Results 1 to 7 of 7
This is a discussion on NY: Would someone let me borrow a Cobb AP for 20 minutes? within the Mid-Atlantic States forums, part of the Regional Discussion category; I live in Syracuse, NY and I have an 06 WRX. I'm having a boost creep issue with my downpipe ...
    Registered User ShardAerithes's Avatar
    Oct 2005
    Wrenching under the Mitsubishi
    I'm having a boost creep issue with my downpipe and cat-back exhaust. I was hoping that someone near this area with a 2006 Cobb AP would let me borrow it for a few minutes ( you can come ride with me in my car of course) so I can see if it will solve my boost creep issue.
    Either shoot me a PM or post a reply..thanks!
    Hawk-Eye Alliance #027
    95 Mitsu 3000GT TT Sable Black
    2006 WRX TR Crystal Gray Metallic
    http://img109.imageshack.us/img109/3...dwrxsig5yd.jpg
    Registered User Redline927's Avatar
    Jun 2004
    New Jersey
    the AP doesnt work like that. you have to unmarry it from its current ECU, and remarry to yours. its not something you want to be swapping between cars.
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Quote Originally Posted by Redline927
    ^^ What he said. Just break down and get one of your own. It is only a matter of time untill you do.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Mar 2002
    Calmer than you are
    The AP's were designed to make "borrowing" impractical and copying impossible. As far as I have seen (from reading the boards) AP will NOT solve your boost creep...at least not yet. The 06's just have a small wastegate. the only known way to kill the boost creep you get from aftermarket DP's is to install a 3" high-flow cat into your DP. This will create enough backpressure to reduce or eliminate the boost creep. It will NOT hurt your performance.
    I have a 3" magnaflow OBDII cat welded into my '02's DP. The before and after dynos were within the margin of error of the dyno. you're putting in a cat that's designed for 6.7L V-8's...it flows PLENTY for a turbo 4 without getting in the way.
    again, this is what i've gotten from reading posts on this board...I do not have an '06, but this is what I've been reading 06 owners seem to be doing.
    go f*** yourself
    May 2005
    Phillytown, PA
    EM will not solve your boost creep issues. You simply need to get more exhaust gas to flow out of your wastegate. You can do this by porting your wastegate or adding a little more back pressure to your exhaust. (ie. a cat)
    Registered User Wrinkleboi's Avatar
    Jan 2002
    Langhorne, PA
    Quote Originally Posted by wrx wagone
    just want to back this up and agree with it 100%... your problem is completely mechanical and engine management or boost control will not solve it.
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
    www.TriStateTuners.com
    Registered User rx4mj's Avatar
    Sep 2005
    Freezing my arse off in NYC
    +1 on they said, and the fact it would most likely magnify your problem and make it worse.
    Hey guys, I'm back!!!
