ClubWRX 1/4 Mile Ranking List - Page 11
Page 11 of 25 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 151 to 165 of 362
This is a discussion on ClubWRX 1/4 Mile Ranking List within the Motorsport Stickies forums, part of the Motorsports Talk category; Originally Posted by YBNormal07 List updated. Sorry I missed your entry. Yay...outta 'de top ten! A "massive" 26 entries now. ...
  1. #151
    Registered User tom'sti's Avatar
    Feb 2007
    Reality
    Quote Originally Posted by YBNormal07 View Post
    Quite alright, I ninja turtle edited it recently for proper form. I'm sure i'll be out of the top 10 soon enough.
    Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant,"If I live, I will kill you. If i die, you are forgiven. " such is the rule of Honor.
  3. #152
    May 2002
    Stratford, NJ
    What happened to my times? You have the 12.6 in my WRX higher up in the list than faster times, and my RS time is gone. Here's my quickest RS time again.
    12.283 SEC / 114.59 MPH / 1.926 60 ft / ~sea level / 1999 / Impreza RS / IMPREZvWRX
    Chris
    1999 Impreza RS - 12.096 @ 114.63
    2002 WRX - 12.602 @ 111.08
    1991 Eagle Talon TSi AWD - 11 second scrap pile - SOLD
  4. #153
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Sorry about that. I just edited the list for duplicates, and used the name to crop what I thought were duplicates.
    I'll add your RS back in
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  6. #154
    Jun 2008
    Manitoba
    13.67 sec/ 98.6 mph / 1.81 60 ft / 753 ft / 2005 / Subaru STI / BrianMB
    Track Conditions: 86* / 35% humidity
    Car Mods: (only things done)
    EMS: ap stg 1
    Weight Reduc: no trunk stuff except the water spray
    Driver:
    Experience: got the car end of April, lol, drove 1/4 mile once before.
    Launch: rev up, let go the clutch
    Shift: tried to be fast, lifted the throttle.
  7. #155
    Jul 2003
    PA
    List updated.
  8. #156
    Registered User 07EJ257's Avatar
    Oct 2008
    Melbourne and Boca FL
    13.172 SEC / 103.63 MPH / 1.85 60 ft / Approx Sea Level / 2007 / Subaru STi / 07EJ257
    a. Intake: SPT w/ heatshield and custom ram
    b. Exhaust: 3" DP with Stock CBE
    c. EMS: XPT Stage 2 w/ 20PSI
    d. Turbo modificiations: Stock
    e. Engine modifications: Perrin Radiator Shroud
    f. Drivetrain Modifications: Stock w/ 33psi tires
    g. Weight Reduction: None, I weight 220lbs lol
    h. (NEW): Gas Octane: 93
    i. Suspension: JDM strut bars
    j. DRIVER MODS:
    1. 2 years of experience
    2. Launch method: Aggressive slip of the clutch
    3. Shift method:
    Fast: Throttle is lifted/clutch is engaged, but very quickly
    ::XPT Stage 2::12.9 @ 105::
    Hawk-Eye Alliance # 9 2 2 1
  9. #157
    Jul 2003
    PA
    Quote Originally Posted by 07EJ257 View Post
    j. DRIVER MODS:
    3. Shift method:
    List updated. It would seem you should have a bit quicker time, and certainly a higher trap with an XPT Stage 2 setup. Were you mild or aggressive on the run?
  10. #158
    Oct 2008
    Mildly. I dont use LC and I dont FFS. I did turn around and run two 12.9s the last time I went with the same mods. The 13.1 was the first trip to the track on Stage 2 so Im starting to settle in and get used to it. PLus I think when I get a legit turboback instead of running through the stock catback I should open up alittle more too. Heres the 12.9 run.
    12.938 SEC / 105.10 MPH / 1.79 60 ft / Approx Sea Level / 2007 / Subaru STi / 07EJ257
    j. DRIVER MODS:
    3. Shift method:
  11. #159
    Palmyra, NJ
    That is the first thing I thought as well. A lot of potential here
    A little bit better...you should still be able to get down into 12.7s with an XPT map. I ran a 12.73 at 107mph on the OTS Cobb Stage 2 map (also without LC and FFS). I suggest you run your tires at a little higher pressure (36-38psi) on all 4 corners. This will help generate a little more wheel spin/hop which is better for a quicker launch. With an AWD car, sometimes having too much contact patch with less pressure can bog and cause too much grip...just a suggestion
    PS...you may be right with the CBE as well...that will open things up in the top end a bit to help the flow in the high RPMs.
  12. #160
    May 2002
    Stratford, NJ
    More spin could help, but you'd never want wheel hop. It puts a ton of shock on the entire drivetrain.
    When drag racing, if you bog out your problem is not too much grip, the problem is not enough power.
    Chris
  13. #161
    Jul 2003
    PA
    j. DRIVER MODS:
    3. Shift method:
    Use your LC...you'll be amazed at the results. Much less shock to the power train too.
    Your trap will be limited by the stock CB, which I didn't notice earlier in your mod list. If anything, get the resonator out of the way with a straight pipe and you'll be golden (and a lot louder).
    As noted above, a bit higher tire pressure won't hurt...I ran from 38-42 psi, depending on weather conditions. Makes for an ungodly need for an immediate 1-2 upshift, but once you are ready for it, it becomes second nature.
    Keep up posted.
    Updated the list with your new time.
    Scott
  14. #162
    Oct 2008
    Thanks for the suggestions guys. Ill definitely bump up the pressure alittle. Ive almost saved up for a catback. Should be in in a week or two.
    Also what my friend was telling me was that I may be shifting out of my powerband. I was shifting around 7100 but suggested I shift alittle earlier at 6600 or so. What do you guys think?
  15. #163
    Palmyra, NJ
    I agree with that as well...by the time you hit 7100rpms, your boost is already beginning to taper off...so you want to shift while you're still boosting well, that way you stay in full boost for the entire run
  16. #164
    Oct 2008
    ****. Ill have to try that out. See what ETs I can hit. Should be about 2 weeks on the catback. So Ill throw her on and reattempt.
  17. #165
    Jul 2003
    PA
    If you do short shift at 6600 rpm, make sure it is an aggressive shift as your rpms will drop off quicker than when shifting at 7100.
