Passing New York state inspection
Results 1 to 6 of 6
This is a discussion on Passing New York state inspection within the Mid-Atlantic States forums, part of the Regional Discussion category; I am currently cobb stage 2, I was told by a local mechanic that I will not pass the inspection ...
    Registered User droogie's Avatar
    Nov 2002
    Rochester, NY
    I am currently cobb stage 2, I was told by a local mechanic that I will not pass the inspection because they plug into the car and check the state of the o2 sensors which will fail in my case. I told him about the re flashing the ecu he said that didn't matter. Has anyone passed New York state inspection or know of a way to if the access port doesn't do it?
    -Mike
    '04 WRB premium package.
    Gutted Stock up, Godspeed dp, Cobb AccessPort (Stage 2), Omori Turbo Guage, Omori EGT Guage, Falken 512's
    Registered User vtjim's Avatar
    Mar 2003
    Colchester, Vermont
    I have AccessECU, not AccessPort. I'm assuming they do the same ODBII test that Vermont does. You should do fine. Hopefully someone with an AccessPort can back me up or tell me I'm full of it.
    The check makes sure the sensors show as "ready", and they do with the Cobb flash. The only thing the flash does is change the values that set off the CEL. It doesn't disable anything.
    I was nervous before my first post-Cobb inspection too but it passed with flying colors.
    You'll need a visible cat on your exhaust, too. Hopefully you have this. (Or doesn't NY require one?)
    Nov 2002
    Rochester, NY
    To stop the uppipe cell I originally did the resister mod. Should Iremove the resistor now that I have the access port? Will the resistor change the state of the o2 sensors?
    -Mike
    Mar 2003
    Colchester, Vermont
    I don't want to answer because I don't have the AccessPort. I'm sure you wouldn't need the resistor with the AccessECU. I don't have a resistor. I'm betting you don't need it for the AccessPort either.
    Someone will see this thread and answer. You could call Cobb and ask them, too.
    I'm pretty sure the resistor puts it into a "not ready" state which will fail you. Again, someone who knows more than me should answer.
    02 WRX Sedan, Silver ("Bugeye")
    TXS Up-pipe, Turbo-back w/cat, Cobb AccessECU Stage 2.
    97 Legacy Outback, White
    Stock. Very stock.
    Nov 2002
    Rochester, NY
    Thanks, I bet your right. I'm going to go out and remove the resistor. I wonder if I need to let the ecu go through a few cycles before it readies the o2?
    -Mike
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    its illegal to remove any emissions control devies so if they cehck for cats and youre missing, youll be tagged
