2011 Obsidian Black Pearl - STi Sedan
Driveline
- TiC Linkage bushings
- TiC wide pivot bushings
- STi Group-N Engine Mounts
- Beatrush Transmission Mount
- Subaru SPT Short throw shifter
- Beatrush Propeller Shaft Mounts
- Kartboy rear shifter stay bushing
- Whiteline Steering Rack Bushings
- Kartboy front shifter stay bushings
- Beatrush Forged Pitching Stopper Mount
- Whiteline Rear Positive Power Kit Inserts
- Whiteline Rear Diff - mount in cradle insert bushings
Brakes
- GoodRidge G-Stop braided stainless steel brake lines
- ATE Superblue brake fluid
Engine
- Perrin CAI
- Perrin heat shield
- Grimmspeed EBCS
- Grimmspeed IWG block off
- AEM (UEGO) WBo2 Sensor
- Turboxs catted downpipe
- Turboxs quad tip catback exhaust
- Killer B Alternator/Radiator Shroud
- Deatschwerks dw65c fuel pump
- Mishimoto Baffled Oil Catch Can
- Mishimoto Silicone Induction Hose
- Tial MV-S External Wastegate 38mm
- Mishimoto X-Line Aluminum Radiator
- Mishimoto Silicone Radiator Hose Kit
- NGK Iridium Spark Plugs One Step Colder
- Injector Dynamics 1000cc fuel injectors
- Killer B Motorsport 4-1 Holy Header w/EWG Up pipe
- Extreme Turbo Systems (ETS) top mount intercooler
- Go Fast Bits Mach 2 TMS Recirculating Diverter Valve
- DEI titanium heat wrap on down pipe and headers (LR tech)
- Cobb Access Port
Interior
- AEM - Boost gauge
- AEM – AFR (UEGO) gauge
- Beatrush oil cap (gold)
- LED (white) interior lighting kit
- Subaru SPT foot well illumination kit – red
- BFM Wideband O2 A/F Data Logging Cable
- Perrin - Black aluminum reverse lock out lever
- JPM Coachworks – Black Alcantara/cherry red stitching - shift boot
- JPM Coachworks – Black Alcantara/cherry red stitching - hand brake boot
- WC Lathe Werks - Titanium STi Sphere - Blued to bronze fade (with the five grooves)
- WC Lathe Werks - STi Si Drive Dial - Blued to bronze fade
Exterior
- Gloss Black Powder coat Stock STi wheels (18x8.5 +.55 offset) (Winter)
- Bridgestone Blizzak - 245/40/18 (Winter)
- Enkei Matte Black PF01 wheels (18x9 +.45 offset) (Summer)
- Michelin Pilot Super Sport – 255/35/18 (Summer)
- Muteki SR35 16+4 Closed Ended Black Lug Nuts
- Black JDM STi side badges
- Rally Armor mud flaps (red lettering)
- Window Tint – 15% back/35% front/5% sun visor (by Portland Tint)
- SPT Carbon fiber trunk trim delete
- PIAA LED license plate illumination
- Color changing turn signals (white LED running/amber blinker) - from fastwrx
- PIAA Plasma daytime running/High beam bulbs (9005)
- Front/Rear badge overlays (carbon fiber background with gloss black constellation)
- Forcewerkz Carbon fiber HD style front lip spoiler
- Red tail light overlays
- Debadged trunk (except the Subaru emblem/STi badge or course)
- Perrin shorty antenna
- Window chrome delete (vinyl overlays)
- Perrin polyurethane exhaust hangers
- Grimmspeed license plate delete
- Grimmspeed license plate relocation kit
- Red Hella twin supertones - 118db
Also have a custom alignment - Maxed out front and rear camber (-1.4 LR front, -1.7 LR rear).
* Awaiting install...
Maintenance items used
- Subaru Super Coolant/plus system conditioner
- OEM Cabin Filter
- Subaru 75W90 Extra-S Gear/Trans Fluid
- Subaru Hypoid LSD Oil
- Amsoil 5w30 synth
- Wix (NAPA) Platinum Oil Filter (have also used Amsoil filters)
- Fumoto F-105 Oil Drain Valve
- OEM crush washers
- PIAA SI-Tech silicone flat wiper blades
- Gates Alternator/Steering pulley & A/C belts
- Optima Red Top Battery
Driveline
Brakes
Engine
- Perrin CAI
- Grimmspeed EBCS
- Cobb Access Port
Interior
- AEM - Boost gauge
Exterior
- OEM Cabin Filter
- Amsoil 5w30 synth
- OEM crush washers
