ClubWRX 1/4 Mile Ranking List - Page 22
Page 22 of 25 FirstFirst ... 1213141516171819202122232425 LastLast
Results 316 to 330 of 362
This is a discussion on ClubWRX 1/4 Mile Ranking List within the Motorsport Stickies forums, part of the Motorsports Talk category; I have a customer with a 02 wrx that is stg 2 with a header up pipe combo on it ...
  1. #316
    Registered User PREracing's Avatar
    Nov 2006
    GRESHAM, OR
    I have a customer with a 02 wrx that is stg 2 with a header up pipe combo on it and he runs 13.0 flat and he gets high 1.6 and low 1.7 60 ft times, I get mid 1.6 60 ft times in my wifes forester, and another customer runs mid 1.6 60 ft times in his 2003 wrx with hybrid build. so it is possible to get there but its more than just power that gives you the ability to get good 60 ft times. on a lower power stock turbo wrx the key to getting a good launch is all in the wheel and tire choice. we have always done best with stock wheels and stock tires aired up to about 55 psi. you get some wheel spin but not to much and then it takes off. hope that helps.
    thanks-
    bobby
    bobby@preracing.com
    Performance Race Engineering
    503-619-0055
    preracing.com
    Follow us on Twitter
    Friend us on MySpace
  3. #317
    Jan 2010
    Missouri
    I was running the stock 16x6.5's on Dunlop Firece Instinct all seasons 225/50/16 in around 35 PSI
    I will say Ive noticed that the tires SUCK for hooking in dry conditions, I was slipping the clutch on my best runs. I tried a few times dumping it or slipping it a little more aggressively but bogged or spun instead of hooking up. That 60' was my best, I had several 2.1's and 2.2's.
    05 WRX premium 5mt - Testestuned Stage II
  4. #318
    Nov 2006
    GRESHAM, OR
    there are 2 known ways of launching your car to achieve good 60 ft times, 1 is slipping the clutch just right and away you go. the other is spin the tires in a controlled manner. I prefer to spin the tires as they are alot cheaper and easier to replace. I start off at about 50 psi in the tires and i start out holding the rpms at about 5500 rpm. when I am about to go I drop the clutch as fast as I can and I floor the gas at the same time so basically by the time the clutch is fully out my gas pedal is fully pressed to the floor. it should spin all four tires for about 1 to 1.5 seconds and then tear out of the hole like never before. if you get too much spin then lower the tire pressure, if you dont get enough tire spin then raise the tire pressure. I never go over 65 psi if I still cant spin at 65 psi I either raise my rpm I am starting from or I line the car up outside of the groove so the isnt as much traction. also I never go below 25 psi in the tires if I am still spinning too much then I lower the rpm I am starting at. hope that will help you a little the next time you go and race your car.
    thanks-
    bobby
    bobby@preracing.com
    503-619-0055
    preracing.com
  6. #319
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    when I get any sort of slip at all (besides the chirp) my 60ft times shoot to 2.0 and my ET's shoot to 13.9's...
    My best is a 1.81 60ft w/ LC at 5200rpm. I slip very very fast, but no drop.
    I just don't get how that 02 WRX is getting 1.6's... Altitude doesn't affect 60ft THAT much, does it??
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  7. #320
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    List updated.
    Nice posts on launching. FYI, when you adjust your tire pressure, always start high and go down from there.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  8. #321
    Registered User INTA:LECT's Avatar
    Jan 2010
    Colorado Springs
    Driver mod maybe?
    I know of a guy in denver with a stage 2 07 that runs 13.7 at bandi...
    There's a guy locally with an 09 stage 2 that ran 13.7 at pmi, i ran his buddy who's got an 09 stage 2 that runs just as well, i managed to pull about a car on him...
    with 293whp 346wtq i'd imagine your car has a lot better than a 13.4 in it. You should be able to cut a 1.6 60' with that much tq.
    2007 Obsidian Black Pearl WRX TR
    3" Catless TBE, Protune, Tein Springs, TurboXs MBC, Apexi Turbo Timer.
    HawkEye Alliance #187
    Vote for my group UNTAM3D's new single "Gotta Go" to get rotation on 96.1 FM Radio!
    VOTE FOR US NOW!
