anybody ever run leaded gas?
Results 1 to 15 of 17
This is a discussion on anybody ever run leaded gas? within the Motorsports Talk forums, part of the Community - Meet other Enthusiasts category; i heard that i could have a high octane map made to switch to at the track. then i would ...
    Registered User thejinxin206's Avatar
    Sep 2006
    seattle
    i heard that i could have a high octane map made to switch to at the track. then i would run more boost and 116 octane. any body do this before? i want to try it. i have run 101 octane in my car at at stage 2 with no special map and deffinately feel the power increase. but i know that the lead will mess up my o2 censors kinda fast. just want to know what people say. thanks. jinx
    <----------Bugeye Mafia #143
    <----------have pulled .97 lateral g's in a wagon
    <----------provides clean urine for the russian olympic team
    <----------tuned by Sean McCormick (R.I.P. 2/2008)
    Moderator timber's Avatar
    St. George, Ut.
    Quote Originally Posted by thejinxin206 View Post
    Don't quote me, but if you have any cats in your exhaust, I think leaded fuel will screw them up...
    "Never Launched"
    Dougie
    - Founder, 250,000 mile club
    -5,000 posts
    Apr 2004
    Southeastern PA
    Quote Originally Posted by timber View Post
    Yep.
    In order to take advantage of the extra octane, a custom map would be needed.
    Mods & Pics
    Registered User ForesterS/tb's Avatar
    Apr 2007
    Lima
    We all have used the av gas 100LL the entire drag championship. As you may know its a low lead fuel used (for years) instead of actual race fuel. Well, my O2 sensor is still fine and nobody on his wrx/Sti or EVO has reported damages or malfunction because of this.
    cheers!
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Its the O2 sensors and CAT's that don't like you when you run leaded fuel, But I'm sure if you ran a CAT-less exhaust and were tuned for the race gas your o2 sensors would last for a while. Just don't be too surprised when you have to change them in 20k miles (at $200 each).
    Noteworthy, you can get High octane unleaded fuel you know.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Nov 2007
    they still make that S--T!?
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Unleaded race fuel:
    http://www.sunocoinc.com/site/Consum...UnleadedFuels/
    Sunoco 260 fuel (100 octane) locater:
    http://www.sunocoinc.com/site/Consum...T100Locations/
    As far as I know, there isn't anything higher than 100 unleaded sold these days.
    As for the use of 100LL (Aviation fuel), it is hard to pin down the good-vs bad using a low leaded, high octane fuel in an automobile. Some have reported success, others have reported issues with the heat generated burning or melting valves. I've only ever heard the negatives from "friend of a friend" type sources, so take this however you want it.
    Obviously ForesterS/tb has first hand experience using this, and from the sounds of it, has not damaged his O2 sensor as of yet. For the price, it's a pretty good deal, so I can see the monetary benefit in using it over 100 octane unleaded fuel.
    My personal thoughts are that if you are running at the drags strip or on a road course, and have the ability to alter your map (timing and injection) to make full use of higher octane fuels, this is an excellent and cheap way to make good power. Since my performance cars have usually been daily drivers, I tended to do this sparingly as the performance difference is pretty significant, and is obviously more harsh on the engine. But then, I tend to lean towards a more conservative tune anyways, so take this into account.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Jun 2006
    Nor Cal
    Looks like VP Racing makes Unleaded 105 & 109 rating:
    http://www.vpracingfuels.com/vp_01_fuels.html#unleaded
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Apr 2007
    Lima
    Quote Originally Posted by YBNormal07 View Post
    x2
    I agree. For us, the use of "av-gas" is limited to drag races only. However there are some guys that use av-gas in a 50-50 mix condition with 98RON for daily driving. Normaly this guys has JDM cars and want to release the full potential of their cars (Im not too convinced about that but....).
    Nobody (including me) has reported a 02 sensor malfunction linked to av-gas, moreover, a friend of mine that uses his JDM EVO VIII with av-gas in a 50-50 rate for daily driving has not reported any problem at the moment.
    If you guys have actual race fuel (unleaded, oxigen charged, actual RON>100) available, use it, definitly is a "better" option than av-gas.
    cheers!
    Sep 2006
    seattle
    i know that about 20 min from my house i can get unleaded 101 octane any day of the week from like 9 am till 11pm. it is however $6.25/ gallon. that i run every now and then. and sometimes when i goto the track, just to see if it helps, but it never makes enough difference to be sure it isn't my driving. i am not that consistent. and i never run it straight. always run it with 92 supreme. usually when the tank is pretty low as to save me money, but i know that sounds silly running that at $6.25/ gallon. i think i'm just gonna try it. the only problem is that they won't let you pump it into your car. you have to pump into an approved container. i think that is b/s, but it isn't legal to run leaded on the streets here in seattle.
    Sep 2006
    seattle
    Quote Originally Posted by ForesterS/tb View Post
    x2
    cheers!
    i don't know if it is that RON100 that you talk about, but i will ask. is all gas oxegenated?
    Apr 2007
    Lima
    the Sunoco 260Gt is marketed as a 3.3% oxigen charged fuel + 105RON + unleaded gas...is that correct?
    Registered User wunderboy987's Avatar
    Nov 2007
    nj
    what about octane booster? that little yellow bottle
    Hawk-Eye Alliance #898Military Milita #898
    AP stage 2 93 oct. maddad DP. SPT short ram intake,SPT intake heat shield,HKS carbon fiber catback,boost,MAF,volt gauges,STI springs, pioneer flip screen headunit, polk audio speakers, vortex generator,STI wing,rally armor UR flaps
    Jul 2003
    PA
    Quote Originally Posted by wunderboy987 View Post
    just say no.
    Race gas is by far a cheaper and better investment.
    Jul 2003
    PA
    If you don't have EMS to ajust timing and fuel to make full use of higher octance fuel, it really isn't going to give you much of a performance advantage. However, when you do use it, you should reset your ECU and run it for about 15 minutes prior to racing as the stock ECU will adjust your timing to some extent to allow more use of the higher octance fuel.
