This is a discussion on ClubWRX 1/4 Mile Ranking List within the Motorsport Stickies forums, part of the Motorsports Talk category; yes sir!...
yes sir!
2012 Lightning Red WRX
Sold: 2006 Sti
Sold: 07 335i coupe Monaco Blue
Thought I'd bump to mention that at 8633ft DA I got a 1.88 60ft, but only a 13.80The weather was horrendous... not drag weather at all. But the 1.88 60ft made me ecstatic. At 6000ft, I would have beat my 13.6 best time
(Btw... the C6 that I raced got 14.46)
tEh PriUs=teH faSTah!@@!
306 AWHP/341 AWT, Stage 2
Im debating whether i should run my car this sunday at subaru vs evo day at englishtown....i really want to know what i run, but i dont want to slip my clutch. Would i bog like a mofo if i dump my clutch? (since you guys are familiar with the ground)
Bugeye Mafia #213
Kevin
2002 Midnight Black Pearl WRX (Traded In!)
2012 Ice Silver Metallic STi Sedan
I know Englishtown quite well...very sticky staging area...up the pressure in the tires to 40psi or so and skip the AWD burnout attempt. A little water on the tires might not be a bad idea either if you want to drive through the burnout area.
Are you modded at all? How much power are you putting down to the wheels? I don't think its a great idea to just straight dump the clutch as opposed to a controlled dump or quicker slip...rev up to about 5500rpm when the tree is staging, and when it hits green, release the clutch quickly, but controlled. If you release when you're in the correct RPMs, you should drop right down into your powerband and build quick boost, minimizing any chance at bogging. You should get a little wheel spin then just take off like a bat out of hell once you get the traction![]()
yea my mods are in my signature or my profile. I just didnt want to burn my clutch since i just got it put on about a month and a half ago. Should i just wait until i change my suspension, since my back is sitting lower than my front? I also wanted to get launch control. Third thing is that it's going to be hot so i know that my car won't be at its full potential. Is it worth running the poor 1/4 mile time?
Bugeye Mafia #213
Kevin
Yes it is....
Because everyone else is going to be running in that hot weather too, and Drag Racing isn't about seeing who you can beat... it's seeing how much you can beat yourself by!
Oh hell I didn't notice you had an STI tranny and a 16G...dude beat the hell out of that thing, it can take it
Seriously though, don't abuse it and bang gears around...but the clutch can handle some serious launches. The method I explained should actually be perfect for an STI tranny with your power. Given a 16G, you are probably seeing full boost by 3400rpms, so just rev up to about 5900rpms and do the controlled fast slip. You should be good to run a 12.3 @ 107+ mph or better with that power and an STI tranny, provided you get a good launch at Englishtown
+1...couldn't have said it better myself.
...even though it does feel good knowing you can take down a random Evo or 335ci or something like that![]()
Definitely!I've got a lot of good races under my belt. 335xi, Corvette C6, Camaro SSs, Mustang GTs, a few Mustang Cobras, a few mild STis and Evos, a super charged hemi cuda, a 442, all kinds of stuff. But I don't go to win... I go to learn how to drive better
That 12.3 would have to be with a lot of practice. (That's why you go!! To practice!) I'd guess just shy of 13 for a first run.
In the matter of 3x going to the strip I went from 14.2 to 13.6. Now My best runs are between 13.6 and 13.8 depending on the weather and my 60ft.
13.85/98.8mph/elev. ? norwalk, oh/02 wrx wagon
Turbo xs tbe , sti up-pipe
Cobb v1 ap stg2 93oct.
k&n panel filter & silencer delete
Cobb short throw, Redline Non syn. trans. gear oil & synthetic in the diff.
Cooper zeon rubbers
2yrs -1yr license suspended
slip clutch, shift fast, revv third out like like never before.
60ft. was not recorded most likely because it was a high school event.![]()
Thats awesome! I have a 335ci, couple Camaros, a handful of Mustangs, Civic SI, numerous WRXs, STI's and Evos...and others, but I haven't been in well over a year now though and I no longer have my STI
I'm estimating his time with his power...I could have hit 12.3 with my protune but after I got it done, I never made it to the track. My best was 12.7 with OTS Cobb Stage 2. I gained 25% torque to the wheels and 20% HP.
A 12.3 should be attainable like you said, with practice, good consistent 60ft's and with good weather conditions (humid and hot will slow you obviously)
i definitely wont hit 12.3 lol
my friend has an 06 sti and he put down 350whp on the same dyno as me. He pulls on me in the higher gears....like mid 4th
He lost to an audi that ran 11.5 at the track by 2 cars. So hes aiming for a 12.5.
Me? Ill run like a 13.8 lmao....my suspension has my front end higher than my rear, i have all season tires that will probably make me bog like crazy at the stick track, and this hot weather, for some reason, makes me not run full boost.
I think im going to sit this one out and wait til i get launch control![]()
Bugeye Mafia #213
Kevin
