Diy
This is a discussion on NoVA Shop - Spring Install within the Mid-Atlantic States forums, part of the Regional Discussion category; Can anyone recommend a decent shop in the Northern VA area that can do a spring install (no alignment)? I ...
Can anyone recommend a decent shop in the Northern VA area that can do a spring install (no alignment)? I just called Ultimate in Sterling and they quoted me $320 + alignment ... seems really steep to me.![]()
2007 OBP WRX - Girls <3 fast cars too
Diy
2004 PSM WRX
Currently Cobb Stage 2
Blobeye Syndicate #23
Yea thanks I would if I knew how.
Should be about a two hour job.
2 x $70/hour = $140
Alignment = $60-70
Job should be about $200-250 tops.
do a search on here or nasioc. I'm sure there is a tutorial somewhere. It's really not that hard of a job to do. All you need is the tools and a buddy.
2004 PSM WRX
I would recommend DIY if you have a buddy, and got an air compressor. You'll need spring compressors too, which you can rent for free at an auto store. The air compressor will help you cut time when using the spring compressors. It took me n my friend 2 hours to do all 4 springs and a rear sway bar.
Canadian Tech Support:
"ok, type su eh"
Customer:
$sua
bash: sua: command not found
"Dont worry ma'am, we're college students, we know what we're doing"
Not sure how close you are but Andrewtech in Gaithersburg, MD is a great shop.
