With 2wd, you only have two tires spinning on launch, so you need to spin tires to heat them up so they have traction on the launch (assuming drag tires of some type). Think of it like melting rubber and then letting it harden until it sticks to the road..this is how you get a good launch with 2wd.
With AWD, you have 4 tires spinning on launch with a better weight distribution too. You don't need to spin the tires prior to launch to heat them up as 1) you don't want the tires to stick as you'll likely break something if they do
and 2) the AWD gives plenty of traction when spinning off a launch so there really is no need. Anytime you can achieve less than 1.9 60 foot times on street tires, you are doing fine.
LinkBack URL
About LinkBacks
