Results 1 to 3 of 3
This is a discussion on My 07 wagon within the Member Show-Off & Photography forums, part of the Community - Meet other Enthusiasts category; i discovered it helps to check if your flash has batteries before you try to use it... either way heres ...
    Registered User npdynamite's Avatar
    Jan 2013
    My 07 wagon
    i discovered it helps to check if your flash has batteries before you try to use it... either way heres some pictures of my subie and i think ill do some more in the daylight when i get a chance
ID:	111403Click image for larger version.
ID:	111404Click image for larger version.
ID:	111405Click image for larger version.
    zax
    zax is online now
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Nice. I wouldn't use the flash in that setting anyhow. A nice tripod and adjustment to the aperture/exposure will turn out nicely
    Facebook me here
    Jan 2013
    true, i think i left my tripod at my parents so i was going to use the flash instead, so i had to crank my exposure time up a bit more than i like without a tripod, so most of the photos were blurry, i might try the same location again when i have my tripod and get the car cleaned up a bit, it needs a good waxing
