My 2011 OBP STi
67K views 229 replies 43 participants last post by  bue car
#1 · (Edited)
2011 Obsidian Black Pearl - STi Sedan
Driveline
- TiC Linkage bushings
- TiC wide pivot bushings
- STi Group-N Engine Mounts
- Beatrush Transmission Mount
- Subaru SPT Short throw shifter
- Beatrush Propeller Shaft Mounts
- Kartboy rear shifter stay bushing
- Whiteline Steering Rack Bushings
- Kartboy front shifter stay bushings
- Beatrush Forged Pitching Stopper Mount
- Whiteline Rear Positive Power Kit Inserts
- Whiteline Rear Diff - mount in cradle insert bushings
Brakes
- GoodRidge G-Stop braided stainless steel brake lines
- ATE Superblue brake fluid
Engine
- Perrin CAI
- Perrin heat shield
- Grimmspeed EBCS
- Grimmspeed IWG block off
- AEM (UEGO) WBo2 Sensor
- Turboxs catted downpipe
- Turboxs quad tip catback exhaust
- Killer B Alternator/Radiator Shroud
- Deatschwerks dw65c fuel pump
- Mishimoto Baffled Oil Catch Can
- Mishimoto Silicone Induction Hose
- Tial MV-S External Wastegate 38mm
- Mishimoto X-Line Aluminum Radiator
- Mishimoto Silicone Radiator Hose Kit
- NGK Iridium Spark Plugs One Step Colder
- Injector Dynamics 1000cc fuel injectors
- Killer B Motorsport 4-1 Holy Header w/EWG Up pipe
- Extreme Turbo Systems (ETS) top mount intercooler
- Go Fast Bits Mach 2 TMS Recirculating Diverter Valve
- DEI titanium heat wrap on down pipe and headers (LR tech)
- Cobb Access Port
Interior
- AEM - Boost gauge
- AEM – AFR (UEGO) gauge
- Beatrush oil cap (gold)
- LED (white) interior lighting kit
- Subaru SPT foot well illumination kit – red
- BFM Wideband O2 A/F Data Logging Cable
- Perrin - Black aluminum reverse lock out lever
- JPM Coachworks – Black Alcantara/cherry red stitching - shift boot
- JPM Coachworks – Black Alcantara/cherry red stitching - hand brake boot
- WC Lathe Werks - Titanium STi Sphere - Blued to bronze fade (with the five grooves)
- WC Lathe Werks - STi Si Drive Dial - Blued to bronze fade
Exterior
- Gloss Black Powder coat Stock STi wheels (18x8.5 +.55 offset) (Winter)
- Bridgestone Blizzak - 245/40/18 (Winter)
- Enkei Matte Black PF01 wheels (18x9 +.45 offset) (Summer)
- Michelin Pilot Super Sport – 255/35/18 (Summer)
- Muteki SR35 16+4 Closed Ended Black Lug Nuts
- Black JDM STi side badges
- Rally Armor mud flaps (red lettering)
- Window Tint – 15% back/35% front/5% sun visor (by Portland Tint)
- SPT Carbon fiber trunk trim delete
- PIAA LED license plate illumination
- Color changing turn signals (white LED running/amber blinker) - from fastwrx
- PIAA Plasma daytime running/High beam bulbs (9005)
- Front/Rear badge overlays (carbon fiber background with gloss black constellation)
- Forcewerkz Carbon fiber HD style front lip spoiler
- Red tail light overlays
- Debadged trunk (except the Subaru emblem/STi badge or course:))
- Perrin shorty antenna
- Window chrome delete (vinyl overlays)
- Perrin polyurethane exhaust hangers
- Grimmspeed license plate delete
- Grimmspeed license plate relocation kit
- Red Hella twin supertones - 118db
Also have a custom alignment - Maxed out front and rear camber (-1.4 LR front, -1.7 LR rear).
* Awaiting install...
Maintenance items used
- Subaru Super Coolant/plus system conditioner
- OEM Cabin Filter
- Subaru 75W90 Extra-S Gear/Trans Fluid
- Subaru Hypoid LSD Oil
- Amsoil 5w30 synth
- Wix (NAPA) Platinum Oil Filter (have also used Amsoil filters)
- Fumoto F-105 Oil Drain Valve
- OEM crush washers
- PIAA SI-Tech silicone flat wiper blades
- Gates Alternator/Steering pulley & A/C belts
- Optima Red Top Battery
See less See more
4
#5 ·
Ah tell me about it. Almost impossible to keep clean and the clear coat is all streaky...I am looking into getting a better paint job this spring!
awesome car, what running lights are you using?
I have have the color changing LED turn signal bulbs installed, but the actual lights are stock. The LED turn signals flash orange when the blinker is on but run clear. Here is a link to where I got them. Color-Changing LED Turn Signal Bulbs - Lighting
This post has been deleted
#18 ·
I called up Subaru of America and sent them pictures of the chipping and also sent them a quote from my autobody shop to have the hood/pillars repainted and they sent me back a response saying that as a good will gesture they would reimburse me $500 of the amount of the $625 quote. Ever hear of the squeaky wheel getting the grease? If you just listen to everyone telling you that SOA won't do anything and accept that without trying then they certainly won't do anything fory you. I have found different on more than one occasion.
#25 ·
#27 ·
The DRL's are just PIAA bulbs (plasma gtx), but the turn signals are a dual colored LED bulb that burn white except when you put your blinker on, at which point they blink amber. I posted a link earlier to them. Straight replacement bulb, no modifications to any wiring at all. The turn signal bulb is more difficult to access than the DRL's though.
#31 · (Edited)
They are not my DRLs. They are my front marker lights, as they are on when I am driving with my headlights on (all lights on). But the DRL's and my high beams are PIAA bulbs (9005). The picture on my avatar is my car with just the parking lights on. They are pretty cool. See post #5 for a link to where I got them and a video of them working.
