in their work
the good news is you going to need another alignment anyways when you do the offset bushings
my guess is your going to need a different upper spring perch- w/ the narrower (I believe Eibachs are 2.5") springs you should be getting better than -2.5- w/ stock spring you can get even a little more than that- the limiting factor w/ stock springs is they actually hit the strut tower- they can't go any further period
curious- are you using the oe domed washer?
how far did you come up on your ride heights?
JR, i think I can get around this with going with a spacer on the strut shaft, that is about 3/8" which would negate the use of the baller camber plates. But that would make it work. Then I can have a bit more adjustment from there, might not even have to be 3/8".
Mike, I came up two full rotations of the collars all the way around. I'll measure in the morning when it isn't raining.
the domed washer is the oe washer that sits atop the oe upper front spring perch- it engages the bearing in the camber plate (or oe top)
not installing it or having it upside down w/ the oe top can cause problems w/ memory steer and the like
the RCE plates are designed to use this washer (unless some other provision is made by the aftermarket coilover)
this extra room may also net you some additional room- I'd definitely check w/ RCE (and maybe GC as well)
JR- your -2.7 was w/ oe style springs- Paul has 2.5" springs and thus more room to move within the strut tower- I believe his "problem" is w/ the interface of the upper spring perch and the camber plate
Don't most things that reduce grip from the rear (bigger bar, stiffer rates, toe out, etc) make snap oversteer more likely?
There are a billion ways to skin the cat, for sure, but in terms of bang for buck a $40 set of camber bolts is pretty good![]()