  9. #322
    Jul 2003
    PA
    I believe you would need some drag radials or slicks and a healthy drivetrain to achieve a 1.6 60 ft.
  10. #323
    Registered User turbotwist's Avatar
    Dec 2008
    ri
    Quote Originally Posted by YBNormal07 View Post
    did a 1.7 with snow tires at new england dragway. With my toyos should be able to get high 1.6s
  11. #324
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by INTA:LECT View Post
    Driver mod maybe?
    I don't buy the stage 2 07. Complete horse crap. Look at the allwheeldrivepirates website and the numbers from local drivers at bandimere.
    The 293whp is adjusted to sealevel... here it's about 252... which is quite a fair amount. I buy the 09 stage 2 at pueblo getting 13.7. Pueblo is at 4600ft... bandimere 6000ft. His 09 stage 2 would probably get about 14.0 up here.
    That "driver mod" comment is a pretty big fall back. Come out to bandimere and see what you can get
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  12. #325
    Registered User 2004NeonSRT4's Avatar
    Jan 2004
    Oxford,PA
    first time at the track with the stock 04 sti last night. track was horrible. no traction even for a awd car. weather was nice high 70s very mild humidity. third and last pass of the night was my best. didn't see a point in beating it up more to go any faster. a sticky track and a cooler day is what it needs.
    1.821 60ft
    5.511
    8.508
    80.99 mph
    11.108
    13.388
    102.89mph
    13.388SEC/ 102.89 MPH/ 1.821 60f /45 ft / 04 sti /2004neonsrt4
    RayfieldsWRX - "You like the feel of torque steer? Interesting"
    jd92677 - "I like the idea of mashing the gas and not knowing which way the car will go."
    -02 WRX 13.8@96 stock SOLD
    -04 SRT-4 626whp SOLD.
    -04 STi 13.3@102 stock. SOLD
    -04 SRT4 388whp DD SOLD
  13. #326
    Jan 2005
    Hagerstown, MD
    Change my time to a 10.353 @ 137.69 mph with a 1.51 60ft please!
    Exact same setup as last year except for different wheels and tires and a rallispec 6spd. This was the first time out on the new trans and the syncros were definately tight still which slowed shifts way down. The track was also prepped horribly and spun to a 1.51 60ft. With good clean shifts and my normal 1.4 60fts the car had a 9.80 - 9.90 @ 140mph pass in it for sure. I have a head gasket leaking so the motors coming out and im finally going to build the heads, never accomplised my goal of going 9's at over 140mph on stock heads with aftermarket cams but oh well. Trying to go deep into the 9's @ 145+ mph on a stock sleave bottom end.
    http://www.youtube.com/watch?v=PB55CNXSAbs
    05 CGM STI
    10.35 @ 137mph
  14. #327
    Nov 2006
    Denver Metro Area
    congrats!!
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  15. #328
    Registered User R Hole's Avatar
    Jun 2010
    South Auckland, N.Z.
    1/4 mile 13.762 @ 103.080 mph
    1/4 mile 13.762 @ 103.080 mph : 60 foot 2.116
    2000, WRX STi Type R V6, Stock running gear 117,000ks/Tein Adjustable Suspension
    Sea Level, Air temp 16'C
    40yrs driving Exp, 1st time on a Dragstrip, R Hole
    I think the car could do low 13s maybe even a 12.9 with a competent driver.
    My best time of the day from 14 runs.
    Champion Dragway, Meremere, N.Z. 30/5/2010 : R/T .370 : 60 foot 2.116 : 330 foot 5.856 : 1/8 mile 8.939 @ 78.670 mph : 1000 foot 11.571 : 1/4 mile 13.762 @ 103.080 mph
    Hey
    ( it's just my opinion, besides my WRX it's all i have )
    Disclaimer
    I cannot guarantee the accuracy nor intelligence of my opinion. But promise to express it free of charge.
  16. #329
    Registered User keifer75's Avatar
    Richmondville NY
    07 WRX TR
    13.1 @ 102
    Mods:
    turbo x replica turbo back, dom tune, vf39. Temp was around 70 degrees. suspension is progress springs and tires are Falken FK 452's.
    Naturally Aspirated Definitely Sucks
    www.nadsny.com
  17. #330
    Registered User Les Bill's Avatar
    Nov 2009
    Damn Md05Sti that is just nasty... congrats!
