Results 1 to 14 of 14
This is a discussion on emissions and catless vs catted in nova (vienna/tysons) within the Mid-Atlantic States forums, part of the Regional Discussion category; Hey guys, i've gotten a lot of different/vague answers on this subject and i wanted some more help in deciding ...
    Oct 2008
    Vienna, VA
    Hey guys, i've gotten a lot of different/vague answers on this subject and i wanted some more help in deciding whether to get a catted or catless invidia downpipe. I will have an accessport so the cel won't be a problem, and I would prefer to get the catless due to the much lower cost and slightly better power/flow. However, i do not want to have to switch it out everytime i go in for an emissions inspection, nor do i want to flat out fail. If need be, i will get the catted if enough people tell me i wont pass. Who from va/nova has catless, how do you pass, where do you go for inspection, etc. Any info is appreciated.
    Thanks
    1clean02_rex
    PM'D........ i'm also curious to hear from other locals.... i have my cat-less dp.... just waiting to put it on....
    Registered User 04wrx2.0's Avatar
    Jul 2005
    Colorado
    What I did was buy the TurboXs TBE with highflow cat and bought the race pipe so I could be catless when I wanted it. And it only takes, if that, 20 minutes to change out. Now with mine I have never had emissions done on my car...I get waivers lol due to Im military and dont live in that state. If anything it is worth researching that TBE to see if it will pass emissions. Im sure it would work for what you want.
    Hope this helps. Goodluck in your search.
    youtube/Pics
    Blobeye Syndicate #314
    1clean02_rex
    i was told i could run a cat=less dp, but just put on an high flow right after the dp...
    Jul 2005
    Colorado
    Quote Originally Posted by 1clean02_rex View Post
    You could. Now the TurboXs downpipe is both. It is a shorter downpipe then other brands so you can exchange the cat or racepipe. Research the system and you will see what Im talking about.
    youtube/Pics
    Read your local emissions laws - if you require a visual inspection of the emission control devices, you'll need to retain at least one cat (or something that resembles a cat) in your exhaust system.
    One thing to consider would be to get a shorty DP (e.g., Bosal) and gut the OEM midpipe cat - it has the look of a catted system, but the performance of catless. IIRC, Micah on here runs the setup I mentioned with good results.
    Jan 2008
    considering im a emmission inspector in nova area technicallt witha ap it will pass due to no cel in ecu but as far as visual inspection goes it wont pass cause you have to see a cat in the dp and up technically but from a subie owner go all catless more power and better response and when its time for emmission pm me and ill take car of you
    Oct 2008
    Vienna, VA
    Quote Originally Posted by guiltyone311 View Post
    that would be perfect, but don't they inspect for cats with the normal inspection as well?
    Jan 2008
    no not for state inspection as long as it doesnt have any leaks thats all va inspection really cares about not worried about cats
    Oct 2008
    Vienna, VA
    alright thats good to know, thanks.
    where is the place you work exactly?
    Jan 2008
    pm sent
    Jul 2005
    Colorado
    Well when I move there in February Ill have to hit you up if I run into problems. But might just keep my ohio plates.
    youtube/Pics
    Registered User shmee40's Avatar
    Jan 2008
    nova
    so will my helix catted dp pass the visual then?
    Registered User Acrdys's Avatar
    Jun 2007
    Lemore
    Quote Originally Posted by shmee40 View Post
    from what he said yes. The 07 wrx doesn't come with a cat in the up pipe. And you have a visual cat in the dp. As long as they don't know that it doesn't come with 2 cats in the dp i suppose.
    Hawk-Eye Alliance#8089
    MODS LIST
