MD: Rally Style Roof Scoop
Results 1 to 12 of 12
This is a discussion on MD: Rally Style Roof Scoop within the Mid-Atlantic States forums, part of the Regional Discussion category; This is a brand new unpainted fiberglass roof scoop and all required mounting gaskets (foam double sided to reduce noise). ...
    Aug 2002
    Virginia Beach, VA
    This is a brand new unpainted fiberglass roof scoop and all required mounting gaskets (foam double sided to reduce noise). It simply bolts into the roof of the car and is ready to go. Purchased originally from here: Primitive Racing But was never installed.
    $100 shipped, negotiable
    Thanks
    ~Tim
    Registered User AUTO228's Avatar
    May 2004
    QUEENS
    How can you install this roof scoop??
    Just stick in the top of the roof or need to drill some holes on the roof and bolt that on???
    O5 Aspen White STI + AP stage II !!!
    02 Rally Blue WRX sold !!
    STi EVO
    Aug 2002
    Virginia Beach, VA
    Quote Originally Posted by AUTO228
    I shouldn't have used the word "bolts" in my initial post...it goes on with standard body shop adhesive/bond stuff...you could bolt it on by drilling through the roof but that sounds pretty sketchy if you ever want to resell the car. it applies the same way front bumpers/lips and stuff go on.
    ~Tim
    Aug 2002
    Virginia Beach, VA
    Bump, changed the price to negotiable, so if someone slightly local wants to work something else out I can cut it down a couple bucks. This has got to go, and it's brand freakin' new!!!
    Registered User Dale_K's Avatar
    Jun 2004
    Maryland
    I'm confused. If you just stuck it on the roof with tape there wouldn't be any airflow to the cabin. You've got to cut a hole in the roof, right?
    Re-Addicted to WRX tacomaboy138's Avatar
    May 2003
    Irvine, Ca (The Bubble)
    i think that this is just the fiberglass piece for the scoop...there is a kit out there that has a small opening that can be propped open for airflow into the cabin, however this obviously requires cutting. What I would like to know is if the kit i described above works with this particular roof scoop...? It would be pretty neat to have the scoop be functional.
    2011 SWP WRX 4D
    07 MINI Cooper S... SOLD!
    03 WRX Wagon... SOLD!
    98 Toyota Tacoma...SOLD!
    Jeremy Clarkson has had my dream job.
    Aug 2002
    Virginia Beach, VA
    the actualy opening in the roof of your car requires a JDM Spec C roof vent kit, it's just a little pop-open sunroof that lets air flow in because the JDM STi Spec C doesn't have any air conditioner. This scoop will fit over the roof vent and allow both to be functional, but doesn't in itself allow air to go in since it's just the scoop. It's 50% of the equation if you want your roofline to look like the WRC cars and be functional.
    ~Tim
