ClubWRX 1/4 Mile Ranking List - Page 15
Page 15 of 25 FirstFirst ... 56789101112131415161718192021222324 ... LastLast
Results 211 to 225 of 362
This is a discussion on ClubWRX 1/4 Mile Ranking List within the Motorsport Stickies forums, part of the Motorsports Talk category; Scotty... You put me in the wrong place...
  1. #211
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  3. #212
    Registered User sethbrown2007's Avatar
    Nov 2008
    coffeyville kansas
    Quote Originally Posted by YBNormal07 View Post
    A good run for that elevation. Updated table, adding you your new run and deleting the old. Two tenths improvement is a pretty good learning curve. Did you get your new tires? Word of caution on your tire pressure. If those tires ever grab hard out of the gate, say by-by to your trans. Really...you want some spin so be careful. I always found higher pressures worked better with the AWD, but this was based on me not wanting to break my daily driver also.
    FYI, for those doubting the trap in 3rd:
    Cobb AP raises redline (7100 or 7200 rpm..I forget exactly)
    3rd gear ration: 3.7
    Final Drive: 1.366
    45 Aspect ratio tires
    225 mm width tires
    So...at 7K RPM, the car is capable of 102.89.
    Speedo inaccuracies account for any sludge, but he has a timeslip, so this is irrelavant.
    I would imagine thought that if try short shifting, you'll end up with a tenth or two knocked off and another .5 mph added on. If you are ending up in the top of 3rd, you are probably going to redline in 1st and 2nd. If you look at the HP/TQ curves, you'll see the best shift range is between 6600-6800 rpm.
    For myself, I shift when it "feels" right, and this works best for me. Sounds like you are doing the same, as you can't deny the results.
    im not doubting the trap in 3rd. i have a stg1 tune as of now and i start loosing boost around 6500 and by redline (7000rpm) im down to around 8psi. and i spoke with the guy that is going to tune my car next week and he told me that with the stg2 tune that i would be loosing boost around 6200rpm. so i was just wondering it your still holding peak boost around redline in 3rd? thanks.
    Hawk-Eye Alliance #132
    "buy it, ease it, brake it, fix it, trash it, change it now upgrade it."
    "i can easily rip the spine out of cars, and watch their bodies fall into a sea of oil and metal"
  4. #213
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by sethbrown2007 View Post
    I'll data log the next time I go to the track... then I'll figure out EXACTLY where I need to be shifting.. based off of boost, power and torque.
    I'm not holding peak boost all the way to redline, but it's pretty close... I think 14psi in 3rd
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  6. #214
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    oops...fixed
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  7. #215
    May 2002
    Stratford, NJ
    I'm still in 5th and 8th. (Should be 6th and 8th BTW)
    I went to Atco a couple of weeks ago to meet up with some people, but didn't get any clean runs in. I did, however, get two crappy no-launch runs in. I've switched over to autox, so I doubt I'll be moving up on the list now.
    Chris
    1999 Impreza RS - 12.096 @ 114.63
    2002 WRX - 12.602 @ 111.08
    1991 Eagle Talon TSi AWD - 11 second scrap pile - SOLD
  8. #216
    Jul 2003
    PA
    Quote Originally Posted by IMPREZvWRX View Post
    Good luck with the autoz. Recommendation: Save your money for track days.....imho best money you can spend on enjoying your car's full potential.
    BSR Inc.
    A full day screaming around a track as fast as your reflexes and experiences (and sometimes traffic) will allow. There is absolutely nothing like testing the true potential of your car and your nerves. You can only do this on a true track. Auto-x is a blast too, but for the cost when considering wear and tear on brakes and tires, a track day provides much more value (just my opinion).
    Cost $250.00
    Category: Recreation and safety;
    Vehicles: Your Car;
    Dates:
    March 27 (SPC)
    April 24 (SPC)
    May 1 (SC)
    May 9 - Spring Festival Only $95 (SPC)
    June 19 (SPC)
    July 24 (SPC)
    August 21 (SC)
    September 11 (SPC)
    October 2 (SC)
    October 16 (SPC)
    November 6 (SPC)
    November 20 (SPC)
  9. #217
    Registered User CobbNation's Avatar
    Dec 2008
    13.161 SEC / 102.75 MPH / 1.783 60 ft / 730 ft / 2006 / Sti / Cobbnation
    a. Intake: Cobb SFI Intake.
    b. Exhaust: Cobb TBE.
    c. EMS: Stage II Protuned
    d. Turbo modificiations: Stock.
    e. Engine modifications: N/A
    f. Drivetrain Modifications: Stock. 36 PSI front 30 PSI back.
    g. Weight Reduction: Everything was in the car, some extra garbage too.
    h. (NEW): Gas Octane: 1/8th tank of 93 and 1/8th tank of 92
    So 1/4 tank of 92.5 Octane
    i. Suspension: Stock
    j. DRIVER MODS:
    1.5 years of stick experience, First time drag experience
    2. Launch method: launch control 5500 RPM,
    3. Shift method: Shifting at 7000, 6420 rpm Flat Foot Shifting
    Fast: Throttle is lifted/clutch is engaged, but very quickly!
    2012 Lightning Red WRX
    Sold: 2006 Sti
    Sold: 07 335i coupe Monaco Blue
  10. #218
    Jul 2003
    PA
    Quote Originally Posted by CobbNation View Post
    Table updated. Got a bit more in her if I'm not missing my guess.
  11. #219
    Palmyra, NJ
    +1
    If you're protuned, you should be getting 12.8 or so. Up your PSI in your tires to 39-40 or so...little wheels spin will be great for you.
    Goodluck!
  12. #220
    Dec 2008
    +1
    Goodluck!
    Thanks for the tips guys! Next time, I plan on running on tuned E85, or(most likely) just current tune and 116 octane gas, + 40 PSI on all four tires?
    Sold: 2006 Sti
  13. #221
    Nov 2006
    Denver Metro Area
    E85 may get you into low 12's! That would be fun! 116 octane will not make any major differences unless your car is tuned for it. The EGTs will be slightly cooler, but that's about it.
    Don't waste the 7.50 on 116 octane.
    The highest legal street gas is 100 octane unleaded. If you're concerned about not getting pure 93 octane, you can add a gallon or two of 100... but I still think that would be a waste of money without a tune.
    Try adjusting the L/C to different RPMs so you can find where you build the most boost.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  14. #222
    Aug 2008
    Lafayette, La
    where do you find 116 octane gas?
  15. #223
    Jul 2003
    PA
    Quote Originally Posted by ajtoce View Post
    Google it.
    Sunoco website had it last I looked. You have to order it by the barrel and have it delivered. Or...if you have a decently supported track (drag or road course) nearby, you can sometimes get it there.
  16. #224
    Dec 2008
    They sold it had the strip I went to. It was Sunoco's race gas. Byron Dragway, Byron, IL.
    Sold: 2006 Sti
  17. #225
    May 2002
    Stratford, NJ
    Don't go sticking 116 in a mildly modded street car. Read up on proper race gas use before trying it out. It can turn into a huge waste of money.
    Chris
