Results 1 to 10 of 10
This is a discussion on Do I smell Cincinnati??? within the Mid-Atlantic States forums, part of the Regional Discussion category; Hey everyone... I'm in Cincy, I used the NASIOC, got banned for dropping an f bomb, re-registered under a different ...
    Registered User wrxwaggin's Avatar
    Mar 2004
    Cloud-Nine
    Hey everyone... I'm in Cincy, I used the NASIOC, got banned for dropping an f bomb, re-registered under a different name, and got my IP blocked... So, I was wondering if there are any Cincinnati based people on this site... I joined the NASIOC and within a month had been to two meets...
    I'm also registered at I-club and could use you feedback to find which site is better....
    Registered User Snowvert's Avatar
    Mar 2003
    I have a house in cincy and an apt in dayton, so i'm back and forth. welcome to the site.
    03 wrx - 300whp/270wtq
    Originally posted by zoophagy
    The people that work there are, for the most part, retards. I used to work there.
    Mar 2004
    Cloud-Nine
    I thought that you were a chick because of your pic... Is that your gf/wife?
    She's pretty hot.
    Mar 2003
    She's pretty hot.
    rofl. I wish. that's shana hiatt from the world poker tour.
    you're avatar is teh 0wn. I hate bush. (no pun intended!)
    Mar 2004
    Cloud-Nine
    since it's pretty much only you and me talking, is teh = the? and 0wn?
    and is w00t an expression of happiness?
    I got all excited when I saw a hot chick posting with a wrx in my town... Then it was you...
    About my Avatar... It's amazing what you can do in Paint... I did that on my PC... I just got my mac up and running... So it's time to do some serious Photoshoping of GW... wait'll you see what I do next...
    Registered User integratowrx's Avatar
    Aug 2003
    Ohio
    Did you ever end up selling that Daytona?
    '02 PSM WRX
    18" P1's, TBE, and Cobb Stage 2
    Mar 2004
    Cloud-Nine
    nope still sitting in my driveway...
    Aug 2003
    Ohio
    What exactly is wrong with it again? My friend may still be interested.
    '02 PSM WRX
    Apr 2002
    Ohio
    Sup I'm on here too.
    320hp/306tq 20g Powah
    Mar 2004
    Cloud-Nine
    There is a coolant leak under the intake behind the engine, I'm too lazy to check it out, but it could be a couple of hoses leaking, hopefully, But it may be a warped head, I've had it apart a bunch of times... They put an aluminum head on an Iron block, bigtime overheating problems, I've had a fare share, but never overheated, I'd have to stop all the time get out and squeeze the upper radiator hose untill the thermostat would open... It always had trouble with thermostats sticking, Maybe a selonoid problem... Whatever...
    I'm the third owner, I found all kinds of stupid **** under the hood... Vacume(sp*) lines connected to the wrong places, missing parts, the pass. side headlight coupling was a bent and reshaped, so someone hit something at one time, and parts were replaced, it may be a lemon, but it's on a good title, I got it for 2200 and put well over 5000 in parts in it, I have most of the receipts... Changed the oil every 3000, and basically treated it well...
    The last thing that could have possibly gone wrong with it after I replaced and fixed everything under the hood was the stearing, and it did, so no power stearing, Then the shifter cabled broke (1-2) and I replaced them, but now to get it in 1,2&R you have to pull up on the reverse lever under the knob... R is next to 1, so It gets a little tricky knowing if you're in first or reverse at a stop, but it's easy to get used to...
    It needs tires... brake work(guess)... It's been sitting in the driveway since I got the WRX March of last year.... I started it up and it runs still, The pass. rear wheel is locked up... I'm thinking of fixing her up a bit and selling her for a bit more, but if you just want to take it off my hands... You're open to do so...
