River Rd
-2 lane double shot treated tarmac
-Speed limit not posted
This is a nice little loop off the side of 501 before Buena Vista. There’s a little curvy section at the end but for the most part it just lazily snakes alongside The Maury River. I found a neat little lock or something of the sort and explored a bit. I sort of got my hale bay picture but I couldn’t really get in the middle of the field and the bales were a lot smaller than the ones on Cornelius. Last side note: there’s a very cool solar house on this road that’s worth checking out.
Hay bale shot was sort of a letdown w\2ft tall bales
At the Lock
Solar House
501N
-2 Lane Asphalt
-55\45\35\25mph
Back onto 501N and it heads into the town of Buena Vista. It’s a very picturesque town but also a very big speed trap. If it says 25mph, one would be wise to proceed at exactly 25mph.
Buena Vista Old Court House
60E
-2 Lane Asphalt\Concrete
-55mph
This is another up and down a mountain road. Nice and smooth with some tight turns. Watch out for the second right hander coming up as it decreases radius mid corner(my speed triple explored the cliff on the left side after I dismounted mid turn). This road actually continues to have some nice turns past the parkway for a while but I usually opt for the parkway simply because it turns to long, straight, and flat in the middle of nowhere on it’s way back to Lynchburg and I generally speaking do not like to double back.
Yum
Watch out for that
Blue Ridge Parkway South
-2 lane Asphalt\Concrete
-45mph
Ah the good old parkway. Thank you depression. If you’re up for a scenic drive it’s hard to beat the parkway. I pretty much stopped at every overlook to check things out and take some pictures. There are a couple sections going up to the peaks of otter that can be fun at 50mph but I generally just cruise. Park rangers have more power than the police and I’ve never really had the urge to get on their bad side. In addition, there is a park ranger station at pretty much every entrance\exit so running from their jeep grand Cherokees might not be such a good idea after all. But the fire roads you say, there are hundreds of miles of fire roads that line the sides of the parkway. Well unless you know those hundreds of miles of fire roads without looking at a map, which I don’t and I drive the parkway a lot, you will probably run into a dead end. Just don’t speed, enjoy the road for what it is.
Stepping Stones
Lake
James River
Unidentified Fire road
-1 lane gravel
Speaking of dead end fire roads, I got denied again. I try to check out the fire roads every now and then as occasionally you will find a gem of perfectly kept, banked gravel for miles but the problem with the fire roads is they are constantly changing. One day it might be open, the next day it may have a giant barricade across the road, or in my case, a post. The reason I tried this one out was that it was not on my map and generally speaking most roads are on my map. Apparently there was a reason it was not on my map.
43N\S double back
-2 Lane Tarmac\Asphalt\Concrete
-55mph
Earlier I said I don’t like to double back. This is the exception to the rule. If you have an Evo or an STI, this is your road. I would highly suggest driving whatever distance you must just for this 4 or so miles of road. Smooth, not really. Long, no. Tighter than Deals gap going up the side of a mountain with at least a 10% grade, that it is. So that coupled with the fact that it was getting late is my reason for doubling back. Side note-there’s some sort of rock quarry at the bottom of the mountain, they’re usually pretty strict about letting people in but I just asked to take a couple pictures this time and they were very cool about it. Sadly not one of them came out.
It is indeed a Land of many uses
Curves
Switchback and then some
Goose Creek Valley Road(695)
This is another one of those roads I always passed up just because I was stuck in a rut. Without exception I always get back on the parkway after coming back up 43. Today I decided to be different and was greatly rewarded. This road is pretty much an extension of 43 on the other side of the mountain but more of a tarmac road surface. Some very tight switchbacks occupy this road on it’s way down the mountain. Change is good.
Afternoon rex
Murrells Gap(680)
-2 lane gravel\tarmac
Wanna be Colin Mcrae? Buy a house on this road and you’ll probably progress to something along those lines. Loose gravel and VERY tight turns inhabit the opening section of this road. This is not the road for all you posting up “where do I learn how to drift,” Some of the turns on this road I don’t even understand how car traverse it on a regular basis. By this I mean that my turning radius is not tight enough to get around some of the turns without the use of the hand brake. After the beautiful opening section the road sort of goes to **** for a while with rocks protruding through the road. This continues for a bit until it turns into a nice civilized tarmac road.
Not much room for error
Get tight
Kelso’s Mill(682)
I went down this road at night so I can’t really be sure but I’m almost positive this would be a beautiful road during the day. It snakes through a valley and in the distance I could see there were some mighty big homes leading me to believe there are some incredible views to be had.
Kelso Mill Gas Station
I sorta like how busy this came out
43N
-2 lane Asphalt
-55\45mph
Back on 43, but this time on the south side of the blue ridge parkway. This road actually continues up to the parkway and some fun little turns right before it’s adjunction to the parkway but it was dark and I wanted to get home.
Jopling(643)
This is the quintessential country highway or at least I like to think it is. It’s pretty much a 55mph road with a couple of exceptions. Basically just a nice flow to the whole thing. Side note-turning onto 640 off this road will lead to some really good fresh apples.
Playing with Overexposure
Everybody else’s headlights going through this section kept washing it out so I set up the timer and drove through with the parking lights on
Disclaimer: I do not condone breaking the law but I do encourage others to get out there and drive. These are all public roads and are meant to be driven as such. Stay within your limits and if you want to exceed them go to a SCCA event. I’ve done both AutoX and RallyX in the past and they’re both a complete blast. Have fun and stay safe.
LinkBack URL
About LinkBacks
, and thanks for the write up
