Results 1 to 7 of 7
This is a discussion on Tired of jacking up your car? Get some Race Ramps! within the Misc & Other forums, part of the Vendor's Forum category; Kronos Performance is now listing Race Ramp's products for car and maintenance and show pieces for vehicles. They are a ...
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    Kronos Performance is now listing Race Ramp's products for car and maintenance and show pieces for vehicles. They are a great alternative for someone who is looking to do simple work on a vehicle without having to jack up a vehicle and put it on jack stands. They are lightweight, portable and available in pieces format as well.
    Product Page: Race Ramps 56 Race Ramps [RR-56] - $203.30 : Kronos Performance, Leading since 6th Century BC
    Race Ramps 56" Race Ramps
    Lightweight Construction
    Will not Scratch or Mark any Flooring
    56 Inches Long, 12 inches Wide
    8 Inch lift Height - Works with many other products!
    56" Race Ramps Car Ramps are ideal for low ground clearance vehicles with tires up to 10" wide. With an incline of only 10.75 degrees, they lift your car up 8" and hold up to 3,000 pounds per set while weighing only 10 pounds per ramp. They are built in one solid piece, making them durable and sturdy. Like all Race Ramps products, they will not slide across a garage floor, dig into an asphalt driveway, or scratch or otherwise damage a cement or painted floor. They can be used on grass, dirt, or almost any other flat surface, and they will never rust. Race Ramps car ramps come complete with straps for easy carrying and storage.
    Product Page: Race Ramps 2-Piece 56 Race Ramps [RR-56-2] - $228.00 : Kronos Performance, Leading since 6th Century BC
    2 Piece Ramps Detach to allow more Creeper Space
    2 Piece 56 Inch Race Ramps are a perfect alternative configuration for the customer who wants more mobility while working on his, or her vehicle. The Once the vehicle has ascended the ramps, the vehicle is then firmly chocked into place. After vehicle is secure, the leading front part of the ramps can be removed, allowing a smaller ramp footprint to work in and around suspension componants of the vehicle or just general freedom of movement without being hindered by a full size ramp set.
    56" 2 piece Race Ramps are ideal for low ground clearance vehicles with tires up to 10" wide. With an incline of only 10.75 degrees, they lift your car up 8" and hold up to 3,000 pounds per set while weighing only 10 pounds per ramp. They are built in one solid piece, making them durable and sturdy. Like all Race Ramps products, they will not slide across a garage floor, dig into an asphalt driveway, or scratch or otherwise damage a cement or painted floor. They can be used on grass, dirt, or almost any other flat surface, and they will never rust. Race Ramps come complete with straps for easy carrying and storage.
    Product Page: Race Ramps 2-PC 67 Race Ramps XT [RR-XT-2] - $334.40 : Kronos Performance, Leading since 6th Century BC
    67 Inches Long, 14 inches Wide
    2 Piece Design for more mobility.
    100% Solid Core Design.
    10 Inch lift Height - Also available in two-pieces
    67" Race Ramps XT two piece car ramps are ideal for low ground clearance vehicles with tires up to 12" wide. These car ramps, with an incline of only 10.75 degrees, lift your car up 10" and hold up to 3,000 pounds per set while weighing only 10 pounds per ramp. They are built in one solid piece, making them durable and sturdy. Like all Race Ramps products, they will not slide across a garage floor, dig into an asphalt driveway, or scratch or otherwise damage a cement or painted floor. They can be used on grass, dirt, or almost any other flat surface, and they will never rust. Race Ramps come complete with straps for easy carrying and storage.
    Two-piece ramps are perfect for those individuals who would like a removable forward section of the ramp to get in and around their vehicles. Getting a creeper in and around suspension parts has always been an interesting challenge in itself. Our 2 piece design was built with this in mind.
    Product Page: Race Ramps 67 Race Ramps XT [RR-XT] - $292.60 : Kronos Performance, Leading since 6th Century BC
    67" Race Ramps XT are ideal for low ground clearance vehicles with tires up to 12" wide. These car ramps, with an incline of only 10.75 degrees, lift your car up 10" and hold up to 3,000 pounds per set while weighing only 10 pounds per ramp. They are built in one solid piece, making them durable and sturdy. Like all Race Ramps products, they will not slide across a garage floor, dig into an asphalt driveway, or scratch or otherwise damage a cement or painted floor. They can be used on grass, dirt, or almost any other flat surface, and they will never rust. Race Ramps come complete with straps for easy carrying and storage.
    More...
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    Nov 2005
    Bordentown, NJ
    *bump*
    [/SIZE]
    Registered User Monk_Knight's Avatar
    Aug 2010
    Colorado
    Wait, but isn't your average WRX a tad over 3000 lbs?
    Nov 2005
    Bordentown, NJ
    Quote Originally Posted by Monk_Knight View Post
    Its 3,000 pounds per set. A set equals 2 of them. If you're just lifting the front of the car, its not supporting all 3,000+ pounds of the car (I'm referring to the 2 ramps you drive on for the front only...they make other products that support holding the whole care).
    [/SIZE]
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    i think you should do a group buy on these in a few months when i have money.
    Nov 2005
    Bordentown, NJ
    lol it may happen
    [/SIZE]
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by shadowpr View Post
    I'd agree. I could use a set of those 10" ones....
    ::Cough Moderator pricing? Cough::
